Quantcast Top front shock mount....again - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Top front shock mount....again
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.com
Old 05-13-2007, 11:29 AM   #1
GeoSojdaTJ
Ok heres the deal, i can't get the top shock mount off......the nut just won't turn....i've grinded, pb blasted and everything else i can think of........
SO can i cut the strut and then be able to just pull it out through the hole in the engine bay? Where should i try to cut it if i can? thanks for the help in advance
/ | ,[___],
1---L-OlllllllO-
()_)()_)--)_)
Originally Posted by ytodd
I hear ya brother. I don't even bother hauling my recovery gear around on trips I don't schedule to get stuck on. This weekend my tools will be at home since no breakage is on the calendar.
GeoSojdaTJ is offline   Reply With Quote
Old 05-13-2007, 12:43 PM   #2
TJ on the Rocks
Sure You can cut it .
Last September when I installed my lift & shocks I had the same problem .
I ended up grinding the nut about 1/2 way through .
With the heat from grinding and the loss of material , it ( the nut ) basically just fell off after that .
[SIZE="7"][SIZE="7"][SIZE="5"][URL="http://www.atozfabrication.com/catalog/"][B][CENTER][SIZE="5"][COLOR="Red"]AtoZ F[/COLOR][COLOR="White"]abric[/COLOR][COLOR="Blue"]ation
[/COLOR][/SIZE][/CENTER]
[CENTER][B][/SIZE]
[SIZE="4"][/URL][/B][COLOR="Red"][/SIZE][/SIZE][SIZE="3"][URL="http://www.stickylee.com/catalog/index.php"]www.stickylee.com[/URL][/COLOR][/SIZE][/B][/CENTER][/SIZE]
TJ on the Rocks is offline   Reply With Quote
Old 05-13-2007, 01:13 PM   #3
jzmtl
If you are talking about cut the rod, you still have the stone guard attached to the rod below and the nut above the shock tower, no?
Just cut between the nut and upper bushing.
jzmtl is offline   Reply With Quote
Old 05-13-2007, 01:15 PM   #4
SMACC
I used a ginder to flatten the sides of the shaft so a wrench could grab hold and turn it.
[COLOR=Navy]Purchased New May 14,2005
2005 Wrangler Rocky Mountain Edition,
Patriot Blue
4.0 Liter, 6-Speed, Dana 44, 3.73
Rubicon Express 2" Budget Boost
TeraFlex Swaybar Quick Disconnects
Kilby Onboard Air Compressor
XM/AM/FM/CD
Hidden Hitch 2" Receiver
Olympic Light Bar
1978 M416 1/4 Ton Trailer
Patriot Blue Jeep Club Member #4[/COLOR]
SMACC is offline   Reply With Quote
Old 05-13-2007, 03:51 PM   #5
GeoSojdaTJ
YEAH!! i finally got em off!!!!! Thnk god my buddy randomly showed up and gave my an idea.....I used a sawsall and cut the bastards out.....duh.....should have thought of that yesterday afternoon...........anyway thanks to everone for the help!!
/ | ,[___],
1---L-OlllllllO-
()_)()_)--)_)
Old 05-17-2007, 10:13 PM   #6
jimj911
If you don't plan on using them again, you would be surprised how easily you can break them off. Jus t grab the shock and bend it back and forth. Usually just four or five times back and forth and . . . POP . .. They're off!
Thanks,
Jim
Uh, yeah the dirty jeep's mine.
jimj911 is offline   Reply With Quote
Old 05-17-2007, 10:15 PM   #7
TJ on the Rocks
Well , look who it is !
Look me up if Ya wanna do some "real" wheeling
[CENTER][B][/SIZE]
Glock Forum
