TPS reads 13.7 with my foot off the gas... - JeepForum.com
post #1 of 6 Old 08-24-2010, 10:19 PM Thread Starter
MattJeep
2003 WJ
So I plug in my code reader today just for the hell of it, and was reading the sensor numbers and the tps was at 13.7. Thats with nothing touching the gas pedal. When I floor it, it only goes to 80. Now every other vehicle I have (Chevy trucks) are at 0 and go to 100 when floored. I tried to loosen the screws to adjust the sensor a little, but really couldn't get the screws to move much. I didn't wanna break it and decided it would be better to remove the TB and take it off if I have to. So what do you think, I'm I only running at 80% power when I'm flooring it?
MattJeep is offline
post #2 of 6 Old 08-25-2010, 02:56 PM
Jonny Jeep
Jonny Jeep's Avatar
Normal. Mine goes from 14 to 76. Anything similar is fine.
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline
post #3 of 6 Old 08-26-2010, 04:15 AM
sportcoupe
Yup, normal...
sportcoupe is offline
post #4 of 6 Old 08-26-2010, 05:46 AM
knightwolf654
mine sits at 16.4 at idle?
knightwolf654 is offline
post #5 of 6 Old 08-26-2010, 06:33 AM Thread Starter
MattJeep
2003 WJ
ok thanks guys. Good thing I didn't go through the trouble of removing it.
MattJeep is offline
post #6 of 6 Old 08-26-2010, 02:18 PM
Jonny Jeep
Jonny Jeep's Avatar
Fine too.
tps , tj , wrangler , idle
Odometer reads '88888..' ? tommaho TJ Wrangler Technical Forum 42 02-24-2015 09:53 AM
a/c charge on DIY kit reads in the red/danger jclaudii TJ Wrangler Technical Forum 3 08-02-2008 10:42 PM
Which JK connector for error reads? BWR JK Wrangler Technical Forum 4 02-27-2008 01:29 AM
Oil Pressure reads ZERO. SEZARO21 YJ Wrangler Technical Forum 8 07-31-2007 04:20 PM
gas gauge reads low shadows_lair TJ Wrangler Technical Forum 3 01-20-2005 10:50 PM
