-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Tommy's Jeep Build Journal (http://www.jeepforum.com/forum/f9/tommys-jeep-build-journal-474732/)
Tommy R 10-17-2007 10:05 AM
In April of 2007 I picked up this Wrangler TJ from a local seller. He was the original owner and needed a truck so it was up for sale. Here's a pic of what it looked like the first day I saw it....
http://www.supermotors.net/getfile/5...ow2001_011.jpg
http://www.supermotors.net/getfile/5...ow2001_016.jpg
http://www.supermotors.net/getfile/5...ow2001_042.jpg
(And no, it didn't come with the cup of tea) ;)
It was cosmetically "okay", but had a few hail dings on it and some paint flaws where it looked like some brake fluid had splattered on it. It's not noticeable from a few feet away, however.
Here's a list of the specifics:
2001 Wrangler Sport
121,000 miles
4.0L
5 speed
Loaded with every option including the subwoofer stereo and a Dana 44
4.5" Rubicon Express lift (short arm Super Ride)
1" spacer up front
1" body lift and motor mount lift
Warn front and rear bumpers w/tire carrier
B&M shifter
35" tires that were SHOT
4.56 Precision Gears
SYE and Tom Woods driveshaft
Hardtop, but no soft top included
I took it for a drive and it was one of the scariest rides I'd ever been in. He'd told me that it handles "pretty strange" and to prepare myself. It rode very rough and inconsistently. I suspected the worn tires. It also pulled one way under acceleration and the other on deceleration. I suspected worn bushings. Nonetheless, I realized it was why the price was so low. No matter. I can fix that stuff easily enough, I thought. I made an offer, we agreed on a price and I drove it home.
Here it is next to the Bronco it was about to replace...
http://www.supermotors.net/getfile/5...e/jeep_001.jpg
Here is a link to all the pictues of my Jeep and my (mis)adventures: http://tommyr.smugmug.com/
geauxturbo 10-17-2007 10:06 AM
Thats sweet tea, right? :D
EvilM0nkey 10-17-2007 10:11 AM
Check every nut and bolt on the suspension and engine. I bet it's been molested in a very bad way somewhere.
Be sure the rear swaybar is still in there and the front is connected too.
Tommy R 10-17-2007 10:16 AM
So I immediately ordered some new 35" Maxxis Big Horns for it, gave it a nice wash, and painted the flares the seller had given me and installed them. BIG difference if you ask me. I also installed some RE quick disconnects.
http://www.supermotors.net/getfile/5...e/jeep_009.jpg
http://www.supermotors.net/getfile/5...e/jeep_011.jpg
I also discovered that the owner had incorrectly installed a dropped pitman arm. I replaced it with a stocker to get the draglink and track bar parallel and the bump steer was GONE! :D However, it had some death wobble issues I needed to work out. Not often, but "often enough". ;)
I did get chance to play at my friend's ranch, though...
http://www.supermotors.net/getfile/5...5-27-07_12.jpg
http://www.supermotors.net/getfile/5...5-27-07_15.jpg
http://www.supermotors.net/getfile/5...mmy_jeep02.jpg
Here's a short video:
http://www.supermotors.net/getfile/5...fst/522710.jpg
It did very well for being open at both ends.
I replaced the front lower control arm bushings and noticed that the bolts for the uppers were a bit smaller (.100") than the holes in the chassis. Thinking this might be contributing to my DW I made these shoulder washers...
http://www.supermotors.net/getfile/5...p_mech_042.jpg
Here they are installed (barely visible under the bolt head):
http://www.supermotors.net/getfile/5...p_mech_049.jpg
They helped, but the DW still pops up from time to time, just less frequently.
Tommy R 10-17-2007 10:17 AM
You mean they make "non-sweet" tea??? Who in their right mind would want that junk?? ;)
Tommy R 10-17-2007 10:28 AM
I'd also removed the rear sway bar. Didn't notice any ill effects and I wanted as much articulation as possible. I would later on be re-installing it. ;)
So about this time the "fun stuff" started to happen. We had a few events coming up (a Jeep Jamboree being one of them) and I wanted the Jeep to be capable. That meant lockers!
