TJ Winch Mounting Plate Flat or Raised? - JeepForum.com
post #1 of 39 Old 12-22-2008, 09:12 PM Thread Starter
cvd
cvd's Avatar
Based on pictures, it looks like some plates are simply a flat piece of steel with holes in the right places (Smitybilt, Rugged Ridge, or MileMarker), while others look like they elevate the winch (Tomken, Warn or Body Armor). Seems to me the lower the winch, the better. Any reason for the differing designs?
A better question is is there anything lacking in the Smitybilt unit? It sure is cheaper.
Cliff
Smitybilt ($70) - http://www.4wd.com/productdetails.as...0&partID=40357
Rugged Ridge ($72) - http://www.4wd.com/productdetails.as...0&partID=40350
MileMarker ($85) - http://www.4wd.com/productdetails.as...=0&partID=9245
Tomken ($190) - http://www.quadratec.com/products/12113_04.htm
Body Armor ($206) - http://www.4wd.com/productdetails.as...0&partID=14699
Warn ($213) - http://www.4wd.com/productdetails.as...=0&partID=6128
cvd is offline
post #2 of 39 Old 12-22-2008, 11:21 PM
StvDiego
The main difference is the "elevated" plates account for the winch mount bolts that go through the bottom of the plate, the flat plates use spacers to raise the plate.
Either way you need room under the plate for the bolt heads from attaching the winch to the plate.
As for other differences...
Some are better quality steel, are powder coated as opposed to painted, some have varying hole designs, some have fairlead mounts some don't...
I've used and thoroughly abused a generic/TJ raised mount with a Mile Marker winch on my TJ for a couple of years with no issues other than needing a touch of rattle can now and then. Look for one with a fairlead mount built in, almost all do.
I also trimmed the plastic swaybar cover to fit around it and reinstalled it
StvDiego is offline
post #3 of 39 Old 12-23-2008, 12:19 AM
fish4life
It depends on what kind of bumper you are mounting this on. Assuming it is a stock bumper, which most winch plates are used with, there is no need for any kind of spacer or gap between the winch and the plate. Standard winch mounting pattern is 4 bolts on 10"x4.5" i think. This clears the stock bumper width enough so that when the winch plate is mounted flush on top of it the bolts can still be tightened from the bottom just fine.
You can see here my M8000 winch is mounted on a Harbor Freight winch plate that sits flush on the bumper. The winch was mounted on the plate and then the whole assembly was mounted onto the bumper. The bolts cleared the bumper just fine. Thinking about it, i think they could even be done up had the plate been mounted first, followed by the winch.
fish4life is offline
post #4 of 39 Old 12-23-2008, 12:22 AM
fish4life
As for the plate, i'd pick the cheapest one that is thick and fits. My Harbor Freight one is good and has been used in several decent pulls, one involving a jeep that slid into a lake from a 10 foot cliff and it is in no way "deformed" anywhere. It's held up just fine
The harbour freight one was a steal at like $37.99, not sure if they still have them or not. I heard they got rid of them all.
EDIT: The Smittybuilt advertised there says it is 3/8" thick. I HIGHLY doubt that is correct. The standard thickness of these is 3/16 of an inch. If you can get a 1/4" in the same price range it would be good, but 3/16 is adequate
Again, if it's a stock bumper, just go with the cheapest 3/16" plate that fits and call it a day
post #5 of 39 Old 12-23-2008, 12:37 AM
mascun
I had the local steel shop cut a piece of 5/16 plate the length of the framerails and the width of the winch. I took it home measured and marked the holes and drilled them out. Total cost $20... it's stronger then any mount you can buy. Plus, it's mounted flat to the framerails, no need to raise it for clearance.
