-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Too hot to drive (http://www.jeepforum.com/forum/f9/too-hot-drive-1389130/)
Randomdude735 07-04-2012 07:30 PM
Too hot to drive
Ok, this is an annoying problem. When I drive my 1997 with top off, I get an amazing amount of heat coming from under the dash. Mild weather or hot weather it is the same. The heat and air are turned off, but its like a blast furnace coming from under the dash. I checked the fire wall and can not find any openings or holes.
It was over a hundred today and I made the mistake of driving my family across town. Any thoughts as to what might be causing this? :(
Its a 97 4.0 5 speed.
wushaw 07-04-2012 07:50 PM
Floor heat from heater core. You probably have a diverter door not closing.
ratmonkey 07-04-2012 11:44 PM
Also, the Trans tunnel gets hot as heck just from the engine and Trans.
JEK3 07-05-2012 07:37 AM
Yep, it's a Jeep thing. I lessened the problem in mine by taking a towel and shoving it up between the center of the dash and the top of the tunnel, forward of the shifter. I made sure the floor vents weren't covered. Worked very well keeping my feet/calves from roasting.
hustler905 07-05-2012 08:22 AM
Have you removed the carpet or floor plugs?
JBTJ 07-05-2012 08:38 AM
No, I wouldn't say that. None of my JEEPS do or have ever done that. Like said, probablly the diverter door is not closing.
JEK3 07-05-2012 08:52 AM
I'll have to look into that. It is a Jeep thing, in that Jeeps are susceptible to it.
clintrivera 07-05-2012 10:09 AM
If the heat is radiating through the sheet metal there are materials you can apply the to metal to shield the heat. Some also serve as sound deadening, so you get two benefits.
Like this http://www.jegs.com/p/Eastwood/Eastw...07471/10002/-1
JeepGoat78 07-05-2012 10:28 AM
I believe there is also a ceramic heat reducing paint you can apply on the tunnel to help with this. I read about it on these forums but can't seem to remember the name of it.
ShakaBrahTJ 07-05-2012 10:36 AM
I'm having the same issue with my 1997, but apparently not as bad. Felt like to me the heat was coming out of the floor vents (heater), although it was off.
JBTJ 07-05-2012 10:49 AM
You would think that if it were a case of heat radiating in through the tub that all JEEPS would have that issue. Since not all JEPS have that issue it must be the diverter door not closing.
Randomdude735 07-05-2012 05:22 PM
Thanks to everyone for the advice! I'm going to check the diverter door and put some insulaton on the floor and firewall. the factory carpet has been removed and a hard plastic surface had been installed. Thanks again. I will let you know if all of this helps.
ShakaBrahTJ 07-06-2012 09:14 AM
Yes, let us know the outcome. Because I'll apparenlty be doing the same thing.
Wheelin98TJ 07-06-2012 09:19 AM
1 Attachment(s)
The blend door is likely stuck on hot.
Slide the lever while watching the arm circled below.
If the arm does not move, you can move it by hand over to cold as a temporary fix.
Attachment 427838
Randomdude735 07-10-2012 06:16 AM
Just wanted you all to know that the diverter door thing fixed the problem!!!! The picture also helped a lot!! My wife is very please with all of you!! Thanks again for your help. I'm going to put insulation down as well to help with the heat around the transmission. Thanks again!
The time now is 02:24 AM.