For the front I opted for a Lock Right from Richmond. Got it knocked out one evening after work. Here it is in operation just after installation (yes, I know the sound is out of sync for some reason):
http://www.supermotors.net/getfile/5...fst/545323.jpg
So now the front is locked. Great! So it was off to a member appreciation day for our club. Here's some pics. Needless to say, it was a pretty mild day of wheeling:
http://www.supermotors.net/getfile/5...-28-07_013.jpg
http://www.supermotors.net/getfile/5...-28-07_034.jpg
It also served as a recvoery vehicle when the fuel pump on my buddy's newly purchased TJ gave up the ghost:
http://www.supermotors.net/getfile/5...-28-07_069.jpg
I also decided to sell the hardtop when a friend essentially gave me a new soft top! I kept the full hard doors, of course.
swanee64 10-17-2007 12:29 PM
Nice, Don't stop now........:2thumbsup:
EvilM0nkey 10-17-2007 12:30 PM
haha. I told ya something was messed up. Glad to see it's on it's way to recovery
Tommy R 10-17-2007 01:28 PM
Before I sold the hardtop I made a hoist for it. The winch was a Harbor Freight special that cost me all of $20 and it included the cable and hook. The pullies and such came from Tractor Supply.
http://www.supermotors.net/getfile/5...p_mech_054.jpg
http://www.supermotors.net/getfile/5...p_mech_055.jpg
I guess about a month after getting the Jeep the CEL came on. "Cylinder #1 Misfire" according to the scanner. I replaced the igntion coil pack, the plugs, ran some injector cleaner through it, and eventually swapped the #1 and #2 injectors to see if the code came back if it followed the injector. I also purchased a new fuel cap.
Sadly, the code has continued to come back. And most recently, it tripped the CEL again this time telling me it had a misfire on #1 and #3. So it's not the injector itself. I'm open to suggestions on what this might be.
Early on it had a radiator leak so I replaced it with a new one. Easy job and it was cheap, too. Later on it also developed a bit of a water pump leak so I replaced it. Simple job. I've also flushed the coolant, the PS fluid, and changed out the diff/tranny/t-case fluids. I also made a nifty little side view mirror for when my doors are off, which is more often than not.
http://www.supermotors.net/getfile/5...terior_003.jpg
http://www.supermotors.net/getfile/5...terior_002.jpg
So there I was with a couple weeks before this big, expensive trip to Llano for a Jeep Jamboree. I wanted two more things prior to this trip: rock sliders and a rear locker. Unfortunately, I was in the process of getting my house ready to sell and it was sapping up all my funds. Then Zach at A to Z Fabrication announced a sale on his sliders! I couldn't resist. The last piece of the puzzle was a rear locker. What to do?
I'd heard horror stories of lunchbox lockers in the rear of TJs. That they would swerve rather violently with each upshift. I'd had lunchbox lockers (Aussies) in my Bronco and it was definitely noticeable and somewhat annoying. With a short arm, tall lift in a TJ I could see it being a problem. So the lunchbox locker was out.
A full Detroit supposedly acts much more civilized and would be great, but at $550-600 it was out of the budget. Of course that meant any selectable would be out of the budget, too.....not that I'd want a selectable rear locker anyway.
So I did a LOT of research and decided to install a full spool. The price was right at $100 and it would allow me to be locked for the Jamboree. If I didn't like it I could always remove it and sell it for close to what I paid for it. Who knows, maybe I'll like it. Keep in mind this Jeep is still often driven on the street.... Some folks said I was nuts. I never claimed to be sane.
[ITA]Tsunami 10-17-2007 01:32 PM
How do you did those shoulder washer?
Tommy R 10-17-2007 01:48 PM
I don't have pics of the spool install, but you've all seen that stuff before. It went well in one evening over the course of a couple hours. So how did it handle? On the street it was....interesting. It really binds up at low speeds requiring more throttle than you'd think. It squeals the tires when taking tight turns...sometimes the inside tire spins, sometimes the outside tire drags! The latter was unexpected. Other than that, you'd never know the spool was back there. And it drives very nice and straight. Above all, it's very predictable which was a key element. Keep in mind the rear swaybar is still off at this point.
