Torque Converter Solenoid problem, wont shift into gear
#1 | |
I have a '97 4 cyl. TJ 2.5SE (unfortunatly automatic) I just got with a Torque Converter Solenoid problem that Im trying to fix, but I cant find any info on where its located or how to fix it. It can idle fine but as soon as its shifted into drive it stalls out. Anyone else have this problem? Ive seen a few sites around saying its kind of a common problem but no one has a straight answer on how to fix it. Previous Owner Dropped that transmission pan and replaced the tranny fluid and it worked for about 4 hours but the next day it had same problem. I bought it cheap thinking I could fix it but its turning out to be a bit of a hassle. Any tips or instructions or directions on where its even located would be helpful - thanks.
#2 |
want it rite or rite now?
the solenoid is under the pan bolted to the valve body...
unplug the electrical connector on the side of the transmission, that will prevent the clutch from locking without diabling the vehicle. the convertor it'self could also be a problem.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
