#1 | |
Trailer Wiring Harness?
I have a 97 TJ Sahara and would like to know what I need to do to connect my trailer lights to the Jeep? Is there a harness tucked away behind the bumper so I can connect the trailer harness directly? Is there a "Y" harness where I need to buy a harness, connect it to the "Y" and then to the trailer? Or do I need to buy a harness and splice it into the tail lights?
Thanks in advance, Joe
#2 |
Forget it- I got off my arse and did a search on the forum and found all the answers
#3 |
I just posted this question yesterday...and I have a 97 also...
97 Moss Green TJ GO WINGS!!! |
#4 |
The dealer can get this item, there is a change after 97, the one I got was under $24, with my dealer discount. Probbly 20% more to the public. Simple install less then ten minutes. The 97 item installs on the passenger side. Just loosen the fender liner and plug it in. Thread the pigtail through the rear crossmember and tie strap. HTH
#5 |
Agree with lostjohn....I bought the kit for my 2004 from the dealer for about $32 and it fit perfectly....completed the install in less that 15mins.
JB |
#6 |
I had mine installed at a trailer hitch store for $20, that's including the harness.
How ironic lostjohn............. I'm lostskiier but my name is Jon |
#7 |
Advance Auto Parts, $15 no cutting, no splicing.
http://www.partsamerica.com/ProductDetail.aspx?mfrcode=HOP&mfrpartnumber=42615 &parttype=874&ptset=A if that link fails- try searching Hoppy part number 42615 or similar for your year model. the 42615 is for an 04 Unlimited. |
#8 |
anyone know if ^^^^^ part number will work on an 05? I called Advance Auto and they said Hoppy dosen't show a part number for an 05.
2006 [COLOR=Yellow]Solar YELLOW[/COLOR] UNLIMITED-6-Speed -Rusty's 2" spring kit w/Skyjacker Hydro 7000 shocks, 1" coil spacers up front and 3/4" coil spacers in rear, 32" BFG AT KO's on Ravines -Spidertrax 1.25" wheel spacers, Clear Turn Signals and Markers, Custom Front Bumper Hoop with upgraded hooks, Delta 50 Flowmaster, Code Alarm CA-670 Paging-Alarm with Motion Detector, K&N FIPK, JKS Discos, Procomp LCAs, Airaid TBS, Tuffy 055 rear section sub console, 4-Hella 500's, Fumoto Oil Drain Valve, Olympic Reverse-a-bars, Delta Headlight kit with black bezels, Edge Trail Jammer kit, Smittybilt Classic Tire Carrier, WARN Oil Skid, Skid Row steering skid, JKS adj. rear track bar, RC front adj. track bar. |
#9 | |
I bought that part labeled for 04 and it works on my 05. I figured there catalog just wasn't upated yet. Although, I think I've got one light that doesn't work, but I assume that's a trailer issue. I can't imagine they changed anything from 04 to 05 on the lights wiring. Maybe somebody can confirm that with a wiring diagram. greg |
#10 |
Thanks for the info!!
#11 |
I paid 15 bucks for a no splice harness at Kragen Auto. it has 2 t connectors that snap into place behind the tailights
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
