tow point - JeepForum.com
post #1 of 13 Old 03-20-2007, 08:47 PM Thread Starter
rob1525
tow point
Does anyone know if I could put some sort of tow points (hooks) or the front and rear bumpers (both stock) of my TJ. If so maybe a picture of what I need. Thanks
rob1525 is offline
post #2 of 13 Old 03-20-2007, 09:20 PM
safarimike
You can get the factory hooks or get the hooks from pep boys (reese I think) that will bolt right up for the front. I think you might have to drill in the rear to mount a hook, or you could just get a hitch.
1999 Jeep Wrangler Sport
safarimike is offline
post #3 of 13 Old 03-20-2007, 09:20 PM
ptowntj
ptowntj's Avatar
Ive seen them pretty cheep on ebay too.
8 lug xj.
ptowntj is offline
post #4 of 13 Old 03-20-2007, 09:30 PM
SecondTJ
SecondTJ's Avatar
skip the stock factory hooks for the front, and get stronger 10k ones. Virtually the same price.
Then get some Grade 8 bolts for them
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #5 of 13 Old 03-21-2007, 08:14 AM Thread Starter
rob1525
Just curious where they bolt on at. Is it the frame where the bumper is attached? If so do I need longer bolts to go along with them?
rob1525 is offline
post #6 of 13 Old 03-21-2007, 08:39 AM
1BadJeepX06
You have to fabricate a factory tow-point in the rear if you do not have a tow-package... There are a few options you have available to you.. Some guys on here have pics..
DH
Coming soon: 2000 Jeep Sport (modifications soon after) :-)
1BadJeepX06 is offline
post #7 of 13 Old 03-21-2007, 09:16 AM
SecondTJ
SecondTJ's Avatar
It is just to the side of the fog lights. You'll see 2 black torx heads.
http://pg.photos.yahoo.com/ph/thamol...e2.jpg&.src=ph
DH
Not entirely true, you can always pick up a factory rear tow hook. And bolt it right in.
SecondTJ is offline
post #8 of 13 Old 03-21-2007, 10:08 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
DH
Check out how to install rear tow hooks at http://www.stu-offroad.com/guards/gas/tj_hooks.htm and make sure NOT to drill through both sides of the frame. The nut and bolt go inside the frame via an opening on the bottom of the frame. Through-bolting through both sides of the frame would start collapsing the frame at that point.
Jerry Bransford is online now
post #9 of 13 Old 03-21-2007, 10:09 AM
aszalan
aszalan's Avatar
The factory rear took hook (part no. 82204120) costs at least $100.
I just went ahead with a hitch and Receiver Shackle
aszalan is offline
post #10 of 13 Old 03-21-2007, 10:10 AM
sardog12
sardog12's Avatar
I got some aftermarket hooks from ebay and they fit perfectly on the front bumper with the grade 8 bolts (~$22) and changed my rear bumper to one with a hitch mount that works great for me.
GEAUX TIGERS
sardog12 is offline
post #11 of 13 Old 03-21-2007, 10:12 AM
Jerry Bransford
Administrator
Are you sure about that? Nevertheless, a pair of 10,500 lb. (stronger than the factory hook) capacity tow hooks can be found nearly anywhere for $15 or less. See my post and link a few posts above this one.
post #12 of 13 Old 03-21-2007, 10:17 AM
Ivan
The Rear Tow Hook and hardware DC part numbers are:
# 9 - 52060 039AA
#10- 6506 116AA
#11- 6505 381AA
From the dealer around $80.
Often you can find them in the For Sale section here for around $20 shipped.
One of the 1,993 Golden Eagles produced in 2006.
Ivan is offline
post #13 of 13 Old 03-21-2007, 11:02 AM
FuzzyDolly
Just an FYI. DC stopped making factory rear TJ points last summer. When I tried to buy one last September, there were only 2 for sale in the entire US. Both in Arizona. If you want a factory rear point, ask your local Jeep dealer to do a search. Maybe they're still available. I was lucky to pick a used one up local when a buddy changed his rear bumper.
Joe
2005 Solar Yellow X
2" Skyjacker BB - 31X10.5\15 Cooper STT
FuzzyDolly is offline
What's really the point? ToothpickJ TJ Wrangler Technical Forum 16 01-21-2011 11:24 PM
What's the point? triplej1954 YJ Wrangler Technical Forum 29 02-11-2010 10:14 PM
5-point in a TJ mpyusko TJ Wrangler Technical Forum 35 12-18-2007 04:06 PM
At What Point............... LowCash TJ Wrangler Technical Forum 1 11-24-2006 09:12 AM
Tow Point.... mudbugII YJ Wrangler Technical Forum 11 12-19-2005 05:58 PM
