Torque on Gas Tank Retaining Straps - TJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Torque on Gas Tank Retaining Straps - TJ
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 08-06-2010, 05:53 PM   #1
n1ml
I am putting in a new gas tank supporting pan in my 1997 TJ. When I replaced the two straps that go over the gas tank in the new pan, the bolts do not go through the pan as far as the originals did. The bolts go on about 1/2" rather than the 1 1/2" of the original. How tight should I make therse bolts. The last thing I want to do is crush the plastic gas tank.
n1ml is offline   Reply With Quote
Unread 08-06-2010, 06:56 PM   #2
BYuen
I tightened my straps down snug just before I noticed any significant deformation of the tank. It's alright if you "crush" the tank a little bit. The plastic walls of the tank are fairly thick and are very malleable. The tank will also return to it's original shape once removed from any pressure creating a deformity. People have gas tanks crushed in all the time from bent stock skid plates even enough so to reduce the fuel capacity by a gallon or two.
BYuen is offline   Reply With Quote
straps , gas tank , tj , wrangler
