Total Height with 2.5" lift, 1" body lift, and 33's? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Total Height with 2.5" lift, 1" body lift, and 33's?
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 07-21-2010, 07:59 PM   #1
Donato_XIII
Does anyone know how high they (your TJ) sits from ground to the highest point? I have clearance bars in my underground parking lot and i want to make sure i wont be anywhere near them.
I'll need someone with 2-2.5" lift, 1'' BL, and 33s. Thanks in advance
Donato_XIII is offline   Reply With Quote Quick reply to this message
Unread 07-22-2010, 06:26 AM   #2
mdm
Farm Wheeler
It should be pretty easy to figure out.
Current height
+ 2.5" from the lift
+1" from the BL
+ (33" - current tire size)/2 from change in tire diameter
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote Quick reply to this message
Unread 07-22-2010, 06:38 AM   #3
TheBoogieman
Congrats DENVER BRONCOS!
TheBoogieman's Avatar
6' 2".
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 07-22-2010, 12:53 PM   #4
Jonny Jeep
Jonny Jeep's Avatar
Stock height with soft top (hard top is not as tall) = 70.9 inches (Jeep Specs).
Assuming stock 215/75 15 tyre and 33" tyre are accurate sizes, height gain from tyre is. (33-27.7)/2 = 2.65"
And also assuming suspension/body lift heights are accurate.
70.9 +2.65 +2.5 +1 = 77.05" or 6' 5"ish.
Online factory service manuals and parts lists - http://www.jeep4x4center.com/knowledge-base/index.htm
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline   Reply With Quote Quick reply to this message
Unread 07-22-2010, 12:57 PM   #5
REDLYNER
Mall Crawling Racer
REDLYNER's Avatar
I'm at 75" with a 3.5" and 37"s.
REDLYNER Racing #4410
Rugged Radios * Raceline Wheels * DynoMax Exhaust * Motor Trenz * Polar Bear Coolers
Instagram/Facebook/Twitter: redlynerracing
REDLYNER is offline   Reply With Quote Quick reply to this message
Unread 07-22-2010, 01:01 PM   #6
MAMMOTH
Wooly Member
MAMMOTH's Avatar
What is the clearance marked on the garage? I have 3" suspension and 33's and haven't had an issue anywhere yet other than my CB antenna hitting things.
2004 TJ Rubicon - 3" lift, 1" BL, Brown Dog MML with Super brackets, 33's, Warn Winch, VanCo BBK - (Thanks MisfitSeven), IronRock tierod, Ten Factory shafts.
Future upgrades - Too many to list
1999 XJ - DD with 228k
2007 JK Unlimited - The wife's ride.
MAMMOTH is offline   Reply With Quote Quick reply to this message
Unread 07-22-2010, 01:38 PM   #7
TheBoogieman
Not even close.My 35's with 4" SL and 1" BL is 6'5"-6'6".It must be the "tyres" instead of using tires here.
Unread 07-22-2010, 01:59 PM   #8
Jonny Jeep
Jonny Jeep's Avatar
It might not be close to real life but is accurate given the assumptions made.
I know my 33" tyres are closer to 32" in actual diameter and the height will also change depending on rim width and tyre pressure. It will also change due to spring sag with age. The assumptions used simply give worst case (max) height where clearance is limited, "tyres" or not.
Unread 07-23-2010, 07:32 PM   #9
Donato_XIII
Ive never been good at math =P
Clearance is 6'10" in some spots, 6'7" in others... dont ask why.
I have 2 tops; the stock hardtop and rampage bowless (which i would imagine would be even smaller the a stock softtop) I was fairly confident that i would still have a decent amount of room to spare, Thanks for all the input. Anyone know how much a roof rack would add? LOL
Unread 07-23-2010, 07:36 PM   #10
jeepinmichguy_
you will be way good to go.
[CENTER][SIZE="4"]ΜΟΛΩΝ ΛΑΒΕ[/SIZE][/CENTER]
[QUOTE=TheBoogieman;12766892]Jeepinmichguy is a jerk.[/QUOTE]
[QUOTE=mrblaine;12000822]
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?[/QUOTE]
[QUOTE=JeepForum123;13578398]you all have nice rigs, stop being f****** a**holes.[/QUOTE]
jeepinmichguy_ is offline   Reply With Quote Quick reply to this message
Unread 07-23-2010, 10:50 PM   #11
mitchlandry
Have 33x12.5s with 2.5 RC w/ 1.25 BL lift, total is 74.5" to top of soft top. I park in a 6' 8" garage everyday, no issue, with about 6" to spare.
Also, tires will make a difference as well, mine are labeled 33's, but are actually ~32, then aired down for proper wear, so my tires are actually about 31.5"
mitchlandry is offline   Reply With Quote Quick reply to this message
height , total , lift , suspension , body lift , bl , 33 , tj , wrangler
