TPS Sensor - JeepForum.com
post #1 of 8 Old 08-19-2013, 12:53 PM Thread Starter
pwatson74
TPS Sensor
So I just replaced the TPS sensor on my 97 Wrangler SE and had the check engine light reset. About 2 days later the check engine light came on again and when I checked it again it was for the TPS sensor. I did double check to make sure that the sensor was correct for my jeepers.
Any thoughts on why it keeps faulting?
pwatson74 is offline
post #2 of 8 Old 08-19-2013, 01:07 PM
AdamLC
I had a TPS issue once where it said i had low voltage I had bad luck with the Borge Warner TPS it made me have erratic idle and high idle. I disconnected battery and touched the terminals together like suggested to clear pcm capacitor so it would relearn still no luck. Ended up going back to my original and its fine. May try battery cable trick. If no luck there I would go with Mopar part. Ive hear of a lot of problems with parts store house brand TPS.
AdamLC is offline
post #3 of 8 Old 08-19-2013, 02:26 PM
samiam_va
Battery healthy? I have had problems with ECU and poor battery charge.
samiam_va is offline
post #4 of 8 Old 08-19-2013, 02:29 PM
bcash616
I had a bad ground that causes some issues.....
bcash616 is offline
post #5 of 8 Old 08-20-2013, 05:58 AM
wesboy
I've been through 4 TPS on my 97 recently.
Original TPS stopped working so replaced it with an after-market TPS - worked OK for a short time, then crapped out.
Replaced with another after-market TPS (Crown). Same deal - worked OK for a while, then crapped out.
Then replaced with a genuine Mopar TPS 6 months ago - haven't had any problems since.
97 TJ Sport 4.0L Auto RHD
wesboy is offline
post #6 of 8 Old 08-20-2013, 11:18 AM
chadridesabike
Try disconnecting the positive terminal, then shorting the wire to ground. This will reset the ECU. I had a similar issue when I replaced my TPS, and this replaced it.
chadridesabike is offline
post #7 of 8 Old 08-20-2013, 07:43 PM
Sudcalifornio
check battery terminal i had the same problems changing the tps, dont get stuff from autozone ur gonna ended up buying more often. try to get the original
Sudcalifornio is offline
post #8 of 8 Old 08-20-2013, 09:48 PM
GilaMtnJeep
GilaMtnJeep's Avatar
If you're going to buy aftermarket sensors the ONLY ones that are as good as the Mopar sensors are sold by NAPA. The Echelin brand is good quality. I bought my TPS from them over a year ago and had zero problems after replacing mine.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
