Total loss for ideas! Anyone with deep knowledge?q - JeepForum.com
post #1 of 27 Old 03-22-2012, 09:09 PM Thread Starter
aschubert
97 tj 4.0....prob: surge/hesitation (on acceleration) rough closed loop idle, power loss..rumbles along rather than smooth running...
Heres where it gets interesting: vacuum aces across all tests, compression 125,125,130,124,125,127...stable 40 psi fuel pressure, rebuilt and tested injectors, new Map sensor, tps sensor tests good, new plugs, wires and spark to plugs tested excellent with online tester, new cat, new o2 sensor, new exhaust manifold..no vacuum leaks anywhere...ran through all possible test variations with vacuum gauge. New gas tank and filters. Whining alternator, but output solid. Evap solenoid tested perfect with ohm meter..(only test I knew to run on it)..evap dry, unplugged. All new exhaust system, including cat. Had intake manifold leak for awhile, baked some plugs, but compression and vacuum testing indicates valves, rings good. Seems to be running rich..as if timing was off...but as u know, no adjustment on that..chain jump would cause far more problems...idle air control sensor clean, functioning unknown. Have not done leak down test, symptoms don't point to that revealing anything. Rough idle spotty, not patterned..as if rich...wondering if unburned fuel closest to intake leak that was fixed cartooned up valves and preignition is occurring..anyone got ANY FREAKING SUGGESTIONS! ARGHHHHH! Oh yeah..mileage is down, too.... :confused
aschubert is offline
post #2 of 27 Old 03-22-2012, 09:32 PM
MattJeep
2003 WJ
Try a proper NTK O2 sensor. Mine had symptoms just like yours and the O2 sensor cured it. Just a thought.
MattJeep is offline
post #3 of 27 Old 03-22-2012, 10:09 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Have you tried unplugging the upstream O2 sensor?...
Knuckelhead is offline
post #4 of 27 Old 03-22-2012, 10:40 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Isn't fuel pressure supposed to be 49psi?
ratmonkey is offline
post #5 of 27 Old 03-22-2012, 11:19 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
What brand of 02 sensor did you install?
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #6 of 27 Old 03-22-2012, 11:57 PM
Sparkyman2000
Fuel pressure should be 49psi or within 10%. Check volume of the fuel pump. Make sure pressure doesnt bleed off entirely after 10 mins of turning vehicle off. Is the fuel good? If the LDP is stuck open too much fumes can get into intake cause too rich. I would check vacuum hoses from rear of car to front. Is check engine light on or any codes stored? Charging system ok? not correct voltage and amps the PCM acts wierd. Throttle body clean and decarbonized same with intake?(a Service Bulletin) Oh as far as IAC is concerned I would remove it than plug it back in turn ignition on see if it moves.
I will start being nicer when you start being smarter.
Sparkyman2000 is offline
post #7 of 27 Old 03-23-2012, 12:22 AM
DevilDogDoc
Early TJ, maybe weak exhaust valve springs?
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #8 of 27 Old 03-23-2012, 12:28 AM
twofiveLO
X2
I had the same thing going on for a couple months and replaced an tested just about everything. One day I unplugged the o2 sensor.... I haven't plugged it in since
twofiveLO is offline
post #9 of 27 Old 03-23-2012, 07:18 AM
UnlimitedMatt
I heard of people having random issues with 97's. Over in the Colorado section of NAXJA (North America XJ Association) they were saying to replace the ecu (computer). That was the last thing they replaced out of desperation and it fixed the random problems on their 97.
2005 Unlimited Rubicon, Sahara Edition #556, Colorado Jeep Club Member #556
Rusty, if you are reading this, I am still waiting for my $249 refund from 06/2010. Pm me for my address to send the check. Thanks!
UnlimitedMatt is offline
post #10 of 27 Old 03-23-2012, 10:30 AM
Knuckelhead
AFSOC Retired
Originally Posted by twofiveLO View Post
X2
That's a troubleshooting step, not a fix...
post #11 of 27 Old 03-23-2012, 12:34 PM
NotURMailman
NotURMailman's Avatar
A bad injector (or injectors) leaking fuel into the engine is also possible, although less likely than some of the other suggestions that have been made.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #12 of 27 Old 03-24-2012, 01:12 PM Thread Starter
aschubert
LDP? 02 sensorwas whatever orielly's had on a frustrated Sunday....intake and upper engine had 64 oz of sea foam, throttle body pulled off and cleaned already...one other thing...no pressure released when fuel cap removed,but seems like people say that's the norm? Do you mean see if unplugging the iac while running to see if the idle speed moves? Not certain what u meant by that idea....gonna look at all suggestions...Thanks for responses! Will let y'all know...
post #13 of 27 Old 03-25-2012, 06:16 PM
twofiveLO
"Fixed" my problem until I get around to replacing it
post #14 of 27 Old 03-25-2012, 07:07 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
So in other words, we should all go unplug our O2 sensors to fix our rigs?
I am Savvy
post #15 of 27 Old 03-25-2012, 08:20 PM
Knuckelhead
AFSOC Retired
That didn't fix anything, it helped identify what needs to be fixed...
poor fuel mileage , rough idle
Total loss of electrical power gummy TJ Wrangler Technical Forum 6 03-17-2009 09:58 AM
Help, total loss of electrical power while driving? iflycoptors TJ Wrangler Technical Forum 19 07-28-2007 08:25 AM
4.2 total loss of power under heavier load.. Richmond88yj YJ Wrangler Technical Forum 4 03-04-2007 11:12 AM
Jeep got hit...Looks like a total loss spitfire13 YJ Wrangler Technical Forum 14 12-21-2004 01:33 PM
Total loss of power Drunc YJ Wrangler Technical Forum 4 11-27-2002 06:43 PM
