TJ of The YEAR WINNERS!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TJ of The YEAR WINNERS!!
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 12-19-2009, 09:51 PM   #1
spyder6
Got that Toyota chit
spyder6's Avatar
2010
#1
GUNKEL SEPTEMBER
Thanks for the opportunity and the chance to enter!
Username: Gunkel
Specs & Mods:
2006 Jeep Wranger Unlimited (LJ) *06' LJ build...Fireproof*
Rubicon express 5.5 springs, long arms, belly pan, quick disconnects
Rubicon express mono tubes and steering stabilizer.
Poison Spyder HD Steering and steering gear skid plate
4.0 auto
D44/30 combo with Ridler covers
NP231 with advance adapter SYE kit
Tom Woods rear drive shaft
37" Goodyear MTR's on Spyderlock beadlock wheels
Homemade front bumper/stinger/winch mount
Homemade rear bumper/tire carrier
KC windshiled light mounts and a set of daylighters with custom grilles
Ramsey winch with synthetic rope and HD hook
Poison spyder rear crusher corners with LED tail lights and custom LED marker lights
SRC front tube fenders with custom tube flares, LED turn signals, and LED marker lights
Poison Spyder Helldaro rocker guards
Poison Spyder full cage kit with spyder gussets and spyder web gussets
Beard seats/Simpson harnesses
Custom LED ambient lighting
Texas Ranger CB, firestick antenna
Gentex rear view mirror with homelink, temp, and compass
Optima blue top battery
PPG base coat/clear coat paint system
Upol Raptor tinted*liner
Current projects:
D44 front axle: Reid racing knuckles, stage 8 spindle nuts, e-locker or ARB, 5:38's, warn hubs, trussed, etc.
D44 rear axle: Detroit, 5:38's, trussed etc.
Story:
I purchased this vehicle back in February 2008 from a friend of mine that owns a local junk yard, the vehicle was a "burn unit" that had obviously been totaled by the junk yard. Over the last year and a half I have removed/rebuilt almost every nut and bolt on the jeep with my own two hands. The only thing that I did not do myself was bend the front "hoop" for the front bumper (lack of tubing bender), paint work, welding, fabbing, etc. was all done by me. I actually built this on a budget as well, many of the parts were either craigslist finds (seats, winch, front axle), closeouts that were discounted (PSC corners, steering), jeep forum vender discounts (lift, shocks, SYE, knuckle's) or ebay finds (CB, mirror, harness's). Many thanks to all of the jeepforum members who provided inspiration throughout this build, along with motivation when my wife/kids were wondering if I was having an affair! (honestly, I swear I am down at the shop working on the jeep).
Pics:
#2
IDAHO-JEEP JULY
Anyway, on to my submission.
Photos: *According to Photobucket these were imported at the required size of 600x800 so I am hoping this is correct.
Specifications / Modifications:
2004 TJ Sport
4.0L I-6
Optima Yellow top Battery*
5 speed transmission*
4 wheel disc brakes
22,000 miles
*AA SYE
*Front Axle = Trussed Dana 30, OX locked, OTK 1 ton steering, Vanco Big brake kit
*Rear Axle = Trussed Dana 44, Ox locked.
*Gear Ratio = 4.88
Suspension
*3.5" TnT Customs dual triangulated Long Arm with high clearance belly pan.
*Fox Remote Res shocks with TnT outboard kit.
*Antirock sway bar system
Tires / wheels
*35x12.5 Mickey Thompson MTZ on 15x8.5 Rock Monster Hutchinson double beadlock - full size spare
Recovery
*Warn XD9000i
Armor
*TnT 4.5" tube fenders & extended wheel well corners. *Rock hard rockers, Road Armor front bumper/stinger, Wilderness rear bumper system.
Accessories
*Rock Hard sport cage - bolt in roll cage
*Cargo Master roof rack
*Cobra CB
*Wilderness Jerry can carrier*
Brief story:
I purchased this Jeep 3 years ago. *I had always wanted a wrangler and after a Spring trip to Moab I caught the fever. *I made minor modifications after I bought the jeep spending time wheeling to determine what I would want to do. *I utilized Jeep Forum and began making a plan well over a year ago. *I began ordering and stockpiling parts early last summer in preparation for the winter build project.
In August of 2008 I pulled my Jeep into my garage where I worked on it for the following six months. *By January of 2009 it was again drivable. *Other than the axle truss welding, fender painting, re-gearing and exhaust system the work was done by myself - including mounting and balancing my tires. *I had very limited knowledge of this type of work prior to this project and learned a lot because of it. *I utilized Jeep Forum as well as stuoffroad.com whenever a question came up.
My goal for this Jeep was to create a well built "all around" jeep - one that could perform well in Moab and on the high way on the way to work. *I was also wanting more than just a "beater" I want it to turn heads and look good.
Now that I have been able to drive it for almost 6 months I could not be happier with this Jeep. *It performed better than expected in Moab this Spring and handles great on the freeway at 70 mph. *I cringe a little sometimes when I drive through brush or smack a rock but remind myself that its a Jeep doing what it was meant to... *
If interested, you can see my build at:*Idaho Jeep Build
#3
-SEAN- AUGUST
Thanks for the opprotunity, here is my submission for the August poll.
Username: -sean-
Specs:
2004 Jeep Wrangler Unlimited (LJ).* Project Long Red One: Project: Long Red One
Tub sectioned to TJ spec. Project L-TJ: Project L-TJ: Sectioning ( Bobbing ) an LJ tub to TJ spec's. - Pirate4x4.Com Bulletin Board
Comp cut rear.
Campbell Ent. glass hood (modified). AutoFab hood pins and extensive under hood accessory relocation.
