Too hot to drive - Page 2 - JeepForum.com
post #16 of 25 Old 07-10-2012, 07:53 AM
JWebber
Lizardskin is a cool paint on product that you can use on driver side tub area by the exhaust.
JWebber is offline
post #17 of 25 Old 07-10-2012, 08:10 AM
ShakaBrahTJ
Originally Posted by Randomdude735 View Post
Just wanted you all to know that the diverter door thing fixed the problem!!!! The picture also helped a lot!! My wife is very please with all of you!! Thanks again for your help. I'm going to put insulation down as well to help with the heat around the transmission. Thanks again!
Hey Randomdude, what exactly did you do to fix it? I need to know as well.
ShakaBrahTJ is offline
post #18 of 25 Old 07-10-2012, 10:28 AM
butch97
Glad you fixed it, thanks!
butch97 is offline
post #19 of 25 Old 07-12-2012, 03:34 PM
ShakaBrahTJ
Originally Posted by Wheelin98TJ View Post
The blend door is likely stuck on hot.
Slide the lever while watching the arm circled below.
If the arm does not move, you can move it by hand over to cold as a temporary fix.
Attachment 427838
Hey Wheelin98TJ, I'm having the same problem as Randomdude, however, I checked and the arm and it does move when I slide the lever. Pretty sure it's going to be related to this, because I feel warm air coming from the floor vents. Any other ideas? I was curious what Randomdude did exactly to fix his.
post #20 of 25 Old 07-12-2012, 03:48 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
That is bad news.
I think you need to pull the dash so you can crack open the heater box. It sounds like your blend door has become unattached from the lever arm, the arm you see that is still moving.
I've never dealt with your specific issue first hand, so I'd recommend you do a little more research on the forum here to verify what I'm saying.
Wheelin98TJ is offline
post #21 of 25 Old 07-12-2012, 05:35 PM Thread Starter
Randomdude735
Well, it was easy.... I just flipped the lever in the picture and the heat stopped. I guess I got lucky.
Randomdude735 is offline
post #22 of 25 Old 07-12-2012, 05:53 PM
TJ-Tera
I have some experience in this area, so hopefully I can shed some light on it. If you have a 1997 (or even up to a mid year 1998 like mine) then you have mechanical sliders as opposed to electrical HVAC control knobs which began to appear in 1999 models (or some late year 1998 production runs). When pushing the slider and no change happens to the white knob in the picture (under the dash) then most likely the steel cable is disconnected or broken as in my case.
Also, even after I replaced my steel cable it may not fix the problem because there is a small green connector on the bottom of the blower motor which the cable attaches to. Mine is broken, so I have to replace this as well.
Hope it helps.
TJ-Tera is offline
post #23 of 25 Old 07-12-2012, 09:26 PM
ShakaBrahTJ
That is bad news.
I can see it moving and I feel a huge temperature change when I go between hot and cold. And my cab wasnt getting as hot as Randomdude's going down the road. I'm guess it's just not closing all the way or something. I appreciate you getting me in the right direction.
post #24 of 25 Old 07-12-2012, 09:27 PM
ShakaBrahTJ
Cool. I just wasn't sure if you had to do a whole bunch of mechanic stuff to it.
post #25 of 25 Old 07-12-2012, 09:32 PM
ShakaBrahTJ
Hope it helps.
Thanks greenone. I do in fact have the cable set up you described. But the cable is still connected and the arm does move to shut the diverted door. I also can tell huge temperature changes when I go between hot and cold. I really only notice the heat when I drive down the road with the fan off. I can feel a warm "breeze" coming from the floor vents. I believe now the diverted door just isn't shutting all the way.
Thanks for the help. I'll hit you guys back if I can't get it.
dash , heat , hot
Can I remove the front drive shaft and still drive around? CobraKhan TJ Wrangler Technical Forum 58 11-12-2014 04:28 PM
I have a drive shaft problem=2 drive shafts in less than one week!!!!!! machoman YJ Wrangler Technical Forum 14 12-24-2010 08:39 PM
jeep drives in reverse but doesnt drive in drive sifuentesjeeps YJ Wrangler Technical Forum 2 12-20-2010 10:26 AM
YJ front drive spinning/posi-lock/no 4 wheel drive bdfletch YJ Wrangler Technical Forum 7 11-09-2009 10:58 PM
Drive Line Noise when Warmed up from extended drive amytom TJ Wrangler Technical Forum 1 02-26-2009 02:11 PM
