Total loss for ideas! Anyone with deep knowledge?q - Page 2 - JeepForum.com
post #16 of 27 Old 03-25-2012, 11:50 PM
Sparkyman2000
Originally Posted by Knuckelhead View Post
That didn't fix anything, it helped identify what needs to be fixed...
If that, depending on what he unplugged the ECM is now using preset parameters for air, fuel, spark and timing instead of using other inputs and outputs of sensors. Still could be another problem.
I will start being nicer when you start being smarter.
Sparkyman2000 is offline
post #17 of 27 Old 03-26-2012, 12:26 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by twofiveLO View Post
"Fixed" my problem until I get around to replacing it
X2
I had the same thing going on for a couple months and replaced an tested just about everything. One day I unplugged the o2 sensor.... I haven't plugged it in since
He unplugged the O2 sensor and the PCM is running in open loop...
Knuckelhead is offline
post #18 of 27 Old 03-26-2012, 12:46 AM
twofiveLO
Its not my DD so I haven't lost any sleep over it. I'll replace it when I replace it.
He was asking for help and I replied. What I do with my oxygen sensors in my free time is no one's business but my own. I apologize for offending anyone. Back to the topic at hand.
twofiveLO is offline
post #19 of 27 Old 03-26-2012, 06:15 AM
mike_dippert
mike_dippert's Avatar
Then you shouldn't have posted it. Don't get butt hurt because you've been called out for a shotty "fix" you were suggesting to the OP, which you now claim is just 'temporary', and does nothing to help the OP in the long run.
mike_dippert is offline
post #20 of 27 Old 03-26-2012, 01:44 PM
twofiveLO
This is a technical forum not a social networking site. Get over it troll.
post #21 of 27 Old 03-26-2012, 02:15 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
You are correct, it is a technical forum and should have proper repair info in it, not rednecked up "fixes".
ratmonkey is offline
post #22 of 27 Old 03-26-2012, 05:57 PM
mike_dippert
After 4 months and 27 posts, you're calling me the troll? Trolls don't last 6 years or get 1640 posts on a tech forum.
That is all. Carry-on.
post #23 of 27 Old 03-28-2012, 06:26 PM Thread Starter
aschubert
Replaced faulty elec. Oil press. Sensor with mechanical...love it..peace of mind...60 when running, 25 to 40 at idle.. NOW..got a oem upstream o2 sensor, will be putting in tonight...jeep mechanic spent 30 mins with me just talking today and basically pointed at the upstream o2 sensor as many of you have...he said my 97 will rarely throw a code for upstream sensor....will update! Thanks for all the replies. If I lick this, I got one great jeep given all the testing I have done and she has passed!
aschubert is offline
post #24 of 27 Old 03-28-2012, 07:26 PM
williambmac
hooking up a scan tool and checking your short and long term fuel trims would have told you right away that you have an o2 sensor problem.
I would suggest using o.e. only sensors, stay away from the aftermarket junk.
good luck.
2000 TJ 5.5 Long arm, lots of extras. R.I.P.
2005 LJ rubi 35's Clayton, lots of extras
williambmac is offline
post #25 of 27 Old 03-28-2012, 10:38 PM Thread Starter
aschubert
Replaced upstream o2 sensor, new autolite plat plugs, oil change.....WHAT THE....RUNS HORRIBLE! Like it was missing on two cylinders...online spark tester revealed nothing...threads suggest learning curve for PCM..doubt it.....THEN...found thread on automate plat. Plugs...NEVER USE THEM EVER EVER EVER..put my old fouled plugs in...ALL PROBLEMS ARE GONE....so I had a bad upstream sensor, never threw codes...without the forum I never would have found that in decent time, and I would never have known the autolite plats sucked..can't thank forum and members enough! She run great..gonna replace those dirty plugs tomorrow still...I'd have a barbecue foe you all if I could! Thanks, my Jeep brothers! Wooooo HOOOOO!!!!!
post #26 of 27 Old 03-28-2012, 10:39 PM Thread Starter
aschubert
"inline" tester...hate iPad autocorrect...
post #27 of 27 Old 03-28-2012, 10:40 PM Thread Starter
aschubert
Dang it, autolite...got me again...
poor fuel mileage , rough idle
Total loss of electrical power gummy TJ Wrangler Technical Forum 6 03-17-2009 10:58 AM
Help, total loss of electrical power while driving? iflycoptors TJ Wrangler Technical Forum 19 07-28-2007 09:25 AM
4.2 total loss of power under heavier load.. Richmond88yj YJ Wrangler Technical Forum 4 03-04-2007 12:12 PM
Jeep got hit...Looks like a total loss spitfire13 YJ Wrangler Technical Forum 14 12-21-2004 02:33 PM
Total loss of power Drunc YJ Wrangler Technical Forum 4 11-27-2002 07:43 PM
