Today is the Day - JeepForum.com
post #1 of 17 Old 04-04-2008, 06:20 AM Thread Starter
Silver04TJ
Today is the Day
I'm gonna pull the trigger on the Cepeck Black DC-1's 15x10's, Cepek Fun Country II 33x12.50x15s, and the Full Traction 3" Economy with M-Force shocks! I'm nervous. HAHA It will be my first lift install but I've read on this for weeks and weeks, got plenty of help on here (THANKS!) and have worked on vehicles all my life. Wish me luck.
Also.. I've been looking at corner guards... not really b/c of rocks but I have a small dent at the bottom left hand corner of my Jeep. It's not too bad or big, just been bugging me here lately and I thought I could cover it up with black corner guards which would look good on my silver Wrangler since I keep everything on it either black or silver. Well I don't want to drill my tub and I don't want to use adhesive on the paint. So I'm talking to my girlfriend last night (who loves my jeep by the way.. mad props to her) and she is like.. well don't they make any with magnets? Genius idea I think! Has anyone tried this or thought of this? Thinking about ordering a set that are not pre drilled and finding some thick "sheet magnet" and somehow attaching it to the back of the corner guard and trying them on my jeep.
Silver 2004 Jeep Wrangler Sport
3.5" Rubicon Express Standard lift,
Cepek DC-1 15x10 Black wheels,
33x12.5x15 Cepek Fun Country II!!
M8000 Warn Winch with in cab controls
And the accessory every Jeep should have...DIRT/MUD!
Silver04TJ is offline
post #2 of 17 Old 04-04-2008, 07:18 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Good luck with the install.Just do like I did and put a WTF sticker over the small dent.
TheBoogieman is offline
post #3 of 17 Old 04-04-2008, 08:13 AM Thread Starter
Silver04TJ
Just ordered it all and got it for just under 2k. $772 for the lift kit with M-Force shocks w/ free shipping. Wheels and tires, mounted and balanced, and shipped for $1192!! Can't wait!!
post #4 of 17 Old 04-04-2008, 08:24 AM
TheBoogieman
Disturbed
Don't forget to post pics when it's all done.I love getting new stuff
post #5 of 17 Old 04-04-2008, 08:40 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Why the 15x10 wheels?
Most Jeepers prefer an 8" wide wheel for that size tire.
Wheelin98TJ is offline
post #6 of 17 Old 04-04-2008, 08:43 AM Thread Starter
Silver04TJ
Yea I will takes pics for sure. Just got a new video camera too so I might video some of the install. Jeep should look like new. List of crap to do:
Install lift kit
Install tires and wheels
Allignment
Change TPS
Paint fenders
Take out carpet to clean and clean inside tub
Clean seats
Clean top and windows
Wash/wax
Good thing I 've got a week off of work coming up in two weeks.
post #7 of 17 Old 04-04-2008, 08:49 AM Thread Starter
Silver04TJ
I don't do any crazy off-roading. mainly hills and mud. I try to stay away from the crazy rock piles/hills b/c its my DD. I don't air down unless I'm driving on the beach at the Outer Banks.... and I like the looks of a 10 on a 12.50 better....as opposed to an 8. Any convincing reasons to go with an 8?? I can still change my order.
post #8 of 17 Old 04-04-2008, 09:56 AM
Chris_
15x10 will put that nice, shiny aluminum rim closer to whatever you're going to scuff it against. At least with a 15x8, the tire will keep you from rashing up those pretty wheels. Even the curbs at the mall can make aluminum wheels look bad.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline
post #9 of 17 Old 04-04-2008, 10:02 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I'd only advise you go with 15x8 wheels for those new 33x12.50 tires, not 15x10. 15x8 wheels help the tires stay seated more securely when you're aired down for offroading better than 15x10 wheels do. It takes more air pressure to hold the tire securely against two edges 10" apart than if they were only 8" apart. I'm running 15x8 with 35x12.50, it's ideal.
Jerry Bransford is offline
post #10 of 17 Old 04-04-2008, 10:32 AM
deltabravo
Yes, that pretty well sums it up.
When running even moderately reduced air pressures, you're more likely to unseat a bead, for example if you drop the pressure, run some sand banks at a medium speed, turn sharp, the tire will fold over and probably unseat a bead. that description is a very "severe" situation, but it's best way I could explain it in a short sentence.
deltabravo is offline
post #11 of 17 Old 04-04-2008, 10:49 AM
Wheelin98TJ
JEEP FREAK
Another advantage with 8" wide wheels is they are easier to keep under the flares.
post #12 of 17 Old 04-04-2008, 11:10 AM Thread Starter
Silver04TJ
So the Full Traction 3" is on backorder.. called 3 different places.. no one had one. So I got the Rubicon Express 3.5" Standard with the Rubicon shocks. Cost about $50 more.
post #13 of 17 Old 04-04-2008, 11:30 AM
Wheelin98TJ
JEEP FREAK
You'll need more parts than what you ordered if it only cost $50 more.
The RE 3.5" kit will net you more like 4" - 4.5".
The standard RE 3.5" kit does not include a front trackbar and you'll definitely want one at that lift height.
You'll also need to address the brake lines if you plan on disconnecting the front sway bar. Either move the mounting point on the frame or get longer lines.
Driveline vibrations may also be a problem. The t-case drop that is provided with the lift kit might not be enough to get rid of all the vibrations. If so, you'll need a MML or an SYE, driveshaft, and adjustable upper arms.
post #14 of 17 Old 04-04-2008, 11:36 AM Thread Starter
Silver04TJ
I thought about the adj. track bar. Guess I'll try it with the Xfer case lowering kit and see how it goes and take it from there.
post #15 of 17 Old 04-04-2008, 11:38 AM Thread Starter
Silver04TJ
Thanks for all of the advice/help.
