Tranny Mount / Skid Plate Help TJ - JeepForum.com
post #1 of 21 Old 06-22-2013, 07:36 AM Thread Starter
RootJ
As you can see, I have a problem with a few constraints to contend with.
http://www.jeepforum.com/forum/f9/st...-fast-1539457/
I have been preparing to rebuild (weld) some f-rust-rating damage on my baby's frame.
Back in December my skid plate fell off due to rusted bolt holes and I have lined up two different welders for the repair but due to extreme personality flaws both of them flaked on the job. The skid is welded on.
I now have it all lined up but my t'case failed and I need to swap the t'case to be able to drive to the location that I have set up for the fab job.
Is there a way to hold the drive line in place after grinding off the skid to replace the t'case so I can drive the 2 hours t' get the skid and rails welded?
Maybe ratchet straps? I don't know.
RootJ is offline
post #2 of 21 Old 06-26-2013, 03:10 PM
Cavitation
Jacks and blocking. Jack the TC remove skid jack and block trani then remove TC.
Cavitation is offline
post #3 of 21 Old 06-26-2013, 05:30 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Moved to TJ Tech.
Wheelin98TJ is offline
post #4 of 21 Old 07-08-2013, 11:21 AM Thread Starter
RootJ
I ground the bolt head flush with the skid plate. If I go further I'll grind into it. What next?
RootJ is offline
post #5 of 21 Old 07-08-2013, 11:29 AM
Cavitation
Some heavy ratchet straps are fine.
post #6 of 21 Old 07-08-2013, 11:30 AM
NotURMailman
NotURMailman's Avatar
I thought the skid was welded to the frame?
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #7 of 21 Old 07-08-2013, 11:54 AM Thread Starter
RootJ
Other side is welded to the frame, easy, I'll cut the bead but passenger side has seized bolts. Gotta take them out to drop the thing.
RootJ is offline
post #8 of 21 Old 07-08-2013, 12:03 PM
Cavitation
You would have been better off Just putting a breaker bar to those and snapping them. Now it looks like you'll have to drill them out.
post #9 of 21 Old 07-08-2013, 12:03 PM
NotURMailman
Try drilling through the center of the bolt. Increase in size until you are about to drill into the threads.
post #10 of 21 Old 07-08-2013, 12:08 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Now is a perfect time to make your own skid like I did.
RnEmOvr is offline
post #11 of 21 Old 07-08-2013, 12:25 PM Thread Starter
RootJ
Couldn't snap them because they were in good shape to begin with, just seized.
Ok so I have step bits, that should work eh?
RootJ is offline
post #12 of 21 Old 07-08-2013, 12:40 PM
tjsean0308
FYI the stock bolts are a tapered shank as you probably know.
Just be careful not to drill into the skid plate that's all. I think a step drill would work well. Should be close to the same angle.
tjsean0308 is offline
post #13 of 21 Old 07-08-2013, 01:30 PM
joe_jeep
cut all that crap off and start over. its not worth fixing as is.
the replacement skid plate "RnEmOvr" made is a good fix for you.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #14 of 21 Old 07-08-2013, 01:36 PM Thread Starter
RootJ
Waiting is not an option at this point. I have to use this one
RootJ is offline
post #15 of 21 Old 07-08-2013, 01:43 PM Thread Starter
RootJ
Originally Posted by joe_jeep View Post
"RnEmOvr".
What is that? Google has suggestions but no results.
RootJ is offline
