Track Bar adjustment - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Track Bar adjustment
Rough Country Lift Kits and Parts!Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off Road
Unread 07-02-2010, 06:08 PM   #1
Spotszilla
I've read the different alignment threads and haven't found anything about the best way to adjust the track bar. Whats the best way to measure so the front and rear axle are properly aligned. Thanks
Spotszilla is offline   Reply With Quote
Unread 07-02-2010, 06:23 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Unbolt the track bar at one end and the Jeep will tend to self-center itself over the top of the axles. Jump up and down on the bumper a tad if you don't think it's quite centered which will probably finish the self-centering. The coil springs take care of that.
Once it is self-centered, just adjust the track bar length until its mounting bolt hole aligns with the mounting bracket hole and then insert the bolt. It doesn't have to be precisely centered... if it looks close to being centered, it is good enough.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote
Unread 07-02-2010, 06:23 PM   #3
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I measure from the frame to the wheel...
Knuckelhead is online now   Reply With Quote
Unread 07-02-2010, 07:21 PM   #4
Boston_Wheeler
For the rear, I used a square and measure from the outer frame rail to the inside of the rotor on each side and then used a ratchet strap to center the axle. Once centered, I adjusted the track bar and installed.
As for the front, I couldn't find a good way to get an exact measurement on both sides so I used Jerry's method from above. It worked great.
[URL="http://www.jeepforum.com/forum/f9/kc-driving-lights-rear-fog-lights-write-up-w-pics-1054319/"]My Aux Fuse Panel, KC Driving Lights and Rear Fog Lights write-up[/URL].
Boston_Wheeler is offline   Reply With Quote
Unread 03-16-2011, 08:58 AM   #5
wow682
I was wondering, I have the tires off the front and axle on jack stands. I had to check tightness on suspension due to death wobble. I found the track bar bad. Will the axle be uncentered now or am I good to install new t/b? I did have to move the wheel back and forth to get to bolts, but axle is in the same spot.....
SILVER JEEP MEMBER # 29,GREEN MOUNTAIN CRAWLER,MILITARY JEEPERS
wow682 is offline   Reply With Quote
Unread 03-16-2011, 11:50 AM   #6
mrjeep03
death wobble?
mrjeep03 is offline   Reply With Quote
Unread 03-16-2011, 01:15 PM   #7
Zombi
By removing the old TB the jeep will want to "self center" on its own.
To really make sure, you need to bounce the suspension. That allows the bushings to relax a little bit and go back to center.
Originally Posted by mrbates View Post
Zombi's are in fact very unpleasant to be around, they smell, and bite--also, they eat babies.
Zombi is offline   Reply With Quote
Unread 03-16-2011, 01:33 PM   #8
uf20wop
i assume you do this with the wheels off the ground?
uf20wop is offline   Reply With Quote
Unread 03-16-2011, 01:37 PM   #9
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Its much easier to install a track bar with the wheels on the ground.
Wheelin98TJ is offline   Reply With Quote
Unread 03-16-2011, 01:41 PM   #10
Imped
Imped's Avatar
Again, this isn't the case if bushings aren't present. Joints have misalignment so they don't "self center."
OlllllllO
Float Test Build
IndyORV
If you see a dead picture link of mine and would like it fixed, please PM me the link to the post and I'll fix it. Thanks
Imped is offline   Reply With Quote
Unread 03-16-2011, 02:07 PM   #11
Fropleyqk
Fropleyqk's Avatar
I agree that if its off a little it really doesnt matter. I dont think the bounce method will get you exactly centered.
As above, I measured from the frame to the wheel and used a ratchet strap.
Fropleyqk is offline   Reply With Quote
track bar , track bar adjustment , tj
