#1 | |
Tow Hitch wiring
Does the TJ have a wiring plug in the wiring harness that one can connect to for the tow hitch?
In the past I have always tied into the factory harness behind one of the tail lights. Is there an easier way? Thanks guys! ![]()
[FONT=Verdana]04 Sport 4" Currie lift with Anti-Rock Rock Krawler 4 link rear Skyjacker 2" body lift Safari Snorkel 35" Procomp X-terrain Mickey Thompson Classic lock Aussie locker front & rear 4.88 gears CV Drive shaft 4WD SYE 215 Ponies I6[/FONT] |
#2 |
www.hiddenhitch.com
Part # 16363 Electrical Wiring Kits T-CONNECTOR - JEEP WRANGLER Packaging Type: Custom Clamshell Description Fits: 1998-04 Jeep Wrangler Tech tips Install Time: 10 minutes Amp Rating: 7.5 |
#3 |
thats what i used, not really that hard to do like it says only takes about 10 min tops!
#4 |
I got one from http://www.quadratec.com/ for like $25 and just had one plug on it plugged into the passenger side tail light pigtail takes like 5 min to install
'03 Rubicon |
#5 | |
'03 Bright Silver Metallic TJ Sport BSMCCEP Club Member #45 Stock: 4.0L I6:5-speed:3.07 gears:D35 with Trac-Loc:15x7 Ecco wheels:Dual Top Group Mods: 30x9.5 BFG A-T T/A KO's:JKS Quicker disconnects:Rock-It Man rocker guards:Jeep Medic oil pan/tranny skid:Kilby steering skid:Warn D30 diff guard:C4x4 D35 diff guard:Rusty's radiator guard:Skid Row LCA skids:SilverStar headlights and fogs:Hidden Hitch class III receiver:Old Realistic 40ch CB:2' Firestik II:Arizona Rocky Road tailgate antenna mount Next : Jeeperman rear bumper '06 Candy Orange Honda Shadow Spirit 750 |
#6 |
You may find the connector that you separate, behind the passenger tail light, to be wrapped in a foam insulation tape. Just a heads up.
'04 Unlimited '99 Sport |
#7 |
Since you show a South Africa address, you may have what is called a built up export. Does your Jeep have amber turn signals in the rear? If so, the standard US trailer harness will not be a "plug and play". Give us a response about the amber.
Your initial post indicates past experience with adding trailer connectors. All the wires you need are at the rear of the Jeep. Also, is yours right hand drive? The Jeep dealer may have an accesory trailer harness available. The US harnesses are readily available from many US sources. The answer to the above questions (amber turn and RHD) are important. If you decide to tie in, it should be fairly easy. Color codes should be as follows(assuming amber turn rear lens): Brown/Red stripe = Right Turn Dark Green/Red Stripe=Left Turn Black/Yellow stripe = Tail lights Violet/Black Stripe = Back-up White/Tan Stripe = Brake Lamps HTH
Jean - Wonderful wife 2003 Toyota Sequoia 2005 FA64 Khaki Heidi - Golden Retriever/Jeep Dog |
#8 | |
Thanks
There is no easy (Cost effective) plug in – so splicing the wires and tying in to the tail light cluster is the correct way! Our Jeep dealerships has the “plug and play” system but for US$460.00!!! I have fitted about 12 tow hitches to TJ’s and I have always tied into the tail light cluster. I use the same system as the KC Daylighter system uses. That little blue plastic splicing kit. The Toyota and Land Rover has a dedicated plug for tow hitch wiring and I thought the Jeeps might have the same that I am missing. B.T.W Our globes are all 5watt (21 for brake lights) and our lenses are all bigger and further away from the globes. The front side blinkers have bubbled lenses and the tail light lenses are a half an inch thicker. Thanks for the help! ![]()
#9 |
Sent you a Private Message
#10 |
I assume South African trailers also utilize Amber turn signals on the trailers too. In the US, most trailers, like many vehicles, utilize only a two filament bulb with red lenses. The tow vehicles with amber turn signals have a converter to convert the three wire/filamemt system to a two wire/filament system. One of the filaments is for tail lights, the second is for stop/turn signal. The turn signal switch has internal circuitry to determine stop or turn depending on TS switch position.
Out of curiosity, what is the part number for the dealer part? Do you have headlight levelers too? Another not available in the US item!
#11 |
I was reading the section in the FSM about headlight levelers. Man, that would be nice when towing a trailer with ~300-400lbs of tongue weight.
#12 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
