Quantcast Tranny fluid change - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Tranny fluid change
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comPoison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.
Old 10-09-2008, 10:51 AM   #1
tjwrangler99
tjwrangler99's Avatar
Tranny fluid change
so based on my name, we all know i have a 99 TJ, its a sport.
i have the I-6 and the manual.
Was wondering if anyone here has changed the tranny fluid in one of these and how easy/annoying it was. The cheapest ive heard from a dealer is 160 bux to have it done, and i really dont feel like paying for that. Plus i like learning how to do crap on my own.
its going on almost 80k now, so im guessing it needs some TLC.
EDIT::
Oh and is there anything i should be doing to the transfer case while im at it?
1999 TJ
BFG AT 31's | BDS 2" Lift | JKS Quick Disco's | Zone Rear Sway Links | TeraFlex 1/2" Drop+Washer | Warn M8000 | Viking 80' 3/8 Synthetic w/ Safety Thimble | Viking 350 Fairlead | MetalCloak AL Bumper | 99 Durango Steering Box | Uniden 520 CB w/ 3' FireStik | ebay header | Magnaflow Mid-Cat | Banks Cat-back | XJ Steering Linkage | Hella Black Magic (x4)
2011 Patriot FD1
tjwrangler99 is offline   Reply With Quote
Old 10-09-2008, 11:03 AM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
The drain for it is on the the side of the passenger-side near the bottom, towards the front of the transmission. The fill hole is on the driver's side, half-way up. Fill it until it starts overflowing out of that hole. Be careful what gear lube you use, not all are suitable for your AX-15 transmission. I recommend Redline MT-90 (a synthetic) which you can get from www.summitracing.com/ and read about at www.redlineoil.com/. It holds approx. 3 1/3 quarts so you'll need to buy 4 quarts. This is an easy one-banana job.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 10-09-2008, 12:00 PM   #3
RokleM
Never having changed ANY oil in my life, I did both diff's (with seals), transmission, transfer case, and motor based on the info on this site. It's not that bad honestly. Plan plenty of time, get all your materials before hand (took me a few trips to find everything I needed), and go slow. I'm sure I saved a ton of money.
RokleM is offline   Reply With Quote
Old 10-09-2008, 12:06 PM   #4
Imped
TITS
Imped's Avatar
It's SUPER easy and will take, at most, 45 minutes of your time. That's with drain time, putting new lube in, and any trouble you may have with the drain and fill screws. Never pay anyone to do your lube changes....everything is so easy.
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Old 10-09-2008, 01:07 PM   #5
tjwrangler99
so in terms of the transfer case, what should i use?
1999 TJ
2011 Patriot FD1
Old 10-09-2008, 01:22 PM   #6
jeepwrnglr92
my tcase takes ATF. I have a 98 TJ and my 92 YJ takes atf too. There is a sticky with the fluids and quantities needed. I found that very helpful.
For sale 1992 YJ Wrangler: Hurculiner, bestop Safari top.RC 4" lift 32 AT wheels, custom bumpers,
2000 Corvette Roadster: Almost stock
http://www.demonoff-road.com/
2002 Avalanche: To many mods to list
jeepwrnglr92 is offline   Reply With Quote
Old 10-09-2008, 03:52 PM   #7
Imped
TITS
Imped's Avatar
I use Royal Purple Synchromax in my tranny and t-case. I suppose you could run it in the diffs as well. It's great stuff.
OlllllllO
Float Test Build
IndyORV
Best served cold
Old 10-09-2008, 03:53 PM   #8
Jerry Bransford
Pretty much any good quality ATF. Mercon, ATF+3, ATF+4 (way more expensive), etc. If it says ATF on the bottle, the 231 t-case used in all TJs is happy with it. It's only the automatic transmissions that are fussy about the kind of ATF they get.
Getting Savvy...
Old 10-09-2008, 03:58 PM   #9
Jerry Bransford
Synchromax is not a GL-5 so it does not meet the specs required for axles/differentials. Neither does it meet the recommended specs for the TJ's 231 t-case which specifies ATF. It would be fine for gear-based transfer cases but the 231 t-case used in the TJ is chain-based, not gear based.
Getting Savvy...
Old 10-10-2008, 06:27 AM   #10
tjwrangler99
so im guessing you still use ATF in the manual tranny?
1999 TJ
2011 Patriot FD1
Old 10-10-2008, 06:34 AM   #11
Kiwi Jeeper
ATF = Automatic Transmission Fluid
'01 TJ Renegade I6 4.0L Auto D30/D44, BFG Muds, Currie springs, OME shocks, Brown Dog MML, ARB Front and Rear Bars, Rokmen Gas tank skid and LCAs, RE UCAs, JB Conversion Super Shorty with Truspeed and TW shaft, Warn 9.5xp
'03 WG Limited V8 4.7L stock standard
Kiwi Jeeper is offline   Reply With Quote
Old 10-10-2008, 12:58 PM   #12
tjwrangler99
ok so Redline MT-90 for the tranny and ATF for the transfer case
1999 TJ
2011 Patriot FD1
Old 10-10-2008, 01:41 PM   #13
Jerry Bransford
Getting Savvy...
Old 10-12-2008, 04:37 PM   #14
Luke4554
will 75-90 weight gear oil be bad in a 2000 tj 4.0 liter five speed tranny? Ive used syncromesh before in my talon but i didnt know what to get for the jeep. I think its a gl-4 or gl-5
[SIZE="1"][B]2000 TJ Sport[/B]
4.0L | 5spd | 4" SkyJacker | Soft 8's | 33" TRXUS | 30/35 | AA SYE/CV DS | SuperWinch | 4 KC's | Pure Bred Tube Fenders | EMPI Buckets | Novak Linkage| Pure Bred Bumpers | Bestop Tinted Soft Top & Bikini | HiLift | Yellow Top | Herculiner | JKS Discos | Skid Row Steering Skid
[b]Owner of [U]WWAutosports[/U] & [U]Pure Bred Fabrications[/U] Dayton, Oh[/b][/SIZE]
Luke4554 is offline   Reply With Quote
Old 10-12-2008, 04:44 PM   #15
97casteeltj
also make sure you take your filler plug out first, then the drain plug!!
needing a new rig....
97casteeltj is offline   Reply With Quote
Glock Forum
