Trackbar for Rubicon - JeepForum.com
post #1 of 12 Old 06-18-2010, 06:30 PM Thread Starter
mpd2434
2014 JK Wrangler
OK I've read just about every post and review about track bar brackets but i'm no closer to buying one now then before. I'm running an OME 2.5" lift with front 1.5" spacer and a 1.25" body lift. What track bar will work with my minimal amount of lift and not hit my front Dana 44? I was looking at the Currie HD recommended by Jerry but will that work with the Dana 44?
mpd2434 is offline
post #2 of 12 Old 06-18-2010, 06:33 PM
VanBCguy
Use the link in my signature to click open Savvy's website. Call Gerald. He'll know (and if by off chance he doesn't, Blaine will). Or PM him the question. His username's Savvy here on the forum.
Either way, you've made a wise decision going with a Currie track bar vs. any other brand.
VanBCguy is offline
post #3 of 12 Old 06-18-2010, 08:30 PM Thread Starter
mpd2434
2014 JK Wrangler
Ok thanks for the help
mpd2434 is offline
post #4 of 12 Old 06-18-2010, 08:39 PM
_N8_
I run the Currie CE-9120TJS on my Rubicon w/ 4" lift & it's not hitting my D44's ARB diff cover.
| 03 TJ Rubi | Stock locked D44's | OME 4" springs | RE Super-Flex arms | 1.25" BL | 35" MTZ's on Rock Crawlers | Currie HD tracbar | Custom engine/tranny skid | Skid Row steering box skid | Pro-Comp front bumper | TG rear tire carrier bumper | 8,000lb CE winch | Hard & soft tops | Full & half doors |
_N8_ is offline
post #5 of 12 Old 06-18-2010, 09:49 PM
vector6
i really like my Clayton..
vector6 is offline
post #6 of 12 Old 06-18-2010, 10:23 PM
mudb8
want it rite or rite now?
mudb8's Avatar
the currie will need 2" bumpstop extension to clear, the clayton,..... even more to clear the tie rod.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #7 of 12 Old 06-18-2010, 10:28 PM Thread Starter
mpd2434
2014 JK Wrangler
This is what I mean, it's so confusing as to what will work and what won't or what else you have to install to make them work.
mpd2434 is offline
post #8 of 12 Old 06-18-2010, 10:44 PM
mudb8
mudb8's Avatar
Lets put it this way.... if you have 33" tires without a BL, or 15.5" collapsed length shocks, or both, you need 2" bumpstop extensions anyhow, which means it and a few other aftermarket track bars will work using a stock diff cover.
less collapsed shock length than 15.5" require less bumpstop extension, so if you use more extension than you need you loose articulation and an adjustable track bar will hit your diff cover.
mudb8 is offline
post #9 of 12 Old 06-18-2010, 11:11 PM Thread Starter
mpd2434
2014 JK Wrangler
OK well I have 33's with 2.5 OME susp. lift, 1.25" body lift, and 1" MML. The shocks were the stock OME's that came with the springs. Is this setup Ok for these trackbars? I'm new to this so please bear with me.
mpd2434 is offline
post #10 of 12 Old 06-19-2010, 11:04 PM
mudb8
mudb8's Avatar
N66 or N66L up front?
N67 or N67L out back?
mudb8 is offline
post #11 of 12 Old 06-20-2010, 06:18 AM Thread Starter
mpd2434
2014 JK Wrangler
I have N66L's and N67L's. What do you think of the Bomb Proof Track Bar and Bracket from Rock Krawler? It looks pretty HD. I'm going to order my Track Bar on Monday and with all the negative posts about them hitting the Diff.
(especially with the Dana 44) and overall poor reviews of different brands, it makes it extremely hard to choose one for my setup. Oh by the way in my previous post I forgot to mention I also have a 1.5" coil spacers on the front springs. Thanks
mpd2434 is offline
post #12 of 12 Old 06-21-2010, 09:48 PM
mudb8
mudb8's Avatar
the n66L's up front must have at least 2" bumpstop extension to keep the shock from bottoming out. the n67L I can't exactly tell you due to the changes pinion angle shock relocators and BPE's can create, I can say tho the rears will need around 3+" of extension.
mudb8 is offline
track bar , rubicon
Front trackbar relocation by drill and rear trackbar relocation bracket install? loudog3114 TJ Wrangler Technical Forum 20 10-26-2014 08:01 PM
what if there is no trackbar? MC_NickP TJ Wrangler Technical Forum 11 12-30-2009 11:20 PM
Will I need a trackbar relocation bracket with rear adjustable trackbar FLATFENDER54 TJ Wrangler Technical Forum 3 02-05-2009 04:35 PM
Rubicon Express rear trackbar or JKS rear trackbar? acelesson TJ Wrangler Technical Forum 9 01-26-2005 11:26 PM
SOA.... trackbar? LOCKED UP YJ Wrangler Technical Forum 10 01-01-2004 10:49 PM
