Too hot to drive - JeepForum.com
post #1 of 25 Old 07-04-2012, 06:30 PM Thread Starter
Randomdude735
Too hot to drive
Ok, this is an annoying problem. When I drive my 1997 with top off, I get an amazing amount of heat coming from under the dash. Mild weather or hot weather it is the same. The heat and air are turned off, but its like a blast furnace coming from under the dash. I checked the fire wall and can not find any openings or holes.
It was over a hundred today and I made the mistake of driving my family across town. Any thoughts as to what might be causing this?
Its a 97 4.0 5 speed.
Randomdude735 is offline
post #2 of 25 Old 07-04-2012, 06:50 PM
wushaw
Rockin jeep
wushaw's Avatar
Floor heat from heater core. You probably have a diverter door not closing.
wushaw is offline
post #3 of 25 Old 07-04-2012, 10:44 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Also, the Trans tunnel gets hot as heck just from the engine and Trans.
ratmonkey is offline
post #4 of 25 Old 07-05-2012, 06:37 AM
JEK3
JEK3's Avatar
Yep, it's a Jeep thing. I lessened the problem in mine by taking a towel and shoving it up between the center of the dash and the top of the tunnel, forward of the shifter. I made sure the floor vents weren't covered. Worked very well keeping my feet/calves from roasting.
JEK3 is offline
post #5 of 25 Old 07-05-2012, 07:22 AM
hustler905
Have you removed the carpet or floor plugs?
hustler905 is offline
post #6 of 25 Old 07-05-2012, 07:38 AM
JBTJ
No, I wouldn't say that. None of my JEEPS do or have ever done that. Like said, probablly the diverter door is not closing.
JBTJ is offline
post #7 of 25 Old 07-05-2012, 07:52 AM
JEK3
JEK3's Avatar
I'll have to look into that. It is a Jeep thing, in that Jeeps are susceptible to it.
JEK3 is offline
post #8 of 25 Old 07-05-2012, 09:09 AM
clintrivera
If the heat is radiating through the sheet metal there are materials you can apply the to metal to shield the heat. Some also serve as sound deadening, so you get two benefits.
Like this http://www.jegs.com/p/Eastwood/Eastw...07471/10002/-1
clintrivera is offline
post #9 of 25 Old 07-05-2012, 09:28 AM
JeepGoat78
I believe there is also a ceramic heat reducing paint you can apply on the tunnel to help with this. I read about it on these forums but can't seem to remember the name of it.
~Goat~
Home made TJ trunk with soft window storage and a sub-woofer:
http://www.jeepforum.com/forum/f37/my-tj-trunk-storage-sub-1397268/
JeepGoat78 is offline
post #10 of 25 Old 07-05-2012, 09:36 AM
ShakaBrahTJ
I'm having the same issue with my 1997, but apparently not as bad. Felt like to me the heat was coming out of the floor vents (heater), although it was off.
ShakaBrahTJ is offline
post #11 of 25 Old 07-05-2012, 09:49 AM
JBTJ
You would think that if it were a case of heat radiating in through the tub that all JEEPS would have that issue. Since not all JEPS have that issue it must be the diverter door not closing.
JBTJ is offline
post #12 of 25 Old 07-05-2012, 04:22 PM Thread Starter
Randomdude735
Thanks to everyone for the advice! I'm going to check the diverter door and put some insulaton on the floor and firewall. the factory carpet has been removed and a hard plastic surface had been installed. Thanks again. I will let you know if all of this helps.
post #13 of 25 Old 07-06-2012, 08:14 AM
ShakaBrahTJ
Yes, let us know the outcome. Because I'll apparenlty be doing the same thing.
post #14 of 25 Old 07-06-2012, 08:19 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The blend door is likely stuck on hot.
Slide the lever while watching the arm circled below.
If the arm does not move, you can move it by hand over to cold as a temporary fix.
Wheelin98TJ is offline
post #15 of 25 Old 07-10-2012, 05:16 AM Thread Starter
Randomdude735
Just wanted you all to know that the diverter door thing fixed the problem!!!! The picture also helped a lot!! My wife is very please with all of you!! Thanks again for your help. I'm going to put insulation down as well to help with the heat around the transmission. Thanks again!
dash , heat , hot
Can I remove the front drive shaft and still drive around? CobraKhan TJ Wrangler Technical Forum 58 11-12-2014 04:28 PM
I have a drive shaft problem=2 drive shafts in less than one week!!!!!! machoman YJ Wrangler Technical Forum 14 12-24-2010 08:39 PM
jeep drives in reverse but doesnt drive in drive sifuentesjeeps YJ Wrangler Technical Forum 2 12-20-2010 10:26 AM
YJ front drive spinning/posi-lock/no 4 wheel drive bdfletch YJ Wrangler Technical Forum 7 11-09-2009 10:58 PM
Drive Line Noise when Warmed up from extended drive amytom TJ Wrangler Technical Forum 1 02-26-2009 02:11 PM
