Tranny cooler - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Tranny cooler
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-25-2014, 02:39 PM   #1
Groove508
Tranny cooler
I'm told I better get one of these for my '05 Rubicon auto. It does seem to light up the floor board in the summer months. I'm interested in one I can slide through the headlight opening. I would like to keep it under 50 bucks but if there's not one out there any good for that, I will spend more. Brand and model please, I want to order one soon!! Thanks!
Groove508 is offline   Reply With Quote Quick reply to this message
Unread 12-25-2014, 03:47 PM   #2
Jerry Bransford
Administrator
Jerry Bransford's Avatar
While an auxilliary transmission cooler is an excellent upgrade for any automatic transmission, the heat you're feeling under the floorboard is actually from the catalytic converter which gets REALLY hot.
This type of cooler fits through the headlight opening.... I first installed one for my transmission in my previous TJ and installed the same type of cooler for my power steering system in my present TJ. PM JF member mrblaine who sells them with a cool mounting bracket that makes installing them easy.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 12-25-2014, 03:48 PM   #3
joe_jeep
Thx jerry.
I need one too.
Merry Christmas!
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline   Reply With Quote Quick reply to this message
Unread 12-25-2014, 03:53 PM   #4
biffgnar
biffgnar's Avatar
In that price range, B&M has some passive coolers that work well mounted in the grill.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 12-25-2014, 04:34 PM   #5
SpaceWrangler
Gnarly Adventurer
SpaceWrangler's Avatar
Location: Where the Girls Dance Different With Familiar Grace
Yep. I've been running one of these for the past few years...
http://www.jegs.com/i/B%26M/130/7026...CsMaAiAO8P8HAQ
My 3-speed runs nice and cool (trans temp gauge), even towing a small fishing boat.
"It always seems impossible until it is done." -Nelson Mandela
My Epic Five-Week Cross-Country Jeep Safari
SpaceWrangler is offline   Reply With Quote Quick reply to this message
Unread 12-25-2014, 04:54 PM   #6
joe_jeep
Will that passive one fit through the headlight hole?
Im guessing no?
glfwda #6624
Unread 12-25-2014, 04:59 PM   #7
BamaJeepman21
I have a small B&M with a remote filter and deep pan. I need to install a temp gauge but so far it works great.
Wanted: Savvy/Currie 3" front springs
-Jack
BamaJeepman21 is offline   Reply With Quote Quick reply to this message
Unread 12-25-2014, 06:52 PM   #8
SpaceWrangler
Gnarly Adventurer
Im guessing no?
You mean the B & M cooler I posted? No, but it's pretty thin. You can slip it behind the grill after loosening the radiator. The rad hoses remain in place, no mess.
You can clamp it to the diagonal grill supports with insulated cable clamps, available at Lowe's, McMaster, etc.
Mount the cooler with its hose fittings pointing up.
Unread 12-26-2014, 08:51 AM   #9
biffgnar
biffgnar's Avatar
Actually I have put that cooler in through the headlight hole. It requires cutting two small notches in the grill around the light and then "encouraging" it. Once everything back together the light bezel covers the notches.
Unread 12-26-2014, 08:57 AM   #10
joe_jeep
cool. I pulled the grill last year to have it re-painted.
Those weird rubber insulated fasteners holding the rad on were a PITA!!!
had to replace them. Unless I need a rad it aint coming off again if i can help it.
I have the inline style like jerry showed on my buggy from the aw4 swap.
It seems to work good. The one I bought is huge, and way overkill.
Its mounted in the wheel well area. Its almost as long as my hood front to back.
with no fenders it gets tons of airflow. Smaller would b better on the rubicon!
Is there an opinion on what style is more efficient? I would assume the flat style is with good airflow,
But thats just a guess.
glfwda #6624
Unread 12-26-2014, 09:55 AM   #11
JBTJ
Don't forget to install a quality external transmission filter. Cool and Clean ATF is the key to a happy long living transmission.
JBTJ is offline   Reply With Quote Quick reply to this message
Unread 12-26-2014, 02:34 PM   #12
Pine_Cat
Here's a picture of another possibility. A hanger like this will allow mounting of two B&M supercoolers side-by-side.
http://www.allthingsjeep.com/ort-5050.html
Sorry the picture is of a closeout, but it should be possible to find something like this out there, because a shop installed a dual-cooler set-up for me about six months ago.
My dual-cooler set-up on the hanger might have been a bit more labor-intensive, though, than was described above.
Pine_Cat is offline   Reply With Quote Quick reply to this message
