TJ Wrangler 2006 Radiator leak - JeepForum.com
post #1 of 7 Old 03-29-2012, 07:21 AM Thread Starter
Blue-Crane
I have a Jeep Wrangler TJ 2006 (mileage 85000 km). There has recently been an issue with mist emanating from the vents on the dash console. Subsequent to a visit with the mechanics, a diagnostics report revealed that there is a leak in the radiator(I understand that Jeep has two radiators), for the heating/air-conditioning unit in the vehicle. There is also some water deposit on the passenger side under the floor mats. Called up Jeep (Cape Town, South Africa) and they reckon that I would need to import a new radiator from the US. I've been told that it may not be a leak in the radiator itself, but it may just be a simple (and no doubt much more cost effective) issue of replacing a clamp or a pipe/tube. I've also been told, since parts are not always readily available here in SA, that I could have one made up. What would you recommend as my best recourse to action? I am told that the entire dash console needs to be removed either way. Thanks in anticipation.
Blue-Crane is offline
post #2 of 7 Old 03-29-2012, 07:26 AM
Fropleyqk
Fropleyqk's Avatar
What youre describing is the heater core going bad. Search a bit in this section for lots of info on how to replace it.
Your Jeep only has 1 radiator.
Fropleyqk is offline
post #3 of 7 Old 03-29-2012, 10:05 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
No, it has 2 radiators, one of them is just smaller and lives in the HVAC unit under the dash, but it is a radiator. It has rows of tubes with fins between them mounted in a core with tanks capping the ends and an inlet and outlet that connect to rubber hoses that coolant circulates through to extract heat.
Or to be slightly more accurate, they are both heat exchangers with identical functions but different jobs.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #4 of 7 Old 03-29-2012, 10:43 AM
Fropleyqk
Fropleyqk's Avatar
More commonly referred to as the heater core. But yeah, if you wanna get all technical...
Point being, for the OP, if you dig around looking for a replacement radiator, you're run across the FRONT radiator. If you search for a replacement heater core, you'll find replacements for the one that is just smaller and lives in the HVAC unit under the dash.
post #5 of 7 Old 05-26-2012, 01:04 AM Thread Starter
Blue-Crane
I haven't been on this site for a while...still quite new here. Would like to say thanks for the insight and suggestions. I finally had the heater core/radiator bypassed. There is a backlog of orders and this part can only be ordered from the States. I shall perhaps look into getting one second hand from a Jeep which is being broken down for parts. What are your thoughts on this? Good weekend to you!
post #6 of 7 Old 05-26-2012, 09:44 PM
gatesjeff33
http://www.stu-offroad.com/engine/he...atercore-1.htm
Here is a photo journal that will show you the scope of the work involved.... It's alot
gatesjeff33 is offline
post #7 of 7 Old 05-26-2012, 10:19 PM
Patrick H
They really aren't bad to replace. Takes about 2.5-3 hours including charging the A/C..
'01 TJ
'48 CJ2A
Patrick H is offline
leak , radiator , tj , wrangler
TJ radiator fan upgrade info.......2000-2006 TJ chris142 TJ Wrangler Technical Forum 642 10-27-2016 08:53 AM
radiator leak. get the radiator fixed or replace? LiveAndLearn TJ Wrangler Technical Forum 32 11-24-2011 10:06 AM
Pinhole leak in radiator--Alumaseal/Bar's Stop leak? JEEP97TJ TJ Wrangler Technical Forum 16 06-11-2010 06:01 PM
Turn a 1997 Wrangler into a 2006 Wrangler MeSoDumm TJ Wrangler Technical Forum 14 06-25-2008 09:24 PM
95 YJ Radiator Leak/ Water Pump leak?? SThomas86 YJ Wrangler Technical Forum 11 01-05-2008 04:25 PM
