Tools, knowledge to install 3" Full Traction lift
#1 | |
I'm planning on getting the 3" FT economy suspension lift here:
http://www.northridge4x4.com/proddetail.php?prod=FTS-7503 and some new FT shocks with the kit. I plan on doing the install myself (but never done one before) and was wondering if there is any additional hardware that I need to purchase with the kit/shocks. Also, what special tools will I need to line up in advance? I've searched the heck out of the forum and got a few ideas. I was wondering if anybody had created a comprehensive list of necessary stuff that they could post or send me. Does anybody know how good the instructions are that come with this or of a good install write-up on the net for this kit. I found a wirte-up on a 3.5" RE install through another thread here, which has helped me a lot. Thanks.
#2 |
Demonic Jeep Freak!
.......................misread.
#3 |
large jack stands ,basic had tools , a good floor jack, drill , and a 9/16 drill bit( I think that was the size)and a friend, it will make it allot easier with 4 hands. The instructions aren't that bad. Good luck
Gone but not forgot. 2000 Sahara 4.0, auto, 4"rock krawler x factor long arm, 33x12.50x15 M.T. Mtz, M.T. classic lock rims,30/44 limited slip, land runner safari rack, land runner front, and rear bumpers, warn 8000i winch, cobra cb, jks 1.25" bl, brown dog 1" mm lift.AA sye, J.E. Reel drive shaft, Aussie locker, Rock Crusher front cover |
#4 |
If you can't jack up your vehicle enough to drop the axle to manually remove the springs then you will need a set of spring compressors. I had to disco my front LCAs to get them in.
The instructions tell you to disco the front driveshaft and that's something I did not have to do at all. Also, you're instructed to put the bumpstop extensions before you install the springs, which is a bit foolish because it's so much easier to finish installing them after the springs are on (unless you have some kick arse spring compressors). See here and here and here http://www.jeepforum.com/forum/f9/full-traction-roll-call-questions-506238/ http://www.jeepforum.com/forum/f9/help-3-full-traction-lift-488918/ http://www.jeepforum.com/forum/f9/full-traction-3-lift-drill-bit-468794/ http://www.jeepforum.com/forum/f9/those-who-have-installed-full-traction-lifts-418195/ http://www.jeepforum.com/forum/f9/full-traction-installation-help-365931/
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times. |
#5 |
Do it right or not at all
![]() Join Date: Jan 2003
A pair of 6 ton jack stands (3 ton jack stands are strong enough but not tall enough) and a floor jack would be good to have. If you have a Harbor Freight Tools store close by you can get those there pretty cheap. A set of 1/2" drive sockets will be required, with 3/8" drive sockets being nice to have for a few spots like when you're doing the lower shock mounts. Also a good selection of combination open-end/box-end wrenches would be good. For the suspension, my '97 TJ uses mixed SAE/metric size hardware but newer TJs are mostly metric. Having both would be best of course.
You should not need a spring compressor. By disconnecting the shocks, antiswaybar links, and trackbar, the axle should droop down enough to get the springs in and out. You can get the axle to droop by supporting the Jeep via the 6 ton jackstands under the frame. Once the Jeep is jacked up via the axle, insert the jack stands. Then once you have everything disco'd, you can lower the axle down via the floor jack and the springs should be loose at that point.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#6 |
This is a simple thing to complete. I did mine over two days by myself. Take your time and depending on the age/condition of your jeep you may want to spray all the bolts with some type of liquid wrench to help loosen them up.
A good set of Torx head sockets will be needed. I think I used 50 and 55. I had to buy the 55 because my set did not come with it. The hardest part was getting the bushings and bars in the shocks!!! If you have a vise or bar clamps this task is much easer. I left the LCA's attached but did need to insert the stock jack between the frame and axle to help get enough room for the front spring to be placed in without a compresser. Good luck and just take your time and make sure to retorque all the bolts & CA'a once completed. |
#7 | |
Now in the 937
Look in my sig and go to my build thread. For some of the "tougher" parts of the install it's practically a how-to on pages 2-3 IIRC.
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase Build thread here. Quote:
Pictures of it wheeling at Bill's 491 And more pics from that trip here! |
#8 |
I am by no means an expert at any of this, but this just sounds like a terrible idea to me. I know I for one would be scared ****less doing that!
#9 | |
#10 |
That kit is much cheaper here... http://www.4wheelparts.com/prodDetail.aspx?partNo=FULFT7503&jeep-parts=true
Any word on the quality of these kits? I read some posts about sagging.
'98 TJ Sahara 3" Full Traction Economy spring lift 33X10.5 BFG M/Ts Outlaw I wheels w/3.75" Backspacing |
#11 |
Great Info!
Thanks for the links BlackBellamy, those are good threads.
Jerry, great tool info. I'm ordering the kit this morning. |
#12 |
I just ordered the kit a few minutes ago at... http://www.4wheelparts.com/prodDetail.aspx?partNo=FULFT7503&jeep-parts=true
It's on sale for today and MAYBE tomorrow. It cost me $346.49 for the kit, $31.94 tax and $54.00 shipping for a grand total of $432.43. If it's as good as you guys are saying I think I'm going to love it. I just wish I knew what it is going to look like with my 31"s. I still need to order shocks but don't know anything about them. Time to start reading about shocks I guess. I'm excited!
#13 |
Commonly pushed shocks to avoid would be ProComp ES-3000, Skyjacker Nitro, Rubicon Express twin-tubes, and Rancho R5000, all four of those are too stiff riding for a Wrangler. Good riding shocks include OME (Old Man Emu), Skyjacker Hydros, or Rubicon Express Monotubes. If you're not careful on your shock choice, your TJ can end up riding like a buckboard wagon.
#14 | |
If this is getting off-topic please feel free to PM me. Thanks for your advice.
#15 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
