TJ Tub Replacement - JeepForum.com
post #1 of 2 Old 10-05-2011, 04:59 PM Thread Starter
1997_Blue_TJ
TJ Tub Replacement
Anybody ever done a tub swap on a TJ? My '97 TJ has a lot of rust underneath the drivers side door (it's rusted all the way through) and on both sides of the tailgate. The rust was all there when I purchased it, and I'm trying to decide between having it all repaired or replacing the tub. Seems like I can get a tub for between $300-$500 and I'm thinking that the time and materials of the full repair would be considerably more if I had it done - I'm not skilled in body work at all. Wondering what kind of time commitment I'd be looking at for a replacement. It doesn't seem that it'd be too difficult with the exception of nuts and bolts being rusted on over the past 14 or so years. Any input would be greatly appreciated! Thanks.
1997_Blue_TJ is offline
post #2 of 2 Old 10-05-2011, 08:22 PM
2ACR
That's Right I Support
2ACR's Avatar
If you don't have to do an electrical sway than a tub swap wouldn't be much more work than a frame swap. It would take some time and thought but it isn't impossible for the average garage mechanic.
It isn't the best choice but you can quickly learn how to use fiberglass to take care of those rust spots. Cut out the bad stuff and reshape the missing pieces with fiberglass.
Either way won't be that easy but both are doable. As long as you do it yourself it won't really matter which option you choose. We will all commend you for your hard work and dedication.
You can also become really good friends with someone who can weld. Cut the bad spots out and have them weld in new sheet metal. Repaint and enjoy.
Originally Posted by jr03 View Post
And when you can't find the wrench your holding in your hand, it's time for a break:rofl:
Jeep Jedi in Training.
2ACR is offline
Looking for D30 axle seal replacement and Ball Joints Replacement Write Ups pfifer TJ Wrangler Technical Forum 1 04-14-2010 07:49 AM
TPS Replacement DesertJeep2002 TJ Wrangler Technical Forum 1 03-23-2009 06:48 PM
TJ Rad Replacement SRV TJ Wrangler Technical Forum 2 08-25-2008 05:24 AM
HID Replacement Kit... Bos TJ Wrangler Technical Forum 11 12-19-2002 07:20 PM
