TJ Transmission Front Pump Leak TF999 - JeepForum.com
post #1 of 22 Old 09-21-2010, 12:04 PM Thread Starter
pinoypowers
Iíve hit the wall and donít know what else to do. It seems like my transmission leak is back and I need help on trying to solve the problem.
Problem: Transmission is leaking from the front pump.
Action taken to correct the problem: Replaced the front seal, bushings, gaskets on the front pump.
After the repair the Jeep ran without any issues for 2 weeks approximately 400 miles of driving. Then one day I just noticed this puddle of transmission fluid on the floor.
Action taken to correct the problem: Took the transmission down again and replaced the front seal and the torque converter.
The Jeep has been running without any leak for about 3 weeks. Last night I noticed a small drip of transmission fluid (RED) on my garage floor. I am not rushing to take the transmission down the 3rd time unless figure of what is actually causing the leak.
Here are other known problems with the Jeep that might help. I have a vibration with I think is coming from the driveline about 60mph. I have a rear main seal or oil pan seal that leak about a drip about one a month. 50% of my driving is high speed for a jeep 70mph at 3000 RPM.
Any help will be greatly appreciated.
pinoypowers is offline
post #2 of 22 Old 09-21-2010, 12:08 PM
LJameson
The only thing i could think of is your trans is overheating. What gears and tires do you have?
1990 YJ
LJameson is offline
post #3 of 22 Old 09-21-2010, 02:23 PM Thread Starter
pinoypowers
I am running 410 gears with 33in tires.
post #4 of 22 Old 09-21-2010, 07:23 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Fill in your profile. You have a 32RH (4.0L) or a 30RH (2.5L) transmission...
Knuckelhead is offline
post #5 of 22 Old 09-21-2010, 08:37 PM Thread Starter
pinoypowers
I have a 32RH transmission on my jeep. FYI: I just filled im my profile, this is my first post..........
post #6 of 22 Old 07-24-2011, 06:36 PM
benlee248
Same issue with a 30rh 4 cyl?
didnt replace the gaskets and bushings yet. but im not sure if it didnt help you if it would help me.
35s 3.73 gears
I also realized that the previous owner before didnt hook the trans cooler to the radiator as well.
Help?
l_______
/l ,[_____],
l---L -OlllllllO-
()_) ()_)--o-)_)
benlee248 is offline
post #7 of 22 Old 07-25-2011, 04:28 PM
cj847
See page 9 of the attached link. There are several seals and O rings that can leak in the front of the automatic.
http://www.scribd.com/doc/23066655/3...C-TRANSMISSION
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
post #8 of 22 Old 07-25-2011, 04:49 PM
Robert J. yates
He's the resident profile nazi... don't stress him
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #9 of 22 Old 07-25-2011, 05:28 PM
Knuckelhead
AFSOC Retired
And your the resident troll...
post #10 of 22 Old 07-25-2011, 06:21 PM
Robert J. yates
LOL.... thats all you got? Have you tried to help this guy since you grilled him about his profile?
:crickets:
Thought so.......
OP.... make sure you do not have a coincidental problem of another and separate leak. Someone else mentioned the stock tranny cooler lines which are known to leak and frankly, are you sure you have the pan installed correctly. The torque spec on the pan bolts is very low... 10lbs if I recall correctly and over tightening can crush the cork gasket and cause leaks. The one piece silicone gasket works better and if that doesn't help, you can always RTV the pan. Check that first before you go back to the pump.
post #11 of 22 Old 07-25-2011, 06:57 PM
Knuckelhead
AFSOC Retired
Thats all that was needed.
Telling him to fill out his profile is what was needed for others to also help him...
post #12 of 22 Old 07-25-2011, 07:09 PM
Robert J. yates
Negatory.
I didn't need that to help him at this point... and neither does anyone else who has even a passing familiarity with these transmissions.
Both the 30 and 32 transmissions are in fact very similar to each other with respect to their internals as both evolved from the original Torqueflite and the 900 series of Chrysler transmissions. My rebuilt 32RH in fact now has the larger 999 bands in it.
Your name fits you and not because you are into bikes.
post #13 of 22 Old 07-25-2011, 07:20 PM
Knuckelhead
AFSOC Retired
My name fits me well because I ride a 1941 Knucklehead.
You are still the resident troll, it fits you well.
Let it go...
post #14 of 22 Old 07-25-2011, 07:30 PM
Robert J. yates
Let it go...
Not one helpful comment to add for this guy.... well done.
post #15 of 22 Old 07-25-2011, 07:35 PM
Knuckelhead
AFSOC Retired
Your trolling again...
87 YJ TF999 transmission Doobiedog YJ Wrangler Technical Forum 3 04-19-2010 01:12 PM
tf999 front seal joeyrossmiller YJ Wrangler Technical Forum 4 08-23-2009 08:28 AM
TF999 Auto Trans Leak Bezzell YJ Wrangler Technical Forum 9 07-04-2009 06:50 PM
Auto transmission swap TF999(?) from a CJ into my YJ danholovic YJ Wrangler Technical Forum 2 01-09-2009 10:04 AM
95 YJ Radiator Leak/ Water Pump leak?? SThomas86 YJ Wrangler Technical Forum 11 01-05-2008 05:25 PM
