Torque specs for Spydertrax wheel spacers - JeepForum.com
post #1 of 9 Old 04-14-2006, 10:16 AM Thread Starter
UCTJ
UCTJ's Avatar
Does anyone know the proper torque spec for Spydertrax wheel spacers???
Thanks...
UCTJ is offline
post #2 of 9 Old 04-14-2006, 10:19 AM
E_ROCK
Thanks...
I called Spydertrax when I got mine. They told me 80 to 90 ft-lb. They also mentioned that I was the only person to call and ask than question. WTF? I was wondering if he was screwing with me.
You can always give them a call also.
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #3 of 9 Old 04-14-2006, 10:21 AM
erickpl
erickpl's Avatar
Yep 80-90. I did mine right down the middle and did 85 to 87.
Just be sure to remove any little c-clips from the outside of your rear drum brakes if you have them. If you don't, the spacers won't fit flush and may cause vibrations or more serious problems.
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #4 of 9 Old 04-14-2006, 10:24 AM
E_ROCK
I used red locklite on them also.
E_ROCK is offline
post #5 of 9 Old 04-14-2006, 10:30 AM
lupinsea
lupinsea's Avatar
He was probably wondering because the spacers come with an instruction sheet that clearly had the torque spec called out.
- Jay
lupinsea is offline
post #6 of 9 Old 04-14-2006, 10:30 AM Thread Starter
UCTJ
UCTJ's Avatar
thanks guys...I also have some locktight...
UCTJ is offline
post #7 of 9 Old 04-14-2006, 10:47 AM Thread Starter
UCTJ
UCTJ's Avatar
Well just got off the phone with Spydertrax and you guys were right on...they spec'd the torque between 85-110 ft/lbs.
Thanks again..
UCTJ is offline
post #8 of 9 Old 04-14-2006, 11:01 AM
E_ROCK
Mine didn't come with any instruction sheet, so there.
E_ROCK is offline
post #9 of 9 Old 04-14-2006, 11:05 AM Thread Starter
UCTJ
UCTJ's Avatar
I got mine used for a good price so they didnt come with instructions either....
UCTJ is offline
Spydertrax spacers safe? JP4LIFE TJ Wrangler Technical Forum 28 02-14-2009 02:48 PM
Torque Specs GIJoe Driver JK Wrangler Technical Forum 8 05-31-2008 05:18 PM
Steering Wheel Torque Specs? jhh TJ Wrangler Technical Forum 1 12-22-2007 02:11 PM
need torque specs 97 tj 97_tj TJ Wrangler Technical Forum 4 12-06-2006 07:16 PM
97 torque specs ugrider21 TJ Wrangler Technical Forum 3 08-18-2004 09:08 PM
