Towing Shopping list...Please Help.
| RUBICON EXPRESS Lift Kits and Accessories Available at Bas | Spartan Lockers FREE SHIPPING Excellent Prices | Free Shipping on TIRES at KrawlOff-Road |
#1 | |
I would like to pull my New ATV to local and distant places to ride. What do I need?
So many choices on Quadratec for hitch and all I haven't picked up a trailer yet but will based on y'all options. What class do I need? Whats a good priced hitch cost? My Quad is 500lbs and about 6 and half feet long.
2006 Rubicon Unlimited Khaki: AUTO, 4:11 D44/D44, REBB /w Mono tubes, Rancho front stabilizer, 31 x 9.5 LT245/75R16 MTRs, Stock 16in Moab Wheels, Olympic Reverse-A-Bars,KC Daylighters on windshield brackets, Garmin Nuvi GPS, Pioneer Sound, 3A fire extinguisher, Line-X interior... www.stevensinger.org <-- Photography website Hello, my name is Steve and I am a Jeepaholic. LJ Owners Member 155 Rubicon Owners Member 123 New Jersey Jeepers Member 44 |
#2 |
Class 1 hitch <= 2000 lbs
Class 2 hitch <= 3500 lbs Class 3 hitch <= 5000 lbs. Class 2 or 3 is your best, but you won't be pulling 5k lbs with a TJ. Class 2 or 3 hitch with 2 inch reciever is what you want. A quad on a light duty trailer will ride fine behind your tj. Just keep in mind that once to get to around 2k and beyond with a TJ you really pushing it. Poor brakes and SWB make for a very poor tow rig. It is very easy to just load up a trailer and take off without thinking about weight. |
#3 |
towing
A hitch for only pulling 500 lbs cant be much, you usually over rate the hich, so instead of buying a hitch for 500, buy one with a greater load capacity, also the tounge weight comes into play, the downforce on the tounge, if the trailer weight is centered, it only causes a little weight on the tounge.
Now if you have an auto trans. you need to think about a trans cooler, you can get away without one, but the trans will last longer with one, in fact the cooler the trans runs the better, I plowed snow with a YJ for 8 years, I had a trans cooler and never ever had a trans problem, so consider a cooler if you have an automatic. you will also need a trailer light plug, I hear Napa has a plug and play, system or you can just get a pair of trailer wires( check the trailer you are going to buy to see what type plug is on it before buying a plug set up. After that all you need do is change your rear end grease if you are going to be towing if not you will burn up the bearings,(cheap insurance) chrysler recomends 140w for towing, get synthetic lube, it keeps cooler....I'm sure someone else has some ideas for you, this is all I can think of now, good luck with you project ![]() |
#4 |
Thanks, I have an 2006 Unlimited Rubicon, Only have 20k Miles on her, What brand is a good Hitch? Also I was thinking of these
Receiver Hitches Hidden Hitch Round Tube Class III Trailer Hitch for 97-06 Jeep Wrangler TJ & Unlimited 2" Receiver Tow Hook in Black What do yall think?
#5 | |
My existing receiver is tucked in under the factory bumper as tight as it can be but it still hangs too low. It screws up your departure angle AND it looks like crap. Just my .02! |
#6 |
Consider an integrated bumper/hitch, rather than a hitch that hangs down. It'll preserve your clearance. Keep in mind that most of them are not technically tow-rated. The Olympic is:
http://www.quadratec.com/products/12008_2X_A_PG.htm ![]()
Blue Jeep Club Member #197 '02 TJ - 31" BFG AT's, some armor, yadda yadda. 2" BDS lift. '94 ZJ - May it rest in pieces. |
#7 |
I've got an 06 Unlimited Rubicon and I am NOT a hardcore offroader. I've got a Hidden Hitch like the one you pictured. I've dragged it in the dirt a couple of times but only knew it because it was dirty. It's a good setup. My hitch is a Class IV which is what I have always purchased over the years including a YJ and another TJ that I still have.
You will never have to worry about the hitch. Period. I'm not comfortable with the hitch integrated bumper. I haven't had a bumper hitch since the 60's and I'll sure as help not use one to tow now. I pull a 4,000 pound boat with mine and have no problem. Legally I'm overloaded, but if you drive with some sense you won't have a problem with your ATV.
2007 Patriot Limited 2006 Unlimited Rubicon 2006 Commander 2000 TJ Sport My previous Jeeps 1992 Wrangler S (Ole Yeller) 1985 Cherokee Pioneer 1989 Cherokee Laredo 1995 Cherokee Country 1996 Cherokee Country 1996 Grand Cherokee Laredo |
#8 | |
I have had this bumper/hitch for a couple of years and highly recommend it. Looks cleaner, doesn't cost mucho buko, and as stated will preserve your clearance. No problems towing my bass boat (approx 800 lbs), or on occasion my motorcycle on a trailer. ![]() ![]()
1997 Sport - R.E. 2" BB - 31" BFG MT's on ProComp 1069's - complete Borla exhaust - Optima yellow top - A to Z sliders - Olympic rear bumper - Alpine CD/MP3 - Tuffy door locks - Meyer Snowplow My TJ at cardomain |
#9 |
Great, thanks for the pictures, What 8k lbs boat you pulling?
#10 | |
#11 | |
#12 |
Thanks sorry i did misread, you did say 800lbs so can i see some pictures of that boat?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