Currie front and rear bumpers. (modified)
4.0 and automatic transmission.
NP231 w/ Advanced Adapter SYE and Novak shifter.
Tom Woods rear drive shaft.
Rear D44: Trussed, Crusher cover, ARB, Yukon 4:88 gears, Alloy USA axles.
Front high pinion D30: Trussed, Crusher cover, ARB, Yukon 4:88 gears, Alloy USA inner and outer shafts and billet seals.*
One Ton over knuckle steering.
37" Goodyear MT/R's.*
ProComp aluminum wheels, 15x8.
Front suspension is three link, long arm using OME 2.5 springs.
Rear suspension is double triangulated long arm using 106AA springs. Outboarded shocks.
Doetsch Pre-Runner shocks.
Currie bump stops front and rear. (modified)
Custom "belly-up" skid and cross member.*
Currie Anti-Rock.
1" BL w/ 1" M.O.R.E motor mounts.
Front and rear L.E.D. lights.
Mile-Marker 12,000 lb. winch w/ HD hook and fairlead.*
RCI fuel cell.
RedTop Optima in BTF mount (modified).
Uniden CB radio, Firestick antenna.
The Source C02 tank.
Empi RaceLine seats (3)
U-Pol Raptor tub liner.
PolyPerformance Racing steering wheel w/ quik disconect.
Current Projects:
Front D60 and 6" stretch.
Full Hydro steering.
Rear 14 bolt.
Airshocks.
40's
Pics:
congrats to all!!
My builds: Bruiser and The Grey
|Forge Overland| or follow us on Facebook
spyder6 is offline   Reply With Quote Quick reply to this message
Unread 12-19-2009, 09:54 PM   #2
RubiconRazorbac
RubiconRazorbac's Avatar
What a great contest and a great lineup. Lots of hard work in those Jeeps! Great job guys.
CONGRATULATIONS!!!
Your shaft isn't long enough to handle that kind of droop...
My build thread: http://www.jeepforum.com/forum/f9/ru...thread-792423/
RubiconRazorbac is offline   Reply With Quote Quick reply to this message
Unread 12-19-2009, 09:54 PM   #3
DaleII
Awesome! Love all the Jeeps guys and Congratulations!!
2005 Silver LJ
DaleII is offline   Reply With Quote Quick reply to this message
Unread 12-19-2009, 10:00 PM   #4
Kenbo-Slice
Three AMAZING rigs.
Kenbo-Slice is offline   Reply With Quote Quick reply to this message
Unread 12-19-2009, 10:10 PM   #5
2006_Sport
Good Job guys. You earned it!
2006_Sport is offline   Reply With Quote Quick reply to this message
Unread 12-19-2009, 10:12 PM   #6
GroundAssault
Way to go guys......
2006 Jeep Wrangler---SOLD!
Nowhere at present is there such a measureless loathing of their country by educated people as in America. --Eric Hoffer
Originally Posted by rmb2485
cheap mods are like a drug dealer giving you your first few for free...they will only get you addicted and before you know it every paycheck goes into your new habit :rofl:
GroundAssault is offline   Reply With Quote Quick reply to this message
Unread 12-19-2009, 10:31 PM   #7
black954
1978 CJ7
GUNKEL certainly deserves it, what an awesome TJ
black954 is offline   Reply With Quote Quick reply to this message
Unread 12-20-2009, 12:38 AM   #8
-sean-
1944 CJ2
Thanks everyone!
Looking through the user names that voted for my rig was very uplifting.
I hope everyone here on JF has a great Christmas!
L-TJ
-sean- is offline   Reply With Quote Quick reply to this message
Unread 12-20-2009, 12:55 AM   #9
missionAvs
missionAvs's Avatar
Congrats guys, you all earned it!!
04 Willys Edition TJ Wrangler
missionAvs is offline   Reply With Quote Quick reply to this message
Unread 12-20-2009, 02:06 AM   #10
Redarcher89
Congrats to all. Can't wait for the calender.
Redarcher89 is offline   Reply With Quote Quick reply to this message
Unread 12-20-2009, 02:57 AM   #11
RogueSpear2023
Congrats, have a merry (whatever is politically correct for you) and a happy new year, I can't wain to see the calendar either.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
TJ Tech Boot Camp
TJ Specs
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline   Reply With Quote Quick reply to this message
Unread 12-20-2009, 03:14 AM   #12
VanBCguy
VanBCguy's Avatar
Congrats to you all guys. It's a pleasure to see all of your builds. I can't wait for the calendar!
VanBCguy is offline   Reply With Quote Quick reply to this message
Unread 12-20-2009, 09:02 AM   #13
cmoore
Congrats to all of the TJOTM rigs. Hope to see them all together on trail some day (maybe this EJS??).
98 XJ:4.0, AW4, HP30/8.25 4.56 Spartan/LSD, alloy shafts & joints, HD steer, SYE/CV, skids, RADesigns gated shifter, RE mix n match lift, 35"mt/rs, THOR guards F&R, weld-in custom rockers & stiffeners, custom front bumper, orfab rear bumper, THOR cowl induction, on board air, on board welder, etc
cmoore is offline   Reply With Quote Quick reply to this message
Unread 12-20-2009, 09:07 AM   #14
LGriffith
I have to say I voted for Sean's rig, but every one of these jeeps completely deserve the win. Congrats fellas, job well done.
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith LJ Build
LGriffith is offline   Reply With Quote Quick reply to this message
Unread 12-20-2009, 09:10 AM   #15
Airdoc
Congrats to all the TJOTY Winners as well as TJOTM Winners!! Great builds!!!
97 TJ, 88 M3, 95 M3, 96 328I Track Car, 00 F150
Airdoc is offline   Reply With Quote Quick reply to this message
