Quantcast trac bars - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > trac bars
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 10-10-2004, 02:34 PM   #1
ltleskip8685
trac bars
Anyone have preferences on trac bars? Trying to decide and want to get a heavy duty one, thanks.
2003 TJ Sport
Skyjacker 2" BB w/ Hydro Shocks
33x12.50 BFG M/Ts
15x10 Black rockcrawlers w/Sim-lock
Rear Trailer Hitch
Skyjacker steering stabilizer
ltleskip8685 is offline   Reply With Quote
Old 10-10-2004, 02:40 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Currie, JKS, and Rubicon Express make the only three trackbars I would consider. For a lift that is less than around 4.5" to 5", I'd go with the Currie or JKS... and the Currie is made by JKS so they're identical to each other. I've had the Currie and it was great... I now have the R.E. because of the new RE suspension I just got installed. All three brands are highly recommended. The #1 brand I would not go with so far as a trackbar is concerned is Tera, they earned a reputation for bending.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 10-10-2004, 03:58 PM   #3
StealthTJ
The ones mentioned before (above) are fine, however with "only" a 2" BB, I wouldn't be worrying about a trackbar, at least not at that lift height.
If it were me, I'ld be replacing the steering (tie rod and drag link) with a heaver duty setup. The Currie HD Steering comes to mind
Fred
[b]Base[/b] - '98 Sahara, 4.0L 6 cyl, Auto (swap from 5 sp)
[b]Suspension[/b]- 4.0" Procomp Springs + 1 1/4" bl. Rear tri-link. Currie J arms, F&R. Warn hubs with WJ knuckles, custom cross over/hi-steering setup, Currie A/R Sway Bar.
HPD30/D44 (rear disk conversion, WJ dual piston caliber conversion in the front); Detroits; 4.56
[b]Misc[/b] - Tera 2wd lo.
[b]Tires[/b] - 35x12.50 MT/R's siped on 15x7 Champion Beadlocks.
[b]Recovery[/b] - Warn XD9000i
StealthTJ is offline   Reply With Quote
Old 10-10-2004, 07:27 PM   #4
ltleskip8685
I am in the process of getting a larger lift, most likely the RE 3.5" SF lift so that is why I was asking about a new trac bar. Thanks for your input.
2003 TJ Sport
33x12.50 BFG M/Ts
Rear Trailer Hitch
Old 10-10-2004, 09:08 PM   #5
CTMpwrdcamry
What about going with the Full Traction and eliminating it? Is it that big of an issue?
CTMpwrdcamry is offline   Reply With Quote
Old 10-10-2004, 09:15 PM   #6
igofshn
Locked @ both ends
igofshn's Avatar
They only eliminate the rear.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
[Jeep Pics
igofshn is offline   Reply With Quote
Old 10-10-2004, 09:19 PM   #7
wakeboarder 21
i have the RE one and it has held up to good amount of abuse, i just had to tighten it a good bit when i first got it but know it has stayed tighter
98 TJ
5spd,4banger
RE 3.5 __ 1" BL__RE front adj. trac bar__Currie Anti Rock sway bar__33 BFG M/T with some black steelies__K&N Filter__CB___ Durango 4x4 Front Bumper
building for 37s
[URL=http://orw.truckmoxie.com/mygallery.ten?id=4573]***PICS***[/URL]
wakeboarder 21 is offline   Reply With Quote
Old 10-10-2004, 09:27 PM   #8
CTMpwrdcamry
I know, but are they that big of an issue that they should be eliminated?
Old 10-10-2004, 09:37 PM   #9
StealthTJ
The rear, yes...
A lifted Jeep rides so much better with triangulated rear uppers and no rear track bar......
Fred
Old 10-10-2004, 10:21 PM   #10
CTMpwrdcamry
Originally Posted by StealthTJ
The rear, yes...
Fred
Where did you get yours? That is the only piece that makes me want FT over RE.
Sean
Old 10-10-2004, 10:34 PM   #11
StealthTJ
Sean
I use the RK rear tri-link (only the tri-link portion), with the optional weld on cradle.
I run the Currie J-Arms for the lowers, with outboarded rear shocks.
[EDIT]: BTW, I suppose that you could run the RK rear tri-link with the RE LA. Just use the weld on cradle.
Fred
Old 10-10-2004, 10:52 PM   #12
CTMpwrdcamry
Fred
Well i am thinking, now, that the RE 4.5 lift with 3.5 springs, the RK Tri-link and upgrade to the long arm later. Just thinking though. Opinions?
sean
Old 10-10-2004, 10:56 PM   #13
StealthTJ
sean
Let me ask the same question that I ask often
Let's go back to some basics, what'cha need the 3.5" lift for ?
Fred
Old 10-10-2004, 10:59 PM   #14
CTMpwrdcamry
Fred
I’m just talking to you in both threads. If you have AIM im me at CTMpwrdcamry.
If not, why not just consolidate and talk in one thread.
Now back to your regular scheduled postings
Glock Forum
