Track bar delete - Page 2 - JeepForum.com
post #16 of 28 Old 09-01-2010, 07:27 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
So how do you guys with triangulated uppers remedy your exhaust issues?
I have the Rock Krawler upper triangulated arms and they work with the stock exhaust.
They have a bend in the arms to clear the exhaust.
I do not think this is the best solution though. I'd rather have straight arms and work the exhaust around them.
Wheelin98TJ is offline
post #17 of 28 Old 09-01-2010, 09:14 AM
tjdriver
i always wondered if i could add the rk upper triangulated arms to my crapper lift since my lift basically used drop brackets on the uppers.
tjdriver is offline
post #18 of 28 Old 09-01-2010, 09:22 AM
Wheelin98TJ
JEEP FREAK
You could add the RK arms, but I would ditch the drop brackets.
The RK kit comes with bracket reinforcements for the stock upper brackets on the frame.
post #19 of 28 Old 09-01-2010, 09:26 AM
tjdriver
my main concern with using the rk kit was the diff in height from your lift to mine.
do they use the same kit in their taller lifts?
tjdriver is offline
post #20 of 28 Old 09-01-2010, 09:33 AM
dcope17
I got the Poly Performance 4 link rear. Not installed yet though. But compared to the RK kit, Theirs are straight with a JJ at both ends, and its tubing, not solid, ( so lighter ) Then you weld the threaded bungs in place so you can make the arms whatever length you want.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #21 of 28 Old 09-01-2010, 09:38 AM
tjdriver
that pp kit is over a g isn't it?
tjdriver is offline
post #22 of 28 Old 09-01-2010, 09:42 AM
Boodyrider
Um. Your point?
Yes, the good stuff costs.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #23 of 28 Old 09-01-2010, 09:44 AM
tjdriver
you buying? lol. i'm going to look at both. i'd really like to spring for a stretch kit but that isn't in the budget.
tjdriver is offline
post #24 of 28 Old 09-01-2010, 11:05 AM
Apex
Recon death squad
Apex's Avatar
Then wheel what ya got while you save up for the good stuff.
Why skimp?
Apex is offline
post #25 of 28 Old 09-01-2010, 12:03 PM
tjdriver
so what we need no is no holds barred comparison of the rk kit and poly kit.
i have no doubt the poly kit will win.
tjdriver is offline
post #26 of 28 Old 09-01-2010, 12:39 PM
dcope17
yes, but wait for a 10% off sale... ( which they were having when I bought it )
The complete RK kit is $2800. Only thing it includes is springs over the PP front and rear kit.
dcope17 is offline
post #27 of 28 Old 09-01-2010, 01:24 PM
Wheelin98TJ
JEEP FREAK
That could be a difficult comparison to do.
What criteria would you use to determine the winner?
post #28 of 28 Old 09-02-2010, 06:12 AM
tjdriver
sheesh, i was just kidding.
tjdriver is offline
exhaust , link , suspension , track bar , triangulated
4.0 cat delete kit??? help! 01blackout TJ Wrangler Technical Forum 28 02-06-2010 08:14 AM
'92 2.5L AC Delete? jmurds YJ Wrangler Technical Forum 10 02-05-2010 05:33 PM
I need an AC delete for 4.2 motorman YJ Wrangler Technical Forum 7 01-28-2010 02:17 PM
