Total Height with 2.5" lift, 1" body lift, and 33's? - JeepForum.com
post #1 of 11 Old 07-21-2010, 06:59 PM Thread Starter
Donato_XIII
Does anyone know how high they (your TJ) sits from ground to the highest point? I have clearance bars in my underground parking lot and i want to make sure i wont be anywhere near them.
I'll need someone with 2-2.5" lift, 1'' BL, and 33s. Thanks in advance
Donato_XIII is offline
post #2 of 11 Old 07-22-2010, 05:26 AM
mdm
Farm Wheeler
It should be pretty easy to figure out.
Current height
+ 2.5" from the lift
+1" from the BL
+ (33" - current tire size)/2 from change in tire diameter
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 11 Old 07-22-2010, 05:38 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
6' 2".
TheBoogieman is offline
post #4 of 11 Old 07-22-2010, 11:53 AM
Jonny Jeep
Jonny Jeep's Avatar
Stock height with soft top (hard top is not as tall) = 70.9 inches (Jeep Specs).
Assuming stock 215/75 15 tyre and 33" tyre are accurate sizes, height gain from tyre is. (33-27.7)/2 = 2.65"
And also assuming suspension/body lift heights are accurate.
70.9 +2.65 +2.5 +1 = 77.05" or 6' 5"ish.
Jonny Jeep is online now
post #5 of 11 Old 07-22-2010, 11:57 AM
REDLYNER
REDLYNER's Avatar
I'm at 75" with a 3.5" and 37"s.
REDLYNER Racing #4410
Rugged Radios * Raceline Wheels * DynoMax Exhaust * Motor Trenz * Polar Bear Coolers
Instagram/Facebook/Twitter: redlynerracing
REDLYNER is offline
post #6 of 11 Old 07-22-2010, 12:01 PM
MAMMOTH
Wooly Member
MAMMOTH's Avatar
What is the clearance marked on the garage? I have 3" suspension and 33's and haven't had an issue anywhere yet other than my CB antenna hitting things.
2004 TJ Rubicon - 3" lift, 1" BL, Brown Dog MML with Super brackets, 33's, Warn Winch, VanCo BBK - (Thanks MisfitSeven), IronRock tierod, Ten Factory shafts.
Future upgrades - Too many to list
1999 XJ - DD with 228k
2007 JK Unlimited - The wife's ride.
MAMMOTH is offline
post #7 of 11 Old 07-22-2010, 12:38 PM
TheBoogieman
Disturbed
Not even close.My 35's with 4" SL and 1" BL is 6'5"-6'6".It must be the "tyres" instead of using tires here.
post #8 of 11 Old 07-22-2010, 12:59 PM
Jonny Jeep
Jonny Jeep's Avatar
It might not be close to real life but is accurate given the assumptions made.
I know my 33" tyres are closer to 32" in actual diameter and the height will also change depending on rim width and tyre pressure. It will also change due to spring sag with age. The assumptions used simply give worst case (max) height where clearance is limited, "tyres" or not.
post #9 of 11 Old 07-23-2010, 06:32 PM Thread Starter
Donato_XIII
Ive never been good at math =P
Clearance is 6'10" in some spots, 6'7" in others... dont ask why.
I have 2 tops; the stock hardtop and rampage bowless (which i would imagine would be even smaller the a stock softtop) I was fairly confident that i would still have a decent amount of room to spare, Thanks for all the input. Anyone know how much a roof rack would add? LOL
post #10 of 11 Old 07-23-2010, 06:36 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
you will be way good to go.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #11 of 11 Old 07-23-2010, 09:50 PM
mitchlandry
Have 33x12.5s with 2.5 RC w/ 1.25 BL lift, total is 74.5" to top of soft top. I park in a 6' 8" garage everyday, no issue, with about 6" to spare.
Also, tires will make a difference as well, mine are labeled 33's, but are actually ~32, then aired down for proper wear, so my tires are actually about 31.5"
mitchlandry is offline
height , total , lift , suspension , body lift , bl , 33 , tj , wrangler
Tryin to figure out how I'm running 33's. Lift or body lift question. dm33buckeyes TJ Wrangler Technical Forum 21 08-14-2011 04:06 PM
Total Height With a Lift? thefewtheproud YJ Wrangler Technical Forum 1 04-27-2010 09:01 AM
33's on a body lift awjdonald YJ Wrangler Technical Forum 22 01-28-2010 10:02 PM
Need total height of YJ with 4" lift and 33s dbdragracing YJ Wrangler Technical Forum 11 12-26-2009 04:58 PM
Is 3/4" body lift enough for 31X10.50's with stock height shocks? RedArrow10 TJ Wrangler Technical Forum 23 04-27-2009 08:29 AM
