TJ Vacuum Lines - JeepForum.com
post #1 of 5 Old 02-15-2007, 02:40 PM Thread Starter
Skeezer
TJ Vacuum Lines
Would anybody happen to have a picture or can tell me the location of vacuum lines on a 06 TJ 4.0L ? I think I might have a vacuum line problem. I appreciate your help, thank you.
2005 Rubicon
Skeezer is offline
post #2 of 5 Old 02-15-2007, 02:47 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
They're "everywhere". They power the power brake booster and go into the dash area where they power the various HVAC control doors. You're just gonna have to kind of look around for them. You can locate a vacuum leak by spraying carb or TB cleaner at all the likely locations on the vacuum line connections while the engine is running. If the cleaner gets sucked into the engine via a leak in one of the vacuum hoses, you will immediately hear an engine RPM fluctuation.
Getting
Jerry Bransford is online now
post #3 of 5 Old 02-15-2007, 02:50 PM Thread Starter
Skeezer
Thanks Jerry, I'll give it a shot.
2005 Rubicon
Skeezer is offline
post #4 of 5 Old 02-15-2007, 03:41 PM
fitzz47
06 should be under warr.
2015 GC Attitude Black
2015 Wrangler Sahara Hydro Blue
fitzz47 is offline
post #5 of 5 Old 02-15-2007, 04:18 PM
cheesycook
Accident Prone Bonehead
cheesycook's Avatar
They can be a pain. My dad used to have cans of smoke for testing fire alarms that would be great for this if someone found a can. No residue, just tape up the intake and spray it in a vaccuum line and see where it comes out.
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top.
tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud.
Hermiston, ORL
, because I don't have a clue, but Stu does!
cheesycook is offline
Necessary Vacuum lines? YJ800 YJ Wrangler Technical Forum 1 07-18-2009 12:18 AM
Vacuum Lines SEMO 95 YJ YJ Wrangler Technical Forum 2 03-01-2008 07:26 PM
which vacuum lines can i get rid of? FASTMETAL YJ Wrangler Technical Forum 1 09-27-2007 05:25 PM
Vacuum Lines mxracer513 YJ Wrangler Technical Forum 3 08-09-2007 09:37 PM
Vacuum Lines 87 yj 2.5L Boog44 YJ Wrangler Technical Forum 8 12-16-2006 02:07 PM
