Tranny Mount With a Motor Mount and Body Lift
| Poison Spyder February Special: FREE Rubber Liners when yo | Slappin' on 61,510 Rigid Industries Lumens for Big Red | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
Geaux Tigers!!!
I've got a 1" body lift on my TJ and of course have occasional issues shifting to 2nd gear....moreso when in 4-Lo. I looked at my transmission mount last night and it's pretty torn up.
I was going to just get a new one, but then I thought of something. Shouldn't the tranny be raised 1" like the body and motor? And this would likely (hopefully) address my shifting issue. So does anyone make a 1" taller motor mount or should I just make some spacers for it? I'm not interested in a tummy tuck right now, but that may happen eventually. Thanks, Tommy
2001 Wrangler Sport - 4.5" homemade long arm lift, 1" body lift, 4.56s, 35" MTR Kevlars, 15x8 Pro Comp alloys, D30/Lock Right/alloys, D44/Detroit My Jeep Build Journal Long Arm Suspension Build |
#2 |
I've never seen a raised transmission mount, But it would cause problems
with your drive line angle. The reason you have a one inch engine lift it so lessen the drive line angle. You do not mention if you have a lowered transfercase skidplate, or an SYE. You have in your signature a mention of a 4.5 inch lift. So I am assuming you have one of them. If you lift your tranny up your gonna have bad vibes if you have a lowered skid plate, This will negate your engine lift helping your driveline angle. If you have an SYE and a CV driveshaft, you can get a tummy tuck and it will raise your transmission up one inch and level your engine and transmission. You will have to adjust your rear pinion angle too.
The above post is my opinion and I have no facts to prove it... :)~ http://www.tjhardcore.com The ultimate TJ owners only forum |
#3 |
Geaux Tigers!!!
I do have a SYE and CV driveshaft so there's no worries there. The reason I have a MML isn't to lessen driveline angle. It's to eventually do a tummy tuck, to get the oil pan a bit higher, and to keep the motor/fan properly positioned with everything else under the hood. The prev. owner had done it, actually, but that's immaterial.
![]() If someone makes a taller tranny mount to level the tranny/t-case with the motor (after a MML), I'll get it. I just don't know if anyone makes one and I need to get something ASAP. Tommy
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