97 tj 4"fabtech, 35"x-terrain, 2" bl,xrc8 winch,
4.0L, np231 SYE, auto 3 speed, dana30, ford8.8
79 cj7 4"rough country 35" dunlop
http://www.indyorv.com/
mascun is offline
post #6 of 39 Old 12-23-2008, 12:39 AM
fish4life
If it's just a flat piece of metal, then where'd you mount the fairlead?
post #7 of 39 Old 12-23-2008, 12:51 AM
mascun
to 2 pieces of 1/4"
I'll take pics if you want
mascun is offline
post #8 of 39 Old 12-23-2008, 01:01 AM
fish4life
to 2 pieces of 1/4"
and how'd you mount these two pieces of 1/4" to the winch mount? Did you weld them on?
post #9 of 39 Old 12-23-2008, 01:26 AM
mascun
well, mine is a lil different. my front bumper is a piece of 4" C channel so i welded the fairlead mount to it. But, the 5/16 plate could just as easily have been bent at a 90 and holes drilled into that for the fairlead. Don't know about by you, but, my local steel shop charges $2 per cut and $3 per bend....So price of 5/16 at correct width 1 cut, plus 1 bend.
mascun is offline
post #10 of 39 Old 12-23-2008, 07:46 AM
TJDaveX
Motorized toy collector
TJDaveX's Avatar
Smitty winch, Rough Country plate, Smitty bumper. Experienced the winch bolt clearance issue with flat plates and aftermarket bumpers during install. No worries, just drilled some holes in the bumper and bored them out with a uni-bit until they were big enough for the winch bolts to drop into. Easier to get a raised plate depending on which bumper you have. My Smitty bumper was cheap, easy to drill through, and I was drilling holes in it anyway for my off road lights.
TJDaveX is offline
post #11 of 39 Old 12-23-2008, 08:05 AM
robncar
robncar's Avatar
Harbor Freight, $40!
http://www.harborfreight.com/cpi/cta...emnumber=90476
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #12 of 39 Old 12-23-2008, 08:49 AM Thread Starter
cvd
cvd's Avatar
Thanks for the replies. I'm going to use the stock bumper. Sounds like a simple (cheap) flat mounting plate should be fine.
Regarding the Harbor Freight "universal" plate - do the holes line up for use with the stock TJ bumper?
Cliff
cvd is offline
post #13 of 39 Old 12-23-2008, 09:49 AM
Dhorn33
I don't think I saw anyone else mention this - but I had the HF plate on my rig for a while until I picked up the Warn TJ plate from a local Jeeper. The flat plate ones are designed to mount in front of the swaybar - the Warn is elevated to sit on top of it. The winch sits slighly higher - and a few inches further back toward the grill with the Warn. The HF plate brings the winch out toward the front and it even sticks out a few inches past the bumper. You can see this in the pics earlier in this thread. Obviously the Warn piece is much more expensive - but look at it and you can see why in my opinion.
Registration for Crawl 4 the Cure is now open.
Visit the website at
for details and event information and come Jeepin' to help cure Multiple Sclerosis
My rig: 1997 Jeep TJ Sahara on 35's with Aussie locked 8.8 rear, 4.10 gears, lots of other goodies
Dhorn33 is offline
post #14 of 39 Old 12-23-2008, 10:00 AM
archdlux
I've got an extra Harbor Freight winch plate sitting around. It's a universal type, brand new.
Was going to sell on ebay, but if you want it let me know. Also have the black steel hawse fairlead.
Was thinking $10+ship for everything. PM if you want me to send pics. Thanks.
archdlux is offline
post #15 of 39 Old 12-23-2008, 11:31 AM
BlueFlame
BlueFlame's Avatar
Bumper (in general) has nothing to do with it. A winch plate should not rely on the stock bumper at all. The bumper isn't strong enough for much.
Flat plates must be in front of the sway bar, so they'll stick out the front more. Look at fish4life's pic.
The raised plates get over the sway bar, so the winch can tuck in tight to the grill. Look at http://www.jeepforum.com/gallery/sho...5&ppuser=71619
Air flow to the radiator is not an issue either way, (except maybe with one of those monster compressor winches.)
BlueFlame is offline
Will A TJ Winch Mounting Plate Fit On My YJ? Group_er YJ Wrangler Technical Forum 2 10-28-2009 07:25 PM
Winch mounting plate dkonshak YJ Wrangler Technical Forum 3 07-31-2009 09:57 AM
Raised winch plate will it fit a YJ??? Hendy7 YJ Wrangler Technical Forum 1 04-20-2009 07:35 PM
Need Quick Help.....Winch Mounting Plate?? RandyTJ TJ Wrangler Technical Forum 10 08-20-2007 10:29 PM
300$ for a winch mounting plate? troy_boy JK Wrangler Technical Forum 14 05-08-2007 05:07 PM
