Trackbar, sye, and tt? - Page 3 - JeepForum.com
post #31 of 34 Old 10-24-2013, 10:02 PM
mudb8
want it rite or rite now?
mudb8's Avatar
Explain to me the effect on handeling from neglecting to raise the track bar bracket...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #32 of 34 Old 10-24-2013, 10:02 PM
cloakedwillys
Vendor
cloakedwillys's Avatar
1952
I did miss the post confirming that he has 3.25" coils.
sent from phone
MetalCloak, It's Your Jeep, Only Better
Will (916)631-8071
facebook.com/metalcloak
cloakedwillys is offline
post #33 of 34 Old 10-24-2013, 10:07 PM
cloakedwillys
Vendor
1952
The track bar that we currently sell was designed for maximum clearance. You do get more side to side swing because of this. For most people it is fine for the added clearance.
We are working on a new track bar kit that will have a different track bar and a raised mount to raise the roll center and promote better handling. It will require more bump stops to prevent the bracket from contacting the floor.
sent from phone
Will (916)631-8071
post #34 of 34 Old 10-25-2013, 12:25 AM
mudb8
mudb8's Avatar
Stock rear coil
2.5" rancho 4cyl soft top rear coil.
1.25" bumpstop extension.
33" tire with a bit of trimming.
Throw in a coil spacer on a stock spring or a lift spring, theres room for trackbar relocation whether you want it or not.
What is the collapsed length of the mc 3.5" progressive coil? I love the advertised extended length of the mc springs.
mudb8 is offline
