Quantcast Torx bolt problem windshield bracket - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Torx bolt problem windshield bracket
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Old 02-28-2009, 05:11 PM   #1
BluegrassTJ
Anyone-
I need help here. I was going to simply install a light bar. That's when it all went wrong. I went to take out the torx bolts: two on passenger side came out fine. Lower Driver side came out ok too. The top torx bolt of the two inset bolts would not budge. Sheered off two torx-40 bits with hand socket wrench.
So, went to the old easy-out method. Drilled smaill hole, tried to get a bite, stripped out....so, drill it all out right....I started in on it and a few broken drill bits....and the realization that probably just screwed up the bracket by boring out whatever it was attached to now enlightens me. The anger got the best of me.
A few questions in order of importance.
1) What is it bolting to on the other side of the windshield frame that I bored out?
2) can that something be easily replaced?
3) if so, how?
4) how much pain/money am I in for here?
Thanks-
BluegrassTJ is offline   Reply With Quote
Old 02-28-2009, 05:18 PM   #2
Hesher420
!!! SLAYER !!!
Hesher420's Avatar
May help you out.....
http://www.emhart.com/products/helicoil.asp
FOR SALE*NIB*TJ CHOME GRILL OVERLAYCLICK HERE
**'06 Blacked Out LJ**
> > > LJ Owners Group < < <
Black Jeep Society
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline   Reply With Quote
Old 02-28-2009, 05:23 PM   #3
BluegrassTJ
helicoil...no idea what to do with that one....too complicated for my level and lack of welder.
Old 02-28-2009, 05:40 PM   #4
Country Boy
Bovi-sapiens
Country Boy's Avatar
Helicoil:
Step 1: Drill hole listed for that size coil.
Step 2: Tap hole with listed size tap.
Step 3: Screw coil into hole.
Step 4: Snap off tab used to screw coil in.
Step 5: Install your fastener of choice.
Its pretty easy and no welder involved. If you get a kit, many times they have the thread tap in there. You just need to get the right size coil. I like to use a bit of high strength Loc-tite on the threads of the coil so it won't come unscrewed from the hole when backing out the screw later on.
2000 WJ Grand Cherokee Limited, 4.7l V8, Quadra-drive
Farming is easy when your plow is a pencil and you are a thousand miles from the cornfield. -Dwight D. Eisenhower
Don't curse the farmer with your mouth full.
Ah, cows. A thousand roast beef sandwiches wrapped in a gorgeous leather coat.
Country Boy is offline   Reply With Quote
Old 02-28-2009, 05:46 PM   #5
clackclack
helicoil used to be life savers in the old magnesium porsche engines... they work on a pretty simple concept; drill out appropriate over-size hole, tap with provided tap (in the kit), screw in new threads (heli-coil) with tool provided in kit... Voila!
Some one once told me they drilled and tapped JB weld with some success... you could try that
clackclack is offline   Reply With Quote
Old 02-28-2009, 05:47 PM   #6
cadencedad
I used a impact..
cadencedad is offline   Reply With Quote
Old 03-02-2009, 01:45 PM   #7
BluegrassTJ
I worked on drilling the only stuck one out and in the process tore up the sheet metal bracket on the inside on the frame pretty good. It bent and really there is nothing to thread the top bolt into now. More questions.
1) I looked in the parts catalog as well as inside out on the jeep itself and cannot find anyone who even knows about this small piece of threaded sheet metal that the upper two hinge bracket bolts are bolted into on the inside of the frame. Honestly it is a threaded piece of sheet metal that I cannot get to but resides inside the frame of the windshield. Anyone here confirm that I know what I am seeing. It moves independently of the frame inside it. Part guy said it was part of the frame but mine it moving around on both the driver and passenger sides once I have the two top bolts out.
2) Any way to get behind the frame to get a net back there to tighten to? OR Anyone know of a method now that I do not have the threads back there to attach on the inside of the windshield frame?
3) Will the windshield hold with only the lower bolt in the bracket on the drivers side?
This whole thing started so that I could add a light bar and now I am up a creek and probably cant attach the bar now anyway since I would only have one bolt on the drivers side. HELP!
Old 03-02-2009, 08:20 PM   #8
Country Boy
Bovi-sapiens
Can't help you on the second and third items, but those may be called "nutserts" or "captive nuts". I have seen them on old farm tractors for bolting down the hood. They can be small pieces of metal that have threads in them and are held in place by a springy sheet metal cage. The cage might be welded in place, or it may be clipped into the (usually square) hole. I haven't taken my bracket off, so I can't tell you for sure what it is. You might be able to get a body shop to weld an insert in place so you can tighten those screws up. Not sure what that would all entail. Can you get pics of the area in question?
Old 03-02-2009, 08:28 PM   #9
dodgetk81
It is a nut plate. There is no way that I know of to get at it. Maybe you can use a small hole saw to put a hole on the inside of the frame to het a nut on it. Then use a rubber plug to fill the hole.
97 TJ 4.0, auto, 4.5" RE long arm, 33 " MT/R's on Moabs, 4.10's, 8.8 w/Aussie locker, A to Z rockers, A/A SYE, Warn M8000, Vanco brakes, Raptor liner
10 Dodge Journey AWD
02 TJ salvage father and son build
98 XJ Classic Stock
91 Schoolbus converted to an rv for goin to Nascar races
Former owner of CJ's, XJ's, a ZJ and a FSJ Cherokee.
dodgetk81 is offline   Reply With Quote
Old 03-05-2009, 09:27 AM   #10
BluegrassTJ
I did just that yesterday. 1-1/8 hole saw cut a hole on the inside of the window frame even with the top of the two bolts. This allowed me access to put nuts and washers on the inside of the frame and tighten them up. (upper one with a socket...lower one with an crescnet wrench on an angle. Worked well and filled the inside of the post with expandable foam to deaden the sound of that lock plate the fell off inside the frame. Covered the hole with a rubber grommet and put the interior molding back on. Looks fine and works like a charm.....although it was the long way around.
Old 04-23-2009, 11:36 PM   #11
jinshiyang
help you out.....
http://www.xhcljx.com/eng
jinshiyang is offline   Reply With Quote
Old 07-09-2009, 12:09 AM   #12
qfjsy
Here may help you……
qfjsy is offline   Reply With Quote
Old 07-09-2009, 12:17 AM   #13
Evian
Evian's Avatar
Welcome to Torx screw hell! You are in good company.
Evian is offline   Reply With Quote
Old 07-09-2009, 12:37 AM   #14
distantdog
I had this happen to me: http://www.jeepforum.com/forum/f9/windshield-bolt-problem-474510/
Good luck. I took it to a shop and had them fix it. Rigged it up with an extra bolt. $160. Made me want to murder someone.
2004 WJ Laredo Special Edition V8 4x4
stock :)
SOLD: 2001 TJ Sport
distantdog is offline   Reply With Quote
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
