Tranny Leak, any common place for a jeep to leak - JeepForum.com
post #1 of 7 Old 03-22-2006, 01:26 PM Thread Starter
jb1dsl
I have a 2000 sahara auto and the tranny has started leaking a little. I got under there and cleaned off all the excess fluid. It looked like it was leaking a little around the pan gasket at the front of the tranny. I tightened the pan bolts down some but it still continues to leak. I have had the jeep for about 2 months and was wondering if the autos in jeeps had a common spot that leaked. I guess I will pull the pan and put a new gasket on it to see if that works. What kind of fluid and how much to drop the pan.
Thanks
Brad
Back in a Jeep again. Sorry I left for a bit.
jb1dsl is offline
post #2 of 7 Old 03-22-2006, 01:35 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
buy the rubber reusable gasket...EDIT: I think they offer one of these, instead of the cork gasket
ATF+3 is fine...
4 qts needed for a service fill (dropping the pan)...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #3 of 7 Old 03-23-2006, 07:53 AM Thread Starter
jb1dsl
Thanks....
jb1dsl is offline
post #4 of 7 Old 03-23-2006, 08:28 AM
Viet15philong
ATF+3 is fine...
Greg
Yes, they do offer the Rubber Reusable gasket. While you under there I would put a deep tranny pan..
Anthony
Viet15philong is offline
post #5 of 7 Old 03-23-2006, 08:40 AM
BigWaylon
tubework is cool...
BigWaylon's Avatar
Anthony
thanks...
I know I bought one for my Dodge Ram...and was "almost" sure I had bought one for the '99 when I bought it used about 2 years ago...
Greg
post #6 of 7 Old 03-23-2006, 09:57 AM Thread Starter
jb1dsl
So is it common for the jeeps to have pan gasket leaks?
jb1dsl is offline
post #7 of 7 Old 03-23-2006, 10:09 AM
mdm
Farm Wheeler
Can't answer about how common leaks are with Jeep automatics, don't have one/never had one.
But be careful when tightening up bolts when trying to stop a leak. It is real easy to break bolts, strip threads, distort the pan lip, etc...
mdm is offline
is this a common leak?/ Anonymous6915 YJ Wrangler Technical Forum 5 03-10-2009 01:29 AM
My jeep is down! (Tranny leak) MudMony TJ Wrangler Technical Forum 6 09-08-2008 11:23 AM
oil leak? is this common...? KeithMutiny TJ Wrangler Technical Forum 21 06-10-2007 08:29 PM
Common 4.0 L Oil leak? joppermann TJ Wrangler Technical Forum 3 05-15-2007 08:02 AM
Common YJ Leak Locations? BzJeep YJ Wrangler Technical Forum 10 05-12-2005 09:50 PM
