Quantcast Torque Steer - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Torque Steer
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 12-16-2008, 06:38 PM   #1
dz1087
Torque Steer
What Causes it and How do I get rid of it?
Back story:
My rig's been pulling left for about a year and a half. It has really been bothering me lately and I have been trying to fix it. So I got a used set of LCA's, thinking my left side was bad and thus allowing the left wheel base to shorten under acceleration. I changed out the left one and it did the same thing. I then swapped the left with the right, and vice-versa. Well, it still does the same thing.
When I pulled the right side though, the axle went back about a half inch and I had to jack the right side up in order to line the holes up to bolt it back in. The left side just sat right in place, didn't have to move it at all. Could this be telling me something about my problem, like a bad UCA or shock, or???
Air Force Jeep Club - Tail# JF037AD
'03 TJ Sport, Black on White, Stock. [[Gone]]
'99 XJ, Purple, Stock but with new wheels.
Running Doorless? Check your state's Mirror Laws!!
http://www.jeepforum.com/forum/f176/list-state-mirror-laws-565361/
There can be no fifty-fifty Americanism in this country. There is room here for only 100% Americanism, only for those who are Americans and nothing else.
Theodore Roosevelt
dz1087 is offline   Reply With Quote
Old 12-16-2008, 06:46 PM   #2
Pillswoj
Bad rear tackbar bushing will cause torque steer too.
Not shocks normally, but any of they bushings in the upper and lower arms as well as the trackbar are what stabilizes the axle and torque steer is the rear axle shifting under acceleration
Friends don't let Friends run Bosch
My Wifes Cake Site - Check the Jeep Under Carved & 3D
Pillswoj is offline   Reply With Quote
Old 12-16-2008, 06:59 PM   #3
LJ_Cool
Have you measured the distance between your hubs front to back to ensure they're evenly spaced?
It was almost impossible to get my older JGC to track straight, and it turned out that one side was just wore or adjusted so poorly that the wheelbase was about an inch shorter on one side.
I would check the play in your rear axle too, it's where the main driving thrust is provided, and if it's jimmying to one side under power it will cause you to veer.
Generally, torque steer is more noticable on FWD cars, and is typically caused because the centerline of tire, is not the same as the centerline where the front wheels pivot when turning. A tire on one side will have more traction, and thus cause the tire to pivot the whole steering system when under stronger acceleration.
2006 TJ Unlimited (Midnight Blue #888)
58k - 2" lift, riding on 31's with terraflex rocker armor
LJ_Cool is offline   Reply With Quote
Old 12-16-2008, 07:13 PM   #4
Pillswoj
Actually "torque steer" may not be the best term, I call it "rear steer". When the bushings in my rear trackbar were shot the jeep would pull left if you were on the gas and then pull left when you took your foot off the gas. It is very noticable and is caused by the rear axle moving with the torque of acceleration.
Old 12-16-2008, 08:02 PM   #5
dz1087
Correct, but evidently it is not my LCA's, so I'm wondering what else it could be.
http://www.jeepforum.com/forum/showthread.php?t=565361
Theodore Roosevelt
Old 12-16-2008, 08:09 PM   #6
Kpat
Bad rear trackbar bushing will cause torque steer too.
X2 on the rear track bar
2000 XJ 4" 33's... TJ on 1 tons and 40's after Afghanistan!
Kpat is offline   Reply With Quote
Old 12-16-2008, 08:13 PM   #7
Pillswoj
Have you inspected the trackbar bushings? do you have a relocation bracket on the trackbar, they can also loosen.
Old 12-16-2008, 08:21 PM   #8
dz1087
I'm bone stock on the suspension. How could I check the bushings on the trackbar?
Theodore Roosevelt
Old 12-16-2008, 08:42 PM   #9
Pillswoj
properly you would have to remove the trackbar to inspect then make sure you torque to spec.
However, while you are looking underneath the jeep at the trackbar, have someone push the back of the jeep side to side and see if there is movement at the trackbar ends.
Old 12-16-2008, 08:46 PM   #10
dz1087
I'm still not seeing how this could cause the left side to get closer under acceleration.
Theodore Roosevelt
Old 12-16-2008, 08:46 PM   #11
dz1087
Should I be considering poly bushings for everything back there?
Theodore Roosevelt
Old 12-16-2008, 09:24 PM   #12
Pillswoj
If the trackbar bushings are shot, it allows the axle to move side to side when accelerating, this will cause the jeep to veer left when accel. and right when you let off the gas. (I could have that backwards it was over a year ago when I had the problem) .
Since you tried replacing LCA the trackbar becomes the prime suspect. The upper control arms arm more for control of axle wrap.
Old 12-17-2008, 06:43 AM   #13
mdm
Farm Wheeler
...it allows the axle to move side to side when accelerating, this will cause the jeep to veer left when accel. and right when you let off the gas...
I had this problem with shot upper control arm bushings.
mdm is offline   Reply With Quote
Old 12-17-2008, 04:58 PM   #14
dz1087
OK, I'm trying not to replace everything if I don't have to. So what would be the most likely suspect, and how would I check? If I swapped the UCA's, and they are in fact the problem, would it pull tot the right instead?
Theodore Roosevelt
Old 12-17-2008, 05:11 PM   #15
Pillswoj
Again, either you take things off and inspect or have someone try to shove the rear of the jeep side to side while you check for movement .
Glock Forum
