Quantcast Towing my Jeep, I turn right, it turns left! - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Towing my Jeep, I turn right, it turns left!
Old 05-09-2007, 11:23 PM   #31
RockRunner85
Originally Posted by jeeplj
I have resolved myself to the fact that 6" of lift has altered the geometry enough to cause this problem. I have felt all along that there is a problem with the caster. But after taking it in for an alignment, you would assume that the caster is OK. Apparently not. If I am reading the printout from the shop correctly, it states that the caster should be between 6.0 and 8.0 degrees. Mine is -1.2 on the left and -1.0 on the right. Camber should be between -0.9 and 0.4. Mine is at -1.1 on both sides. The printout also talks about "cross caster" and "cross camber." I have no idea what that means but it shows that I am within the specified range. The steering wheel does return to center, but the sharper the turn, the less eager it is to re-center.
How does that thing even drive down the road without wandering all over. You need to fix your caster. Shorten the front uppers, lengthen the lowers, or do a combination. Make sure you watch for clearance with the steering components on the front. Check the pinion angle as well.
What I would do is buy a magnetic angle finder if you do not have one already. Position it on the axle diff housing parallel with the driveshaft or perpendicular to the axle shafts. Read the degree and compare it to the measurement from your alignment. Using the difference you can adjust your control arms and determine your caster. Shoot for the 5 range.
Cross caster is the difference between the pass and driver caster measurements. You need this to compensate for the crown in the road. It is set by the way the axle brackets are welded on. If you make the control arms identical in length you will be set.
Camber is not going to be adjustable without offset balljoints and it is probably correct anyway as there is some margin of error with how the alignment sensors are clamped on the wheels.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
The Reptile File
A discussion forum on geckos, lizards, snakes, and other reptiles.
RockRunner85 is offline   Reply With Quote
Old 05-10-2007, 10:59 AM   #32
Older Fossil
I agree! With your caster going into the negative range, the front end could be having problems tracking straight. See if you can get your caster closer to +4. But watch for front DS vibes. If you get vibes, back off the caster until they are totally gone. With a lifted Jeep, caster and DS pinion angle are a compromise.
Art
'01 TJ
RE 3.5" Springs, JKS UCAs & LCAs, JKS front and rear adjustable trackbars, OME shocks, JKS Quicker Discos, AA SYE and TW CV driveshaft, KOZ Offroad rear bumper & swingaway carrier, D30 front w/ Detroit TrueTrac, D44 rear w/ Detroit TrueTrac, AR Baja rims, Goodyear 33x12.5 MT/Rs.
Older Fossil is offline   Reply With Quote
Old 05-10-2007, 11:25 AM   #33
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Yep you've got a caster issue. But though the factory specified caster range is 6 to 8 degrees, 7 being optimal, don't try to get the caster angle all the way back up to that with your suspension lift. Doing so would likely cause front driveshaft vibrations. Your caster goal should be 4.5 to 5.5 degrees with 5 to 5.5 being pretty optimal for your lift height and tire size.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 05-11-2007, 01:04 AM   #34
jeeplj
Spent some time on the phone with the shop today and discussed the caster. I'll probably get some offset ball joints. That, along with rotating the axle should get me where I need to be without the driveline vibes. The good news is that the shop said they would cover the labor on the ball joints and realignment so I'll probably take them up on that. As I said several posts ago, I am also considering switching to manual hubs. If I do that, then I would only have to live with driveline vibes when I'm off-road, which would be tolerable.
Thanks to everyone who posted. I think we can end this one now.
-Wes
jeeplj is offline   Reply With Quote
Old 05-11-2007, 01:08 AM   #35
Jerry Bransford
Why? While those would have a very minor effect on caster angle, they are primarily meant to adjust the camber angle. While your camber angle is very slightly out of spec, it is your caster that is the primary problem.
Getting Savvy...
Old 05-12-2007, 04:18 PM   #36
jeeplj
They told me they could get 2 - 3 degrees of caster change with them. Is that not true?
Old 05-12-2007, 04:30 PM   #37
RockRunner85
You don't need offset ball joints. Thats going to effect camber. You need to change caster which is the rotation of the axle. All it takes is adjusting your control arms.
Like I said before since you know the caster you have know you can easily use an angle finder and adjust this yourself.
With only adjusting the control arms you can get your caster into the accpetable range. I wouldn't go buying balljoints when you don't need them. Seems like they want you to buy the ball joints so they can make a profit since they offered free labor.
The Reptile File
Old 05-12-2007, 06:01 PM   #38
Unlimited Rubi
Man just buy a trailer
05 Unlimited Rubicon, 6" Full Traction Lift, Bilstein shocks, 37" Irocs, Flowmaster Hushpower 2, WJ Knuckles and Brakes, 1 ton high steer, Mountain Offroad High Clearance Front Bumper w/9000 Warn, Jeeperman rear w/9500 Ramsey,Kilby gas tank & steering box skids, Poison Spider Trail Cage, Uniden 510xl
Unlimited Rubi is offline   Reply With Quote
Old 05-12-2007, 06:15 PM   #39
mrblaine
Brake Wizard
mrblaine's Avatar
The pin on the balljoint is offset from centerline. Depending on how you orient it in the hole, you can affect caster only, camber only or a combination thereof.
I am Savvy
I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com
mrblaine is offline   Reply With Quote
Old 05-12-2007, 06:50 PM   #40
Flatbroke
Not sure what the Problem is, but saw where you posted maybe it was the 6inch lift. I flat tow mine behind my 5th wheel and also have a 6inch lift with no steering problems. I did however loose a wheel on the rear.
Yellow 02 Sport
Originally Posted by XRussoX
Haha
I actually look at a Jeepers nuts to see how informed they are. Ditch your nuts man!
Russo
Flatbroke is offline   Reply With Quote
Old 05-12-2007, 07:02 PM   #41
RockRunner85
That makes sense. I was just trying to state that with properly setting up the control arm length he shouldn't need offset ball joints.
The Reptile File
Old 05-12-2007, 07:19 PM   #42
redluve1
Is your passenger side sway disconnect bent or is it the picture?
6/5/2011 back in a jeep. 4 door jeep wrangler, green,soft top, 6 speed transmission
redluve1 is offline   Reply With Quote
Glock Forum
