Towing a 2003 behind a RV? - JeepForum.com
post #1 of 11 Old 07-16-2004, 03:45 PM Thread Starter
NekkidFish
I have just purchased a Universal bumper-mount tow bar from JC Whitney, which says it bolts to most flat bumpers. We are moving across country and will be making the final move in an RV, hopefully towing our 2003 Jeep Wrangler, manual transmission.
Here's what I 'think' we have to do to tow:
1. Unlock the steering wheel
2. Put the main drive in Neutral
3. Keep the manual stick in a gear such as third
Is that all we need to do?
I cannot seem to find a lot of info on towing with a tow bar, but a ton on how to tow on a flatbead or with a dolly.
Any and all help will be appreciated!! PK
NekkidFish is offline
post #2 of 11 Old 07-16-2004, 04:27 PM
JFiorentino
JFiorentino's Avatar
I had these web sites bookmarked, they talk about flat towing a Jeep. Good luck.
http://www.jedi.com/obiwan/jeep/flattow.html
And
http://www.monacocoach.com/lifestyle...01/dinghy.html
John
John
"When approaching a four-way stop, the vehicle with the largest tires always has the right of way"
2004 TJ, Auto w/ OD, 4.0L, Off-Road 36x13.5 Super Swamper IROK's on MT Classic II Rims, SYE, CV Driveshaft, 4:56 Gears, ARB Locker, 3.5" RE Superflex, 2" Body Lift, JKS Quicker Disco's, 9,000# Winch, Toys-by-Troy step-sliders, The Source OBA. And lots more....
JFiorentino is offline
post #3 of 11 Old 07-16-2004, 05:36 PM
EDM0656
It's probably in your owner's manual. It was in 99.
99 Sport 4.0 5 speed
2" RE BB 1" Daystar body
32" BFG AT's
Crager Black Steel Wheels 3.75" backspace
Bestop Bikini
Mirror Movers and some lights
Cobra 29 CB
and a few more payments
EDM0656 is offline
post #4 of 11 Old 07-16-2004, 07:01 PM
rico334
rico334's Avatar
Nekkidfish-
I tow my 2000 wrangler all over the place. It has 42k driving miles on it and probably has gone nearly that far by being towed also. (They also do not rack up mileage on the odometer by being towed either)
Follow the 3 steps listed below and you will have no problems.
1. Place transfer case in NEUTRAL
2. Place manual transmission in gear. (I use 1st gear)
3. Unlock the steering wheel to where it free wheels (but not turned to where the accesory power is on.)
Have fun ! !
Rick
O||||O
YELLOW Jeep Club
2000 Tj
5 Sp
I-4
O||||O
rico334 is offline
post #5 of 11 Old 07-17-2004, 05:49 PM
blupupher
blupupher's Avatar
Make sure you have some tow lights hooked up also, either magnetic on wire into the Jeeps lights.
blupupher is offline
post #6 of 11 Old 07-27-2004, 11:00 AM
Broadway
Broadway's Avatar
you might as well put your transmission in nuetruel as well, why take a chance on not having your transfer case completely out of gear. I have found no just cause to leave your transmission in gear.
2000 Black TJ Sport, FF14 bolt disk brakes Detroit and 5.13s, HP D60 ARB and 5.13s, TF727/Atlas 4.3, stretched 104" on 39" IROKS
Broadway is offline
post #7 of 11 Old 07-27-2004, 06:53 PM
rkutzner
rkutzner's Avatar
I agree, unless someone can shed some light on the subject. My 2001 has 28000 road miles and over 4000 towed miles.....
disconnect the battery for that long trip, no miles get racked up either....
2001 TJ Sport
Everything SELF INSTALLED.
The Serious Stuff:4.5 RE LA, 35" MT/Rs, 4.88s, Super44 w/Detroit, D30 w/Ptrax, SYE, Tera 4:1, 2LOW & Rear Disks, AntiRock, Lotsa Skids (some homemade!), Nth Shock Shifters, Patriot 9500...and LOTS more !
rkutzner is offline
post #8 of 11 Old 07-27-2004, 08:27 PM
blupupher
blupupher's Avatar
If your t-case goes into gear and the tranny is in N, your tranny will be toast. There is no internal lubrication going on in the tranny if being driven from the output side. That is why you leave it in gear or park for auto. Not fun if it happens, but better to have a tire lock up than get somewhere and have no transmission (not necessarily from a safety point, but a mechanical one).
post #9 of 11 Old 07-28-2004, 06:40 AM
rkutzner
rkutzner's Avatar
Hmmmm, toasted tranny or nasty accident with toasted Jeep and or toasted engine and or blown diffs and or......
Since the chance is so small and my trips usually short I'll stick with it in Neutral until someone gives a better reason !!!
I need a justification for that 700R4 or NSG370 or NP4500 anyways
2001 TJ Sport
rkutzner is offline
post #10 of 11 Old 07-28-2004, 07:46 AM
97sahara
Tranny in neutral-- when the the T case is in N, you'l get no movement, so why risk screwing up your gears? I've been towing my 97 for a while, and I always put it in 2nd.
97sahara is offline
post #11 of 11 Old 07-28-2004, 10:28 AM
blupupher
blupupher's Avatar
Theoreticaly, with the t-case in N you still could get some turning of the output shaft on the tranny. Not likely, but damage could happen. When I flat tow, I do it with the t-case in N and the tranny in park. Why, because that is the way it was designed to be done. Says so in the owners manual.
2003 TJ What else do i need???? lawson1273 TJ Wrangler Technical Forum 11 06-09-2009 04:38 PM
rubicon? (2003 Rubi vs. 2003 Sport) Tom1 TJ Wrangler Technical Forum 10 09-08-2008 07:24 PM
2003 Tj Canfourjeep TJ Wrangler Technical Forum 5 03-02-2008 12:12 PM
replace 2003 skid plate with <2003 frankske_ TJ Wrangler Technical Forum 5 04-08-2007 06:00 PM
2003 Se RandyS TJ Wrangler Technical Forum 13 09-25-2003 11:27 PM
