Trail Jammer install/writeup and review - Page 5 - JeepForum.com
post #61 of 86 Old 04-04-2008, 10:34 AM
chandlerr
chandlerr's Avatar
Originally Posted by kittyhawk View Post
Who has the Best price on the kit? Intake, TB and Programer.
Thanks
Dave
the best price i can find right now online is around 600 (http://www.thoroughbreddiesel.com/ed...ail_jammer.htm), when I bought mine I found a place that had it listed for about 500 and I printed out their website and brought it to 4wheelparts where they honored the price match and so I got it all for about 500.
2004 Black Rocky Mountain Edition, Clayton 4 Linked w/ 4" Pro Comp Springs, 37" Iroks (lost to Mexico. RIP Krystal)
2006 Black LJ Rubicon, mostly stock with 33's... soon to change
chandlerr is offline
post #62 of 86 Old 04-04-2008, 10:56 AM
ThUmPeRcOn
Anyone put a throttle body spacer like "air raid' under it? Or would it not be advised?
The original point and click interface was a Smith & Wesson.
ThUmPeRcOn is offline
post #63 of 86 Old 04-04-2008, 11:00 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Don't believe the ads. For the type of throttle body the TJ uses, a TB spacer won't do a thing. Spacers can really help underneath carburtetors and perhaps under throttle-body injection type systems, which our TJ does not use of course, but they don't help with our kind of throttle body. Only air passes through our throttle body, no fuel at all... so all you're doing is creating a longer air path which doesn't help in the least.
Getting
Jerry Bransford is offline
post #64 of 86 Old 04-04-2008, 11:05 AM
ThUmPeRcOn
Thanks, just curious I have other mods to complete. I would like to see some actual dyno results before making a purchase like this if anyone has access, and time?
post #65 of 86 Old 04-04-2008, 08:33 PM
Heavysausage
Here you go http://www.rockcrawler.com/techrepor...r_tj/index.asp
But i have a fast ???? for everyone how do i know if my jeep is a early or a late 1997 model. Please tell so i can know if i can use this kit or not Thanks.
Heavysausage is offline
post #66 of 86 Old 04-04-2008, 08:44 PM
ThUmPeRcOn
Hmmmm Thank you! But I still have other mods to complete first Although it will be fun watching you guys play with this for awhile Thanks for sharing!
post #67 of 86 Old 04-05-2008, 05:12 PM
Postal
Well, I should know Tuesday evening. Just placed my order yesterday at 4wdparts.
No dyno in my area ( I dont think ) but will see if I can do some vids of 0-60 and maybe some idle and exhaust shots just for before-and-afters.
I'll do a seperate thread to add as a product review and link to it here.
Suspension/Axle: 2"BL/2"SL:4.88 gears:D30/D44
Wheel/Tire: 15x8 American Racing Mojaves :35x12.5 BFGs
Armor: Rockcrusher bumpers and rocker guards
Int: Husky liners & Neoprene Front & Rear
Recovery: Warn 9000ti
Next: Discos : D-rings F/R: Audio : CB : Offroad lighting
Postal is offline
post #68 of 86 Old 04-14-2008, 10:51 PM
Kencary
Do the latest Edge TB's still have the whistling noise issue or has that been fixed?
Kencary is offline
post #69 of 86 Old 04-15-2008, 08:35 AM Thread Starter
barry1me
barry1me's Avatar
Im used to my TB, kinda sounds like a supercharger!
Sport TJ build
everything below has a hyperlink to the install/review
Before you ask about a product in the Technical forums check out the product review section!
barry1me is offline
post #70 of 86 Old 04-15-2008, 10:05 PM
Rocky5
Rocky5's Avatar
me too and mine does too!
2006 Solar YELLOW UNLIMITED-6-Speed
-Rusty's 2" spring kit w/Skyjacker Hydro 7000 shocks, 1" coil spacers up front and 3/4" coil spacers in rear, 32" BFG AT KO's on Ravines
-Spidertrax 1.25" wheel spacers, Clear Turn Signals and Markers, Custom Front Bumper Hoop with upgraded hooks, Delta 50 Flowmaster, Code Alarm CA-670 Paging-Alarm with Motion Detector, K&N FIPK, JKS Discos, Procomp LCAs, Airaid TBS, Tuffy 055 rear section sub console, 4-Hella 500's, Fumoto Oil Drain Valve, Olympic Reverse-a-bars, Delta Headlight kit with black bezels, Edge Trail Jammer kit, Smittybilt Classic Tire Carrier, WARN Oil Skid, Skid Row steering skid, JKS adj. rear track bar, RC front adj. track bar.
Rocky5 is offline
post #71 of 86 Old 04-17-2008, 04:27 PM
Postal
Well, I picked mine up from 4wdparts and didn't wait to get back home to install it. There is no whistle on mine so it seems that Edge has taken care of that.
Install was straight forward, though I skipped the part where I am supposed to use the new hex bolts Edge supplied to fasten connections up to the new throttle body. I put everything on with the OEM bolts and then realized my mistake when one of the OEMs was TOO long to screw in all the way. Due to the wider bore the wall is thinner and thus the OEM bolts are too long to use.
When I first turned the engine over it sounded like a little jet sitting under my hood. The cold air intake allows alot of the throttle body sound to pass through it.
I pulled out of the parking lot and IMMEDIATELY found that I had to pretty much STAND on the brake pedal to keep from moving forward at the stop light. It idled at about 1100RPM but felt like I was toeing the line waiting for the tree lights to turn green and go for a hole shot!
I jumped on it a little bit and the jet engine sound faded away as the plenum opened up more. I definitely had more throttle response and went through the gears a little quicker.
I do, however, feel that I have lost a little power between 55-70mph.
Overall I don't feel ripped off for the money I paid since this will be only the first step in the whole beginning to end exhaust overhaul.
Next is headers and Magnaflow exhaust.
Postal is offline
post #72 of 86 Old 04-18-2008, 05:02 AM
Border Dave
Got Sand?
Border Dave's Avatar
Why does your Jeep idle at 1100 rpms? That's a lot higher than it should be, isn't it?
My favorite shops in the Northwest:
Border Dave is offline
post #73 of 86 Old 04-18-2008, 06:22 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
about 400 too high
did you install the computer with the kit? you shouldn't have any lul in power with all that
My builds:
and
or follow us on
spyder6 is offline
post #74 of 86 Old 04-18-2008, 08:31 AM Thread Starter
barry1me
barry1me's Avatar
Originally Posted by spyder6 View Post
about 400 too high
yeah something doesnt sound like its hooked up correctly.
Sport TJ build
barry1me is offline
post #75 of 86 Old 04-18-2008, 05:30 PM
Postal
Sorry, I should have updated that. The throttle cable may have stuck or something, it idles at 700 or so now, much better.
Still, I wonder about the loss at the higher MPHs.
I may unplug the module and run with the cai and the throttle body to see what I get.
Postal is offline
Edge Trail Jammer? scanderw TJ Wrangler Technical Forum 27 01-03-2011 03:51 PM
trail jammer coryweng TJ Wrangler Technical Forum 3 10-26-2009 12:01 PM
My writeup and review of LJLunatic's sliders tjthorson TJ Wrangler Technical Forum 0 05-30-2008 05:57 PM
? for those who have the Trail Jammer BlkBird TJ Wrangler Technical Forum 4 11-17-2007 09:05 AM
Edge Trail Jammer bd1 TJ Wrangler Technical Forum 1 02-15-2007 10:24 AM
