Torque Spec for Dana 35 Carrier Bearing Caps - JeepForum.com
post #1 of 16 Old 01-16-2009, 06:47 PM Thread Starter
01TJfuntime
All in the title. 1997 Dana 35 c-clip axle, whats the torque spec for the bearing caps??
01TJfuntime is offline
post #2 of 16 Old 01-16-2009, 06:54 PM
19OlllllllO41
19OlllllllO41's Avatar
80ft/lbs according to the service manual.
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
post #3 of 16 Old 01-16-2009, 06:56 PM Thread Starter
01TJfuntime
Can I get a verification? I thought I read somewhere it was less. Thats the Dana 35 rear, not 30. Sorry to be nitpicky.
post #4 of 16 Old 01-16-2009, 07:05 PM
19OlllllllO41
Confusing part (from my 99 wrangler factory service manual)...
Says the "216 RBI axle" is 80 ft/lbs.
Says the "194 RBI axle"is 57 ft/lbs
Doesn't refer to either as a Dana 35, 44, etc. So maybe the 194 is the Dana 35, and the 216 is the Dana 44?
Edit: also says the "181 FBI axle" is 45ft/lbs (assume this is the Dana 30)
Sorry about the confusion!
The Present:
'04 WJ
'46 CJ2A
The Past:
post #5 of 16 Old 01-16-2009, 07:25 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
181 axle = Dana 30
194 axle = Dana 35c
216 axle = Dana 44.
The bearing caps for the Dana 35c are indeed tightened to 80 ft-lbs. Make darned sure to reinstall the bearing caps exactly as they came off... left vs. right and that the they go on facing the same direction as they came off... the end that was on top needs to be reinstalled on the top.
Jerry Bransford is offline
post #6 of 16 Old 01-16-2009, 08:46 PM Thread Starter
01TJfuntime
Okay, so I have a bit of conflicting information here.
Indeed the 194 RBI is the dana 35, 216 is a Dana 44 and so on
But,
According to Jerry, the dana 35 bearing caps need to be tightened to 80 ft-lbs, however, TJeep99 says the dana 35 (194 RVI) bearing caps are to be torqued to 57 ft-lbs.
Once again, sorry if this is redundant, but it is of critical importance that I get an accurate torque spec.
So, what is it 80 ft-lbs or 57 ft-lbs?
Thank you.
post #7 of 16 Old 01-16-2009, 09:04 PM
19OlllllllO41
Looking at the 1999 Wrangler factory service manual right now, it says
"194 RBI AXLE" Bolt, Bearing Cap 77 N.m (57 ft. lbs)
The Present:
'04 WJ
'46 CJ2A
The Past:
post #8 of 16 Old 01-17-2009, 10:32 AM
Jerry Bransford
Administrator
Well that's damned odd, my '97 manual definitely says 80 ft-lbs. for the 194 RBI axle's bearing cap bolts.
Here's the part of the page out of the manual just scanned...
post #9 of 16 Old 01-17-2009, 06:33 PM
Jacon
But,
Thank you.
I sent you what you need.....
Jacob
Jacon is offline
post #10 of 16 Old 01-18-2009, 12:35 AM Thread Starter
01TJfuntime
so guess what I did.
Looks like I have to open the case again and re-torque to 80 ft-lbs.
I did do some driving, 1.7 miles just to get a feel for how the 4.11 gears handle (Im doing a 4cylinder axle swap)
Now the question is, do you think I did any damage driving with those bearing caps torqued to 57 ft-lbs?
post #11 of 16 Old 01-18-2009, 11:23 AM
Jerry Bransford
Administrator
Nope, you'll be fine.
post #12 of 16 Old 01-18-2009, 06:19 PM
19OlllllllO41
Well let the confusion continue..... So to prove to you guys that Im not crazy or seeing things, I just scanned the page out of my 1999 Wrangler Manual with the 57 ft/lbs spec.....
The Present:
'04 WJ
'46 CJ2A
The Past:
post #13 of 16 Old 01-18-2009, 08:01 PM Thread Starter
01TJfuntime
Yeah that's nuts. I have a 2001, but the axles I put in my Jeep were from a 1997 SE model. I opened the case again today and torqued all four of the bearing cap bolts to 80 ft-lbs. Weird that there are different specs for different years. Since I have 1997 axles I just went with the spec for that year. But for future readers you may want to double check with the FSM to make sure you get the correct torque spec for your particular model year. Its not like your torquing a skid plate nut or a body mount, I feel that differential carrier bearing caps NEED to be torqued correctly to their respective specification. Sorry if I stumped any of the veterans
By the way, 4.11 gears kick it. Huge difference from 3.07. Yeah its a dana 35, but I got spare shafts and only run 31s. Jeepforum rules!!!
post #14 of 16 Old 01-18-2009, 09:10 PM
bfr
bfr's Avatar
fwiw it is still 57lbs in the 03 fsm
bfr is offline
post #15 of 16 Old 02-17-2009, 11:38 PM
mrtosh
2005 WK
Not to threadjack, but does anybody know what the torque specs would be for the bearing caps on a Dana 30(front) in a '98 xj?
'05 WK Limited QDII, Superlift 6", Bilstein struts,315/70/17 Duratracs, Gibson CB, Volant CAI, JBA UCA's, JKS quick disco, adj. Rear trac bar, 4xguard armor, Diablosport Intune, Xenondepot 6000k HID's, Putco Jet yellow fogs.
mrtosh is offline
Dana 35 torque spec for yoke cody11ca YJ Wrangler Technical Forum 12 09-07-2013 12:38 AM
So I mixed up my differential carrier bearing caps... Douglas S. YJ Wrangler Technical Forum 2 08-08-2009 07:55 PM
What torque for D30 bearing caps Robbypfd YJ Wrangler Technical Forum 1 06-11-2009 07:48 PM
torque specs on dana 30 bearing caps??? eng4safd YJ Wrangler Technical Forum 2 03-19-2007 05:44 PM
Anyone, Torque specs dana 35 (non c clip) Bearing Caps mde YJ Wrangler Technical Forum 2 01-16-2005 09:14 PM
