tranny skid rattle - JeepForum.com
post #1 of 3 Old 07-11-2010, 08:57 AM Thread Starter
Thrust
tranny skid rattle
I have an '04 LJ and I've had a rattle for the past year. I've looked all over for the source of the sound including, sway bar links, shock bushings, loose track bar, etc.
Today I crawled under the Jeep and hit the tranny skid with my hand. This seems to be the source of the noise. It's not exhaust related and there's no contact with the exhaust. Just a very slight metallic sound. Also, I grabbed the rear drive shaft to check the play in the transmission mount. There's some play, but not a lot.
Any ideas of what to check/tighten? I checked the four nuts that bolt the tranny mount to the skid; all were tight.
TIA!
**edit** I should mention, I checked for rocks bouncing around on the tranny skid. This is not the problem.
Prior to the lift, a TJ has the aerodynamics of a brick. After the lift it has the aerodynamics of a brick 2.5 inches higher.
Thrust is offline
post #2 of 3 Old 07-11-2010, 09:07 AM
05moabTJ
05moabTJ's Avatar
Sounds like you covered it, turn up the radio....
Synergy 3" Phase 3,FOX,TOYOs 37",TrailReady 17HD Beads,RCV shafts,Yukon 5.13
05moabTJ is offline
post #3 of 3 Old 07-11-2010, 09:46 AM Thread Starter
Thrust
That's one option, but I'd rather fix the problem.
Thrust is offline
noise , rattle , tranny , transmission , skid , solution , help
Rattle/knock near skid plate 2ACR TJ Wrangler Technical Forum 2 05-05-2010 07:56 PM
Oil Pan Skid Rattle Stafford TJ Wrangler Technical Forum 14 02-01-2009 05:16 PM
Rattle from tranny FarFire70 TJ Wrangler Technical Forum 5 07-20-2007 12:00 PM
Skid Row Engine/tranny skid Instructions? 06WranglerX TJ Wrangler Technical Forum 3 06-13-2007 08:08 PM
Diff Skids/Steering Box Skid vs. Tranny Skid MCanavan TJ Wrangler Technical Forum 2 04-06-2006 05:42 PM
