Quantcast Top front shock mount problems....... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Top front shock mount problems.......
GR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent Prices
Old 05-12-2007, 02:08 PM   #1
GeoSojdaTJ
Well my top front shock mount do not want to cooperate.........they just won't budge, i'm afraid to strip the stud out......any ideas besides cutting them???
Oh and i did hit them with wd-40, pb-blaster etc......
/ | ,[___],
1---L-OlllllllO-
()_)()_)--)_)
Originally Posted by ytodd
I hear ya brother. I don't even bother hauling my recovery gear around on trips I don't schedule to get stuck on. This weekend my tools will be at home since no breakage is on the calendar.
GeoSojdaTJ is offline   Reply With Quote
Old 05-12-2007, 02:40 PM   #2
edzakory
I had the same problem when I removed my front shocks. When you turn the nut, the stock stem rotates thereby preventing the nut from loosening.
I was able to get vice grips on the shock stem and this prevented the stem from rotating allowing me to remove the nut. The passenger side was more difficult. I had to cut the rubber bushing and remove it before I was able to have enough clearance to clamp the stem. The fuse box is on this side so you can not use the hole in the fender for a socket extension to loosen the nut from the top.
On the driver's side, I used a pneumatic air wench with socket extension so the job was easier on that side.
edzakory is offline   Reply With Quote
Old 05-12-2007, 03:26 PM   #3
TJ_Firefighter
mine were bad off, i tried vise grips but finally had to grind 2 flat spots on the strut to prevent it from turning, on the passenger side i had to remove the air box to gain access to the hole so i could use extensions and a ratchet
1999 TJ
4.0L
2" BB 2"BL, ProComp Adj. Front Track-bar, SkyJacker Hydro 7000 shocks
33x12.50 Dunlop RV
[B][COLOR="Wheat"]Kahki Jeep Club Member #42[/COLOR][/B]
[COLOR="White"][B] U.[COLOR="Orange"]S.C.G[COLOR="White"]. J[COLOR="Blue"]ee[COLOR="White"]p Club Member #1[/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/B]
[COLOR="Red"][B]Firefighting Jeep #2[/B][/COLOR]
Soon to come: HomeFab Rockers
TJ_Firefighter is offline   Reply With Quote
Old 05-12-2007, 03:35 PM   #4
GeoSojdaTJ
my major problem is that i can't get the nut moving without the stem moving too..........i'm not reusing these shocks so breaking them is in play
and thanks for ideas guys...i'll let ya know how it turns out
/ | ,[___],
1---L-OlllllllO-
()_)()_)--)_)
Old 05-12-2007, 03:38 PM   #5
TJ_Firefighter
cut the plastic off from around the top half of the shock if that's not already done....vise grips or anything else you can think of from there
1999 TJ
4.0L
33x12.50 Dunlop RV
Old 05-12-2007, 03:40 PM   #6
GeoSojdaTJ
tried that and the damn thing is still turning, guess i will try to find a way to grind it down....don't have a angle grinder though.................
/ | ,[___],
1---L-OlllllllO-
()_)()_)--)_)
Old 05-12-2007, 03:45 PM   #7
TJ_Firefighter
yea, i think a grinder or a dremel or something is about where you're at now....some others have said cut the strut and pull it up through the frame mount like that not sure how easy or hard that is though
1999 TJ
4.0L
33x12.50 Dunlop RV
Old 05-12-2007, 05:55 PM   #8
sa_9933
2004 KJ Liberty
i had to use Channel locks and sqeeze the Snot out of the stem, then use a open end wrench to get the nut to loosen...once it goes it doesn't take much, just that intitial turn.
Now let's see what happens when you use the OTHER guy's brake pads.....
sa_9933 is offline   Reply With Quote
Old 05-12-2007, 05:57 PM   #9
sa_9933
2004 KJ Liberty
ps....if you're having problems with the top front...i would soak the piss out of the top Rear for like two or three days....the only parts on my jeep that i didn't hit with PB blaster and i snapped three of the four bolts, then had to spend twelve hours drilling them out with various size drill bits....Sucked Balls
Old 05-12-2007, 06:26 PM   #10
rljsrubicon
Advance Auto
Universal Shock Nut Tool Set
AmPro#T72025
$6.95
...Ron
rljsrubicon is offline   Reply With Quote
Glock Forum
