Quantcast Trac bars? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Trac bars?
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 09-28-2007, 08:19 AM   #1
archer75
Trac bars?
Is a new trac bar something you need with a 4" lift? I believe the lift kit itself came with trac bar brackets but still uses the stock track bars. Sometimes I do feel what I have read is bump steer. But it's not a huge deal. Are trac bars easy to install?
2004 Unlimited - Hard Top, 4" Fabtech lift
Currie HD Tie Rod/Ends/Drag link,
Black Diamond front and rear adjustable trac bars
Skyjacker Steering Stabilizer, 7" Rugged Ridge Fender Flares, 4x 5.25" Boston Acoustics S55, Skyjacker 7000 Hydro shocks
archer75 is offline   Reply With Quote
Old 09-28-2007, 08:54 AM   #2
brossie
Adjustable tracbars aren't going to eliminate bump-steer. To eliminate bump-steer, you need the drag-link and trac bar to the the same angle. Therefore, unless you are going to use a tracbar drop bracket(different from a relocation bracket), don't install the drop pitman arm because it will cause the drag link to be at a smaller angle than the tracbar. If you have the money to get adjustable tracbars to replace tracbar relocation brackets, do it. They keep the axle centered and are much more reliable than a relocation bracket, which is a good thing. They are extremely easy to install, 2 nuts, a bolt, a measuring tape, and two wrenches is all it takes to get the front tracbar installed and the axle centered.
'90 Grand Wagoneer 360, D44's, 727 tranny
Sold Unfortunately: '02 Sahara, Full Traction Tri-Link rear, TnT Customs Phantom Fenders, Custom bent cat-back Flowmaster 40, AA SYE, Tom Woods Shaft, Warn bumpers f/r, 4" rough country lift, 33" Mastercraft MT's, Tabor 9K winch, Hella fog lights, a bag full of tools for when it breaks.
brossie is offline   Reply With Quote
Old 09-28-2007, 01:25 PM   #3
archer75
I didn't lift the jeep myself, it was done by a previous owner. And I believe this is the kit he used:
http://www.4wheelparts.com/PDT52712.aspx
It has a pitman arm and trackbar brackets.
So what do you think I should do in this case? Just grab some adjustable track bars for front and back and call it good? I don't know if those brackets are drop brackets or relocation brackets.
I am taking it in to Les Schwab tomorrow to look at the breaks. I've also asked that they look over the lift and see if everything is ok. I can pass along some of this info for them to check.
Old 09-28-2007, 01:30 PM   #4
jeeptillidie
Take the drop pitman arm off and replace it with a stocker would be the first thing I would do. That will probably help the bumpsteer considerably. Then I would start thinking about the adjustable track bars and lower control arms since the picture of the kit looks like it came with uppers.
jeeptillidie is offline   Reply With Quote
Glock Forum
