Tommy's Jeep Build Journal - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Tommy's Jeep Build Journal
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 10-17-2007, 02:28 PM   #16
Tommy R
I didn't like the way the Jeep handled. The "spool jacking" thing was not good. But, here's the $64 question....
Was the problem the spool? Or was it the short arm lift?
Well, to answer that question all I had to do was look at our guide's TJ. It had a basic long arm lift from Teraflex. It only had long lowers. But he was running a spool. His Jeep exhibited NONE of the goofy characteristics of my Jeep. Sure, I would likely be okay with a full Detroit, but the problem will still come up (pun) from time to time with a locker. The long term answer is a long arm lift.
However, money is still tight and a long arm lift would likely cost me $1600+ after I would sell my current lift. Too much moolah for me. It was then that Lance's (geauxturbo) write-up enticed me. He'd copied the Clayton long arm lift and I'm doing the same! So far I've ordered and received the bushings, Johnny Joints, and hardware. I'm just waiting on the steel to be ready to be picked up and the Rubicon Express bushing sleeves to be delivered. This should all be within this week.
Next week, the fabrication begins!!!
2001 Wrangler - homemade long arm, 4.56s, 35" MTRs, D30/Lock Right/alloys, D44/ARB/35 spline alloys
My Jeep Build Journal
Tommy R is offline   Reply With Quote Quick reply to this message
Unread 10-17-2007, 02:42 PM   #17
tweba99
Sounds like a fun project. You could also get some shorter springs to help you out. It looks like you have to much room in the wheel wells for the tires you are running and that would help with you Jeep leaning so much since it is top heavy right now.
1999 Jeep TJ on 1 tons (OLDER)
2003 Jeep Rubicon (OLD)
2008 Jeep Unlimited X (NEW)
tweba99 is offline   Reply With Quote Quick reply to this message
Unread 10-17-2007, 02:48 PM   #18
Tommy R
Yeah, I wouldn't mind dropping it another inch, but long term I plan on running 36s or 37s in which case the lift I've got should be just right. But like you said, I may still drop it a bit in the meantime and lift it again when the time comes.
BTW, I read your entire thread on your build and it was great stuff! Fantastic job!
Tommy
Unread 10-17-2007, 02:57 PM   #19
tweba99
Tommy
Thanks. You are right, I was running 4.5 springs with my 37's so if you plan to step up then you will be fine. I am running 39.5's now on my same 4.5 springs.
Unread 10-17-2007, 03:11 PM   #20
Tommy R
And they bolted right up, too? Awesome!!!
My buddy is running a D30 up front with a Lock Right and alloy axles. Based on how his rig does with that setup I'll make the decision to stick with the "small" tires or sell them and step up to some 37s. Time will tell and I'm in no rush.
Unread 10-17-2007, 03:24 PM   #21
tweba99
Right.
It depends on how you drive. I ran my 37's with a stock dana 30 with an aussie locker and chromo'd Dana 44 with a full detroit and I never broke anything. I was easy on the pedal and tried not get my front tire bound up while turning.
Unread 10-17-2007, 04:17 PM   #22
Tommy R
You sound exactly like me! I've always been pretty gentle on equipment so I suspect I'll be fine with the D30 with 37s....especially if I put stout axles and u-joints in there.
Unread 11-07-2007, 12:04 AM   #23
Tommy R
Here's a little write-up on why I decided to remove the spool and install a full Detroit in its place.
Unread 11-07-2007, 12:33 AM   #24
ImSuck
wow nice wrangler tommy, if you ever get a chance to come down to spring send me a pm and we can head out to spring creek
-Andrew
Low Output 4 Cylinder Jeep Club member #59
[QUOTE=Grewe02]No such thing. Eat **** and die.[/QUOTE]
lifted with some extra's
......sold
ImSuck is offline   Reply With Quote Quick reply to this message
Unread 11-09-2007, 01:04 PM   #25
Tommy R
Wednesday night I removed the spool and installed the Detroit. The Detroit certainly has it's "nuances", but so far I prefer it to the spool.
Thursday morning I replaced the fuel pump. The old one was making bad racquet. Fires first time every time now!!
Unread 11-09-2007, 01:05 PM   #26
Tommy R
Will do!
Unread 11-11-2007, 12:43 AM   #27
Tommy R
Went wheelin' today in Bastrop with the local Jeep club. Really tight, very technical trails...
Pics are right here.
Here's a few.....
Unread 11-14-2007, 11:12 PM   #28
Tommy R
I made mine a lot louder. Cut the muffler off and welded in a turndown to make clearance for the triangulated 4 link I'll build....hopefully soon!
Re-used the OEM flange and tailpipe:
It's too loud and "trashy" sounding to keep fulltime, but for the interim it'll work until I can determine how much muffler clearance I'll have with the new suspension.
Tommy
Unread 11-15-2007, 08:05 AM   #29
98tjsahara
Is that a public Jeep trail in Bastrop? I've been looking for a place to wheel but it seems there arnt any around me. Bastrop would be the closest so far.
Sold the 98 TJ Sahara. Buying another Jeep soon!
98tjsahara is offline   Reply With Quote Quick reply to this message
Unread 11-15-2007, 01:07 PM   #30
Saisling
I've enjoyed reading the thread so far. You are right, tires and flares in the beginning made a drastic difference and it just keeps getting better. Sweet ride.
Partial hijack, but if you wouldn't mind, could you give me some more details on the top hoist you made? Anymore pictures? Specifically, how is your frame built to hold the top.
I really need to get a hoist rather than depend on friends to help me with my top... I'm just sure I can do it cheaper than the $190 or so it would cost to buy one outright.
Saisling is offline   Reply With Quote Quick reply to this message
