TJ won't shift into 4wd.. Help?! - JeepForum.com
post #1 of 3 Old 08-20-2011, 12:21 PM Thread Starter
deerkilla4500
Took my 98 TJ 4cyl out wheeling this weekend and it was working great.. 4wd Hi and Lo were working perfectly until the last trail I hit.. Took it in 4 LO to get over a really steep berm, but after I went back over it to get back to the other trails and shifted back into 2wd I couldn't get it to shift into 4wd at all.
I pull the lever back and I can hear the linkage moving (I think it's moving.. it sounds normal regardless) but the lights never come on and I'm definitely stuck in 2wd. It's done this before and I randomly messed with the lever and it eventually fixed itself.. But this time it's not changing at all.
Any ideas?
deerkilla4500 is offline
post #2 of 3 Old 08-20-2011, 01:37 PM
RockMonster
have you crawled under the jeep and visually inspected the TC linkage for any hang ups?
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++ ++++
RockMonster is offline
post #3 of 3 Old 08-20-2011, 01:50 PM Thread Starter
deerkilla4500
I crawled under, but I don't really know what to look for.. There's nothing obviously disconnected or anything
4wd , shift , tj , transfer case
32RH shift issue - will not shift into 2nd automatically noise_maker TJ Wrangler Technical Forum 11 09-09-2012 02:37 PM
Auto wont shift out of park, BRAKE TRANSMISSION SHIFT INTERLOCK MECHANISM seems stuck Rivka TJ Wrangler Technical Forum 19 04-22-2012 08:26 PM
What holds the shift lever onto the transmission shift stub? venturad YJ Wrangler Technical Forum 10 01-19-2010 07:31 AM
Can't Down Shift into 2nd or 1st, but when stopped, it will shift MarkkInNJ YJ Wrangler Technical Forum 8 07-03-2009 09:48 PM
How to separate upper shift lever from lower shift lever??? rgs112 YJ Wrangler Technical Forum 3 08-11-2008 05:59 PM