The weirdest thing it would do is lift the inside front tire if I were accelerating quickly through a turn, such as turning at an intersection at speed. It wasn't dramatic or scary, though I'm sure it freaked out people who saw it. Basically, I could do it if and when I wanted to, so it was very much under control. That would soon change. ;)
The Jeep had Pro Comp MX-6 adjustable shocks on it. They were very stiff. I'd replaced the fronts a few weeks after purchase with some Skyjacker hydraulics, but didn't get around to putting the rears on until pretty recently. So the Skyjackers are way, WAY softer than the Pro Comps. As a result, the Jeep started doing strange things.
At really low speeds doing a u-turn, the ridiculous amount of anti-squat provided by my short arm lift would allow the inside tire to crawl under the Jeep moreso than the outside tire. When the inside rear suspension would jack the Jeep high enough it would lift the inside FRONT tire off the ground. I'm not talking an inch or two. I mean like a foot off the ground! If I did tight, low speed circles at 2 mph or so I could carry that inside front tire off the ground at least a foot or so! Why did it do this now and not before? Because the Pro Comp shocks were gas charged and provided a lot of resistance to the rear suspension drooping. The Skyjackers allowed this movement much more readily.
This in itself wasn't so bad. What was bad is when I had to accelerate quickly in a turn at an intersection from a stop. If the turn was tight enough it would jack so quickly and violently and lift that tire off the ground so fast that you'd honestly think the Jeep was going to flip itself like a diner chef flipping a flapjack!! I didn't like it. At all.
So I put the rear sway bar back on and kept the Skyjacker shocks. It felt normal again. :) Now it's off to the Jamboree!!!
Tommy R 10-17-2007 01:53 PM
I machined them out of solid bar stock steel.
Tommy R 10-17-2007 02:10 PM
The Jamboree
So now my Jeep is "very" locked front and rear, has sliders, fresh tires, and some decent suspension goodies. I'm ready for the Texas Spur Jeep Jamboree!
http://www.supermotors.net/getfile/5...e/dsc_0049.jpg
I also made a mount for my Hi-Lift:
http://www.supermotors.net/getfile/5...-15-07_026.jpg
Here's our group, sponsored by 4x4fun.com!
http://www.supermotors.net/getfile/5...e/dsc_0015.jpg
Staging:
http://www.supermotors.net/getfile/5...e/dsc_0047.jpg
I also found out that 12-13 psi in these Maxxis tires is way too much. On day 1 of the event I was aired down to 10 psi and the sidewalls were still barely flexing. On day 2 I went down to 8 psi!! In hindsight I shouldn't have done that. If I'd lost a bead in one of the situations I was in I would've easily rolled. I need beadlocks now. :(
Tommy R 10-17-2007 02:14 PM
Here's some miscellaneous photos, but my whole write-up is located RIGHT HERE:
http://www.supermotors.net/getfile/5...e/dsc_0251.jpg
http://www.supermotors.net/getfile/5...e/dsc_0296.jpg
http://www.supermotors.net/getfile/5...e/dsc_0599.jpg
http://www.supermotors.net/getfile/5...-15-07_062.jpg
http://www.supermotors.net/getfile/5...e/dsc_0611.jpg
http://www.supermotors.net/getfile/5...e/dsc_0684.jpg
http://www.supermotors.net/getfile/5...-15-07_172.jpg
http://www.supermotors.net/getfile/5...-15-07_073.jpg
And a video:
http://www.supermotors.net/getfile/5...fst/564872.jpg
It was mid way though the day I noticed the Jeep was doing the "spool lift" pretty badly. It was at a break area that I noticed my rear sway bar endlinks (PLASTIC!!) was broken so I was running with no rear bar! Given the off-camber situations we were in that made for some very, VERY scary moments.
Here's a pic showing how the Jeep jacks when taking a tight left hand turn on a grippy surface like granite. I'd turned the wheels to the right in an effort to flatten it out before we got out to have lunch:
http://www.supermotors.net/getfile/5...e/dsc_0460.jpg
http://www.supermotors.net/getfile/5...e/dsc_0462.jpg
Scary as hell!!! Especially when you consider I was only half way through the turn at the top of a mountain with a steep drop off. :eek:
Fortunately, I managed to get through the day without rolling it.
The time now is 07:26 PM.
Powered by vBulletin Version 3.8.4
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
