Track bar and drag link length - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Track bar and drag link length
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFord Explorer 8.8 4340 Chromoly Axle Shaft Kit C Clip ElimFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 05-22-2014, 06:49 AM   #1
DBLJ
DBLJ's Avatar
Do they have to be the exact length or can they be off a bit. I'm finally getting around to fixing my steering issues and this is at the top of the list. I'm using a Clayton trackbar and currie steering. No drop brackets or drop pitman arm.
Buy my transmission cooler. Derale TJ cooler.
http://www.jeepforum.com/forum/f126/...0561-a-2936825
DBLJ is offline   Reply With Quote Quick reply to this message
Unread 05-22-2014, 09:01 AM   #2
mike_dippert
hodophobic
mike_dippert's Avatar
Are you using the stock mounting locations?
Is your axle centered?
Is your steering centered and properly aligned?
If you answered yes to all three then you're ok.
mike_dippert is offline   Reply With Quote Quick reply to this message
Unread 05-22-2014, 09:40 AM   #3
DBLJ
DBLJ's Avatar
Originally Posted by mike_dippert
Are you using the stock mounting locations? Is your axle centered? Is your steering centered and properly aligned? If you answered yes to all three then you're ok.
Yes I'm using stock mounts. Eyeballing the axle, it is centered. I'll need to plumb bob it to be 100%. Steering is aligned, the wheel is off center. Supposedly the adjuster is stripped says the tire monkey.
I was out measuring last night and there is a 5" difference in length.
Unread 05-22-2014, 10:06 AM   #4
rda616
5" sounds right to me. They need to rotate on the same axis.
rda616 is offline   Reply With Quote Quick reply to this message
Unread 05-22-2014, 10:40 AM   #5
mike_dippert
hodophobic
5" seems like too much, but I've never actually measured mine. I know there is a little difference, you can see that just by looking at the mounting points. I'll try to measure mine tonight if nobody else chimes in.
Unread 05-22-2014, 02:01 PM   #6
DBLJ
DBLJ's Avatar
Thank you. Everything I have been reading says that they both need to be very close to the same length.
Unread 05-22-2014, 03:44 PM   #7
rda616
They need to work on the same axis. Length is moot if they are indeed following the same ark.
Unread 05-22-2014, 06:25 PM   #8
Matt L
Trackbar 31.5 draglink 36.5
Matt L is offline   Reply With Quote Quick reply to this message
Unread 05-23-2014, 05:09 AM   #9
DBLJ
DBLJ's Avatar
And how is the steering? No issues?
