torx 35 bit ??? - JeepForum.com
post #1 of 23 Old 05-13-2011, 09:24 AM Thread Starter
adixon94
torx 35 bit ???
while trying to put my mirror relocation mounts on my '06 LJ i found out that i need a torx bit between a 30 and 40. all of my tool kits seem to skip 30 to 40 and so do most in stores. Im wondering do they make a bit between 30 and 40 such as 32 or 35 and if so where can i get one.
adixon94 is offline
post #2 of 23 Old 05-13-2011, 09:34 AM
TraumaMonkey
There is certainly a T35 bit you are missing. You should be able to get one at any decent hardware or auto parts store.
TraumaMonkey is offline
post #3 of 23 Old 05-13-2011, 09:34 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
No such size as a T32 or T35.
http://en.wikipedia.org/wiki/Torx
If you don't believe a Wiki posting, just Google for the industrial specifications of TORX fasteners.
CJ7-Tim is offline
post #4 of 23 Old 05-13-2011, 09:45 AM
monkeee2002
That's odd, I'm pretty sure I have a T35 bit in my toolbox.
Bought it at Orileys, it was about 10 bucks, iirc.
The skinny pedal on the right is my friend. the gas gauge is not.
monkeee2002 is offline
post #5 of 23 Old 05-13-2011, 09:56 AM
hustler905
Are you sure it's not just a T-40 with a bunch of paint in it?
hustler905 is offline
post #6 of 23 Old 05-13-2011, 09:56 AM
CJ7-Tim
CJ7-Tim's Avatar
Tamper Proof security Torx have a T35. Tamper Proof fasteners have that pin in the center of the Hex that block a standard Torx bit.
Maybe LJ's have security hardware for mirrors, but standard Torx fasteners don't have a T32 or a T35.
CJ7-Tim is offline
post #7 of 23 Old 05-13-2011, 10:04 AM
chris142
Theres also a Torx Plus that wont work on a regular torx bolt.
chris142 is offline
post #8 of 23 Old 05-13-2011, 10:11 AM
p997c4s
Get a torx bit with a lifetime warranty and keep that receipt handy... . At least yours is a 2006, maybe you will get them off, I would not touch them. Good luck!
p997c4s is offline
post #9 of 23 Old 05-13-2011, 10:29 AM
freeskier93
I'm pretty sure this is the solution. Just about every torx on the body is t40, but most people think it's to big because the bolt is filled with paint. I have removed every torx bolt on the body of my jeep and replaced almost all of them with stainless hex key bolts.
I find the best trick is to bang the bit in with a rubber mallet and use a wrench or impact tool.
freeskier93 is offline
post #10 of 23 Old 05-14-2011, 09:23 AM
monkeee2002
EDIT: OOPS!!! My bad! I was thinking of the T-55. I have no T35.
I have removed my mirrors, so it's probably just got paint in it. I really don't remember having any problems with mine.
post #11 of 23 Old 05-14-2011, 09:25 AM
LiveAndLearn
just looked, I dont have one either
LiveAndLearn is offline
post #12 of 23 Old 05-14-2011, 10:46 AM
flatlander757
No such thing as a standard T35... it's always good fun to ask a new mechanic in training for a T35 socket
Use a T40, and tap it in with a hammer... as stated already it's full of paint.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #13 of 23 Old 05-14-2011, 10:51 AM
MooSe7
Originally Posted by freeskier93 View Post
I have removed every torx bolt on the body of my jeep and replaced almost all of them with stainless hex key bolts. .
Happen to remember the size?
2004 Wrangler Sport
2006 Grand Cherokee Laredo
MooSe7 is offline
post #14 of 23 Old 05-14-2011, 12:39 PM
CJ Chet
The ones on my '04 are T40!
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #15 of 23 Old 05-14-2011, 01:09 PM
PurpleTJ
just removed all 8 windshield hinge bolts without stripping yesterday. used a t40
Purple Jeep Club member #8
PurpleTJ is offline
Torx bit set? fang_x TJ Wrangler Technical Forum 12 11-21-2010 10:55 PM
Why Torx???? crqflier TJ Wrangler Technical Forum 25 06-28-2009 05:55 PM
another torx dwales31 YJ Wrangler Technical Forum 3 07-10-2006 09:29 AM
Help!! Where to buy the torx e12?? mspell YJ Wrangler Technical Forum 7 09-04-2005 04:41 AM
Torx!! TJ2000 TJ Wrangler Technical Forum 4 12-18-2003 10:39 PM
