Quantcast Torque specs on oil pan bolts - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Torque specs on oil pan bolts
Old 07-19-2006, 02:46 PM   #1
COYJ
I replaced my oil pan after having punctured it on a rock. I have the new one in place but I'm unsure how tight the bolts need to be. I've snugged them down evenly without much pressure so as to not crush the gasket, is this good enough? 4.0L engine.
COYJ is offline   Reply With Quote
Old 07-19-2006, 05:46 PM   #2
Stu Olson
Stu Olson's Avatar
My FSM shows the 1/4-20 bolts getting 84 inch pounds while the larger 5/16-18 bolts get 132 inch pounds. Just in case you were wondering, the drain plug is 25 foot pounds.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline   Reply With Quote
Glock Forum
